Old 09-03-2014, 03:04 PM   #26
Dewey72
Re: 72 Cummins swap
Originally Posted by shopteacher View Post
great project and I'm Subscribed to this one! could you show a couple of pictures of you engine mounts please!
What color are you going with?
Here is the only Pics I got.
Dewey72 is offline   Reply With Quote
Old 09-03-2014, 08:37 PM   #27
shopteacher
Re: 72 Cummins swap
Hey Thanks for the Pictures!
Mine is a 2WD and will use a slightly different configuration, but I will be getting a hold of AutoWorld in the morning to order my set! I have used their mounts quite a few times in three Super Duty conversions and a mid 80's Chevy 4x4 cummins conversion!
Great products with friendly and fast service!
AutoWorld is #1 in my book
I need to have the Admin move my build from the 67-72 section to the Diesel Conversion section!
Keep up the great work!
shopteacher is offline   Reply With Quote
Old 09-08-2014, 01:06 AM   #28
C20scott
Re: 72 Cummins swap
I moved my tank to the rear for the purposes of being able to fit a sub behind the seats. And every inch of added storage space is a positive in these small single cabs. Unfortunately, ive found that the un-muffled drone of the cummins engine basically overpowers my stereo at cruising speeds.
Mine has the 31 gallon tank from a 1985 blazer, but i am considering swapping it for the 25gal just to save the few inches of vertical clearance...
1969 K20, Cummins 12v conversion in progress...
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=574152
C20scott is offline   Reply With Quote
Old 09-23-2014, 10:20 PM   #29
63c102013
63c102013's Avatar
Re: 72 Cummins swap
Very cool build. I am using fuel cell sitting in the bed of my truck. Might not be perfect for if you want to use your bed but would give you plenty of room for your exhaust. Good luck on your build
63c102013 is offline   Reply With Quote
Old 09-23-2014, 10:38 PM   #30
shopteacher
Re: 72 Cummins swap
Well I got my engine mounts from Auto World the other day and what a great fit and finish! Now to move on to my Rusty Rocker panels !
A mid 70's Blazer gas tank is going in the back between the frame rails for my tank problem !
Sorry about the hi jack!
Hows your project coming along?
Old 09-24-2014, 03:59 PM   #31
Dewey72
Re: 72 Cummins swap
Ya thinking about building a tank to go under my toolbox. The old man already cut a hole in the bed for a bed tank. Playing with ideas.
Old 09-24-2014, 04:03 PM   #32
Dewey72
Re: 72 Cummins swap
That Autoworld stuff is great built stout!! Ya I got the driver side rockers and cab corner on and finishing up the floor pan and off to the other side. Fun stuff.
Old 11-23-2014, 08:16 PM   #33
rgreathouse
Re: 72 Cummins swap
Any updates? Very nice build! Also do you have any pictures of hood latch support mods and radiator support mods to run the second gen Intercooler?
1972 c10,2wd,long bed,250,4spd---->
1972 SWB Fleetside 4x4 12v Cummins build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=513791
rgreathouse is offline   Reply With Quote
Old 11-24-2014, 05:17 PM   #34
Dewey72
Re: 72 Cummins swap
Found some pics. I can get more.
Name:  cab off 001.jpg
Name:  cab off 006.jpg
Hope that helps. I cut the top two rows off of my intercooler and welded.
Old 11-24-2014, 05:24 PM   #35
Dewey72
Re: 72 Cummins swap
Finally got back to this project this past weekend. Still working on the cab. Cutting out the rust and welding in new panels. Been busy stocking the freezer with salmon. Did get some time to get these. Figuring on mounting them in the pillar.
Old 11-24-2014, 08:59 PM   #36
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 72 Cummins swap
Nice gauges. Salmon huh, what river do you get them out of? That sure sounds good to have in the ol freezer.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 02-19-2015, 12:00 AM   #37
Dewey72
Re: 72 Cummins swap
Got some time to work on the old girl.
Old 02-19-2015, 09:40 PM   #38
Dieselwrencher
Re: 72 Cummins swap
Nice work! That looks great!
Ryan
Old 02-22-2015, 06:24 PM   #39
Dewey72
Re: 72 Cummins swap
Cleaned the garage out and found my other project.
Old 02-22-2015, 06:33 PM   #40
Dewey72
Re: 72 Cummins swap
74 nova. 425 + HP 383 SB. Ended up with a free car and had to build a cool engine for it. Its funny how a free project ends up costing a small fortune. Humm... Head scratcher.
Old 02-23-2015, 03:31 PM   #41
Dieselwrencher
Re: 72 Cummins swap
Very nice! I hear that on the free car costing a fortune!
Ryan
Old 02-29-2016, 08:16 PM   #42
rgreathouse
Re: 72 Cummins swap
Dewey72 any updates? Lookin good. What radiator hoses did you go with? My nextt project is getting cooling system squared away.
Old 03-01-2016, 05:16 PM   #43
Dewey72
Re: 72 Cummins swap
Got the cab and doors all blocked out and almost ready for the paint booth just need one more final sand when I can find time. The upper radiator hoes was the 93 dodge hose with a bushing on the radiator and cut and extended in the middle and the lower hose was a John Deere hose off a tractor. Cant remember what one. I have it wrote down in my notes somewhere if interested.
Old 08-06-2016, 08:42 PM   #44
Dewey72
Finally progress!
Old 08-06-2016, 08:44 PM   #45
Dewey72
Re: 72 Cummins swap
Old 08-06-2016, 11:09 PM   #46
COS399
COS399's Avatar
Re: 72 Cummins swap
Very nice looking project you got going.
1987 GMC R2500 SC 454 T400
1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors
COS399 is offline   Reply With Quote
Old 08-08-2016, 06:30 PM   #47
Dieselwrencher
Re: 72 Cummins swap
I love the color choice on it!
Ryan
Old 02-27-2018, 05:22 PM   #48
Dewey72
Re: 72 Cummins swap
Figured I would give a update. Paint is about done and still fitting body panels. Looking for a outer grill. Got the air filter and exhaust on. Also looking for wheels and tires. Will 35"s fit with only a 4" lift? Slowly making some progress. Name:  exhaust 027.jpg
Old 02-27-2018, 08:13 PM   #49
Dieselwrencher
Re: 72 Cummins swap
That is looking great! I've seen a lot of pics with 4" lifts and 35s on these. I'd give it a try. You're just 2 pairs of zero rates away if you need an inch extra lift if they don't.
Ryan
Old 02-16-2019, 10:10 PM   #50
Dewey72
Re: 72 Cummins swap
[size=1]Posted via Mobile Device[/size Final got to drive it a bit. Ran strong. Went to move it the next day and the thing wanted to go to high isle at start. Tried about a dozen times. Ended up pulling the darn pump off.
