#26 |
![]() Join Date: Feb 2014
Re: 86 K10 LWB - Frankie
After multiple attempts I finally got all of the air out of the clutch hydraulics. Sitting on the floor because I haven't installed the seat yet, I took it for about a 1/2 mile trip down the road and back. Felt good to have it moving on it's own power.
86 Chevrolet K10 350/SM465 Frankie SOLD 1995 GMC Yukon GT SOLD 1996 GMC Yukon GT 2010 Suburban 1500 4x4 5.3l/6L80e. Sold 2016 Silverado 2500HD Crew Cab 4x4 6.0l/6L80e |
#27 |
Been a while since I posted. I got a few things done since then. Exhaust is now hanging from brackets instead of the strap.
#28 |
I installed my new windshield. New seal was a bit challenging to fit on the new glass but it turned out well.
#29 |
Al's liner HNR down on the floor.
#30 |
Got a few more things put back on. Seems like every time I check one item off of the to-do list, I discover two or three more to add to it.
#31 |
Looking good!
#32 |
Finally got all the instrument gages working and reinstalled enough components I felt I could take this beast out for a drive. Decided to stick to the back roads so I could just cruise along. I got about half way to my buddy's house (around 4 miles) and I lost power. I
The engine would run but it would not excelerate. Took me almost 40 minutes to chug back home. New fuel pump installed this afternoon with the addition on a fuel filter and Frankie is terrorising the neighborhood again. On a different note, is it just me or can any of you remove 3 trucks worth of seat belts, saving all the hardware but when it comes time to install, you can only find enough bolts to install the drivers seat belt???
#33 |
It's been a little while since I posted an update about Frankie... well that is because I had not done anything more than drive it. The seat you see in my last set of pictures may look decent but the whole frame is very rusty. I put it in the truck because I did not have anything else to use. I drove it a few time and then the webbing gave way and the cushion sinks through.
While playing around on CL this past weekend I came across a cool find. A few text messages to the seller to work out a trade for some spare parts I have and score... a new seat for Frankie. It may not look the greatest but it sits pretty comfortable and it should clean up real nice.
#34 |
I recovered my headliner and painted up the trim pieces. I need to order a few things but I am trying to keep some momentum and get this done a little at a time. Eventually the interior will be two sades of gray and black.
#35 |
Progress has been slow but the miles are getting added to the odometer every week. I discovered a few minor issues that I have been addressing along the way. I have plans for a few more upgrades from my current parts. My entire front clip is cheap aftermarket parts that are very rusty on the inside. I have been collecting some good GM parts and now I have everything to replace the front clip. I found a pair of fenders on CL in Jacksonville. I also found a complete core support from an 89 Suburban in Ocala. When I went to pick that up, I also scored a hood. If it stops raining this weekend I will take a few pics and upload them.
86 Chevrolet K10 350/SM465 Frankie SOLD 1995 GMC Yukon GT SOLD 1996 GMC Yukon GT 2010 Suburban 1500 4x4 5.3l/6L80e. Sold 2016 Silverado 2500HD Crew Cab 4x4 6.0l/6L80e Last edited by silverbear; 03-26-2015 at 05:01 PM. |
#36 |
Step 1: Hood replacement. The new one has a couple of scratches and dents but it is RUST FREE!
Core support and fenders will get installed soon.
#37 |
Looks good.
#38 |
#39 |
Step 2: Replace core support and grill. these are from a 89 Suburban. Special thanks to GMACHINZ for hooking me up with contacts I needed to convert the connector on the wiring harness.
The grill in not in the greatest shape but it will work for now. Step 3: Drivers fender replaced. Cheap, rusty aftermarket one gone and a factory (rust free) original in it's place. Maybe tomorrow, if the weather continues to hold out, I can swap out the passenger's side fender. This may be a small victory but I also now have functional horns. ![]()
#40 |
Second Chance Program
Subscribed.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt. 77 C20 crew cab Silverado. 396/th400. In work. |
#41 |
![]() Join Date: Jul 2014
Good amount of work here! Looking good!!!
#42 |
Thanks. It has been a long project but I have enjoyed being able to use it as I improve it.
#43 |
A little diversion from the body work. The before pic. The brush aluminum look was damaged so I wanted to try to dress it up a little.
The after pics. Silver carbon fiber vinyl made a big difference. Nice thing is, I have about $6 in materials and if I get tired of it, it is easy to change out.
#44 |
A couple of pics of the dash bezel mocked up in the truck along with the right side trim piece.
#45 |
Looks really good Chris. Time to get it installed.
#46 |
Thanks Brad. I have a few things to install under the dash before I can finish up the duct work and then the trim pieces. I hope to get the sound deadener install on the firewall this weekend.
#47 |
Step 4: Back to the body. I replaced the passenger fender and now that is the last piece I need to replace. I will have a little work to do on the bottom of my doors but I can live with them for now.
While I had the fender off I took opportunity to do some work on my blower motor. And since I was that far into it, I dropped out the heater box and added some sound deadener. Got the passenger side done last Saturday and I worked on the driver's side today. I know I have a lot more floor to cover but the rest will wait until I have the carpet ready to go in. Next step is to re-install all of the duct work in the dash.
#48 |
Good stuff!
#49 |
More progress on the interior. The PO had painted the dash pad with common gloss black spray paint. You can see it in some of my previous posts. I spent a few evenings this past week to sand and prep it for refinishing.
After sanding and cleaning.
#50 |
I chose to use SEM Landau Black for the dash and door panels. I also got some SEM Smoke Gray for the kick panels and upper trim.
The dash now.
