Old 03-15-2013, 09:20 AM   #26
Rich 5150 69
Rich 5150 69's Avatar
Re: Question about rear coils?
that was the reason for shock # 32207, but even with a proper shock, the angle is to great for the shock to be effective, even one a stock truck..
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 03-15-2013, 09:51 AM   #27
fleetsidelarry
Senior Car Nut
fleetsidelarry's Avatar
this link mentions another link which I've also added:
http://67-72chevytrucks.com/vboard/s...ock+relocation
http://talk.classicparts.com/showpos...8&postcount=51
you may run into driveline vibration with this much drop due to unequal u-joint angles so you might want to check and fix while under there
Larry
fleetsidelarry is offline   Reply With Quote
Old 03-15-2013, 01:41 PM   #28
Rich 5150 69
Larry I had five inch drop in before, no vibration at all, I changed to four inch drop do to no load carrying capacity, plus the rear mounted tank I installed. I will still move the shocks to the out side of the rame rails as soom as I get mounts made up and installed with pics...
Old 03-15-2013, 02:14 PM   #29
fleetsidelarry
Senior Car Nut
hey Rich. I understand. from what I can tell, most people don't have any problem. just thought that while he was under there it might be a good time to check the angles.
And I've thought about redoing my shocks the way you're describing. the "relocator" kit helps a little but there's still a pretty large angle even with just the 3" drop. the regular drop springs are so wimpy I ended up buying an overload bag setup. I was going to share for the OP but haven't found a link yet.
Larry
Old 03-15-2013, 03:27 PM   #30
Rich 5150 69
For those that want to do they`re own homework, here`s a couple of sites you`ll want. fter doing the search, I bought my shocks on e-bay 26 bucks for both delievered to my door....
http://www.kyb.com/technical/documen...onsSecured.pdf
http://www.monroe.com/assets/downloa...engthSheet.pdf
Old 03-16-2013, 12:34 AM   #31
Captainfab
60-66 Nut
I believe it is No Limit Engineering that makes a kit for relocating the shock to outside the frame.
Old 03-16-2013, 12:57 AM   #32
Rich 5150 69
Captfab I did see those mounted on a '65' short bed, they were just ok, but I really did not like the away they were mounted, maybe it was the owner install but they looked as if they had a shock that was way to long, and the mounts looked a little on the weak side, I do have a plan I will get to soon....
Old 03-21-2013, 04:06 AM   #33
hop sing
hop sing's Avatar
Originally Posted by Clyde65 View Post
Just put some air bags on there bud. I replaced my 4" drop coils with 2600 bags and the dual schraders, rides better and I can tow now. With the springs I couldn't tow my small travel trailer ( 2000#).
is it possible to get pics of ur set up ? thx hop
hop sing is offline   Reply With Quote
Old 03-21-2013, 11:02 AM   #34
LVPhotos
LVPhotos's Avatar
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 03-21-2013, 11:03 AM   #35
LVPhotos
LVPhotos's Avatar
1962 Shortbox.
Old 03-21-2013, 11:04 AM   #36
LVPhotos
LVPhotos's Avatar
Max up. 100psi.
Old 03-21-2013, 11:06 AM   #37
Rich 5150 69
LV whats the load rating on those bags....?
Old 03-21-2013, 11:37 AM   #38
hop sing
hop sing's Avatar
Originally Posted by LVPhotos View Post
Thx bro , u wouldn't have of pic installed ? I have only bagged my diesel dodge w/leaf springs , I assume the bag goes inside the coil ? Thx hop
Old 03-21-2013, 11:41 AM   #39
LVPhotos
LVPhotos's Avatar
2140#@100 psi from Ridetech.
Old 03-21-2013, 11:44 AM   #40
LVPhotos
LVPhotos's Avatar
Hop sing I posted full up and full bumpstop down.
Old 03-21-2013, 12:33 PM   #41
hop sing
hop sing's Avatar
thx bruddah ,,didnt see the pics before this reply was on my i=phone ,,its pretty much like i did my diesel ,i remeber when i use to drag race a friend had a chevelle w/a bag inside coil on one side to cure the twist in the ass end ,,but thx for the education aloha hop
