Old 05-24-2013, 06:44 PM   #26
Homebuilt Hotrods
Homebuilt Hotrods's Avatar
Re: 1967 C10 SWB Fleetside Project
Need some help. I tore down my frame after it was blasted. Now realized that this very front crossmember is bent and one of the rivits are out. Do they sell these or do i need to bang it up and fit it in? I borrowed a picture of the crossmember from a fellow board member. (hope thats ok)
Garage Built
Homebuilt Hotrods is offline   Reply With Quote
Old 05-24-2013, 07:11 PM   #27
19Chevy67C10
19Chevy67C10's Avatar
Theres a rivet place online that sells rivits for our frames, also check with LMCTruck they also sell them I believe....Build looks sweet!
Kev's-C-10
19Chevy67C10 is offline   Reply With Quote
Old 05-24-2013, 07:15 PM   #28
19Chevy67C10
I'm sorry to load up your thread, but here's the place to get the factory style frame rivets...
http://www.bigflatsrivet.com/install.html
Rock on!
Kev's-C-10
Old 05-24-2013, 08:02 PM   #29
Homebuilt Hotrods
Rock on!
Never apoligize. I figure ill probibly have to bent it back to shape and put a bolt in it for now.
Garage Built
Old 05-24-2013, 10:36 PM   #30
Homebuilt Hotrods
Got it all tore apart and the bare frame preped for paint. Hopefully tomorrow if time allows... Second Pic is where that front crossmember is bent. I suppose I better fix that first.
Garage Built
Old 05-24-2013, 10:37 PM   #31
Homebuilt Hotrods
I also stripped that rust that was underneath some of the engine mounts and front suspension stuff, Pic was before that but you guys get the idea.
Garage Built
Old 05-25-2013, 12:19 PM   #32
Homebuilt Hotrods
Any reason I shouldnt do rustoleum roll on bedliner for the frame? Seems to be cost effective and easy. It would seem to me if its tough enough for bedliners it should stand up on the frame well any thoughts? Frame is freshly blasted.
Garage Built
Old 05-26-2013, 12:42 AM   #33
Homebuilt Hotrods
The first of two coats of Summit Racing Epoxy Primer Flat Black. Love how it turned out. One more coat and flip the frame to catch what i missed on the other side.
Garage Built
Old 05-26-2013, 11:31 PM   #34
Homebuilt Hotrods
Second coat of epoxy primer. Frame flipped, everything is covered well. 1 Quart paint, 1 quart catalist was enough for two medium coats to bare frame and front crossmember. Still have lower control arms, rear end, trailing arms and a whole lot of misc pieces yet.
Garage Built
Old 05-27-2013, 07:00 PM   #35
knomadd
knomadd's Avatar
Looking good. Keep posting pics. You know we all love to see what's going on.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 05-29-2013, 10:10 PM   #36
Homebuilt Hotrods
Bad luck today. My son (almost 3) and I were cruising in the 69 c10 cst 396 truck. Ran about 80 on interstate to go to favorite hardware store for a bunch of good priced grade 8 hardware for the 67 frame for reassembly when our luck changed for the worst.
All the sudden we didnt have any brakes, the pedal hit the floor with no stopping power. Thankfully it wasnt too busy in town or on the interstate and we just made it home (ran a few yellow lights). Just putted up the drive way slowed it down by neutral and my feet, then had to slam it in park. Took the front wheel off, inspected the rubber brake hose. No luck, pulled everything off and looked at the wheel cylinder to find it had broke off where that large nut attaches it, it must have pulled all the insides out and dropped the whole trucks brake fluid on the ground.
Then took out the brake cylinder and the brake line broke, then it broke at the other end as well...
Long story short thank god were alive. And the truck has all new 3/8" line, just waiting on a new rubber hose as mine had cracks, and the wheel cylinder. Should be up tomorrow.
WOW....
Garage Built
Old 05-29-2013, 10:17 PM   #37
knomadd
knomadd's Avatar
WOW, this is going to make me look closely at my vehicles this weekend. I'm glad you and your son got home safely.
-Duane
Old 05-29-2013, 10:26 PM   #38
Homebuilt Hotrods
Thank you... I too am very glad we got home safe. I too am going to be checking some other things as well. And double checking everything on the new build.
My son just loves that pickup. He loves all my old pickups. Even when we drive our newer trailblazer and we come out of a store and he sees an old truck he assumes we can just jump in and take off. This is one of my favorite photos of my son in my old 64 c10 custom cab big window truck. About a year and a half ago.
Garage Built
Old 05-29-2013, 10:34 PM   #39
knomadd
knomadd's Avatar
That's an awesome photo. And a great story too. I hope my kids will love my old vehicles as much as I do, when I have kids. Do you have build threads for your other trucks?
-Duane
Old 05-29-2013, 10:39 PM   #40
Homebuilt Hotrods
I believe i have a few threads on here from a 47 3100 i started it was on an s10 frame. A 53 5 window on an s10 frame and steel 20's. And a few other random things. To be honest I have a bad habit of selling things half complete.... Thats why with the encouragement of the forum. Im really trying to document and keep things rolling on the 67 build. I know its time to finish one. The 67-72 are by far my favorite trucks too so that helps. By the way love your 71 c10 i really hope mine looks half that good!!!. That is one killer truck you have there.
Garage Built
Old 06-17-2013, 06:05 PM   #41
Homebuilt Hotrods
Frame is back together with all new grade 8 hardware. Got the tires and rims mounted up. Plan on putting the drive train in and setting the box on the frame. Maybe then ill have some more room to work. And make room for the patina 1960 swb fleetside im picking up.
Garage Built
Old 06-17-2013, 06:06 PM   #42
Homebuilt Hotrods
I plan to do rear bags for hauling loads, so thats why the 4x4s are there just for bracing for now.
Garage Built
Old 06-18-2013, 12:55 AM   #43
Homebuilt Hotrods
I couldnt help but set the engine and trans in the new frame.
Garage Built
Old 06-18-2013, 01:35 AM   #44
knomadd
knomadd's Avatar
Nice!
-Duane
Old 06-18-2013, 02:36 AM   #45
Homebuilt Hotrods
Nice!
Thanks man I actually feel like I'm getting somewhere.
Garage Built
Old 06-19-2013, 11:03 PM   #46
Homebuilt Hotrods
Got the short box mounted. Love the look. Im thinking ill need to go lower for sure.
Garage Built
Old 06-20-2013, 10:44 AM   #47
67cheby
67cheby
67cheby's Avatar
Nice !
67cheby is offline   Reply With Quote
Old 06-20-2013, 01:09 PM   #48
Homebuilt Hotrods
Originally Posted by 67cheby View Post
Nice !
I really appreciate the support!
Garage Built
Old 06-30-2013, 02:36 PM   #49
Homebuilt Hotrods
Just picked up a very nice AC cab with very little rust. Even inner rockers look good. Already sandblasted and only 150 bucks. Feel pretty good!
Garage Built
Old 06-30-2013, 06:59 PM   #50
gdavis
gdavis's Avatar
That was a good find. Good luck with the rest of the truck.
Check out Patches
Cars I owned in the past.
1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev
1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS
1967 Buick electra 225 1995 Harley Davidson bager
What does not kill you will make you stronger
1968 c10 short wheel base stepper
gdavis is offline   Reply With Quote
