Old 05-12-2013, 12:05 AM   #26
dallred
Re: 89 tbi idle issues
Check this thread. They suggest fuel pressure.
http://67-72chevytrucks.com/vboard/s...d.php?t=399892
dallred is offline   Reply With Quote
Old 05-28-2013, 03:52 PM   #27
dallred
I think I have the Blazer running better. When I sprayed Carb cleaner around the shaft that goes through the TB with the butterfly valves on it and it started running better. Yesterday I pulled the TB off and took it all apart, then put o rings on the shaft. It seems to be running way better already. It seems I had a vacuum leak around that shaft causing terrible idle issues.....
We will see how it goes.
Old 05-28-2013, 07:42 PM   #28
brokenframe
i'm having a lot of the similar issues. but my sometimes acts like a vapor/hydro lock situation when I try to restart it after stalling. I've changed the iac, map, and cts. help!!!. go to my thread please and comment. its my daily driver and its not driving daily right now. didn't mean to steel your thread dallred.
brokenframe is offline   Reply With Quote
Old 05-28-2013, 11:49 PM   #29
dallred
http://67-72chevytrucks.com/vboard/s...d.php?t=582169
check this out guys this guy might need some help
pass that on.
idle, tbi
