Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 03-03-2015, 02:14 AM   #26
64chevtruck
Re: Trailing Arm Mounts
Hi, Im getting ready to put a later 308 rear end in my 64 that has trailing arms, Im guessing ill need these brackets then>? Im not sure how many bolts the new rear end has in it or how big the tubes are yet though, I will get that info tomorrow.
Have a good week
64 C10 Fleetside LB 4 Sp/292 Build http://67-72chevytrucks.com/vboard/s...d.php?t=602438
70 GMC 1500 Fleetside LB 3OT/350 Build http://67-72chevytrucks.com/vboard/s...83#post6767983
76 GMC CCLB Dually Build http://67-72chevytrucks.com/vboard/s...d.php?t=691612
79 GMC 3500 Fleetside LB 454/400
90 Suburban Silverado 4x4 350/700R4
97 1500 Cheyenne Short Fleet 350/5sp
64chevtruck is offline   Reply With Quote
Old 03-04-2015, 12:20 AM   #27
Captainfab
60-66 Nut
If the differential is a 8.5" 10 bolt or a truck 12 bolt, the axle tubes are 3" in diameter.
Old 05-17-2015, 11:58 AM   #28
short62
Hi Capt need trailing arm mounts for 10 bolt 8.5
short62 is offline   Reply With Quote
Old 05-17-2015, 11:38 PM   #29
Captainfab
60-66 Nut
I'll send you a PM with ordering and payment info.
Old 06-07-2015, 11:58 PM   #30
Captainfab
60-66 Nut
Bump
Old 07-01-2015, 01:11 PM   #31
OldChevy61
OldChevy61's Avatar
Captain, I need a set of the trailing arm mounts for 12 bolt truck rear end . Getting rid of the ho32.
OldChevy61 is offline   Reply With Quote
Old 07-01-2015, 11:24 PM   #32
Captainfab
60-66 Nut
Old 07-07-2015, 07:27 AM   #33
OldChevy61
OldChevy61's Avatar
Got the mounts yesterday. Solid pieces and great service. Thank you Sir.
Old 08-11-2015, 02:51 PM   #34
DakotaKid
is there a Diagram with Measurements for the spacing of these for 60-62?
Current Project : 1962 Chevy SWB Fleetside
Others, 1958 Edsel Villager Station Wagon
1926 Ford Model T Roadster Hotrod
www.suedescarclub.com
DakotaKid is offline   Reply With Quote
Old 08-11-2015, 11:57 PM   #35
Captainfab
60-66 Nut
I can try and get some measurements for you tomorrow, but to get the pinion angle correct, you really need to mock this up under your truck at your desired ride height.
Old 08-12-2015, 11:08 AM   #36
DakotaKid
Pinion Angle is easy to set, more worried about the spacing between the 2 mounts.
Old 08-13-2015, 01:36 AM   #37
Captainfab
60-66 Nut
I am not able to get precise measurements for this but what I came up with is the center to center of the U-bolt at the rear should be aprox 46-3/8" and at the front 44-1/4".
Old 02-01-2016, 01:13 AM   #38
Captainfab
60-66 Nut
Bump
Old 02-01-2016, 10:25 AM   #39
Hop
Cap, PM'D
Hop is offline   Reply With Quote
Old 02-03-2016, 11:34 PM   #40
60chevyjim
60chevyjim's Avatar
Originally Posted by Captainfab View Post
These are the mounts that you need when installing a non-original differential under your trailing arm equipped truck. I make these for both the 10/12 bolt differentials and the 14 bolt differentials. They are laser cut from 3/16" steel, formed on a press brake and the end caps are MIG welded on. The price on these are $55.00 plus a flat rate shipping in the US of $12.35. As always I will combine shipping when you purchase other items from me, to save you money on shipping.
To make a purchase either post in this thread, send me a PM here on the forum or send me an email to captainfab454@hotmail dot com.
nice brackets !!
60chevyjim is offline   Reply With Quote
Old 02-04-2016, 12:16 AM   #41
Captainfab
60-66 Nut
Originally Posted by 60chevyjim View Post
nice brackets !!
Old 02-06-2016, 11:06 PM   #42
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
Hey captain im looking at putting a 14 bolt sf 6 lug axle under my 61 crew cab. Still working everything out. The 14 bolt measures about 3.33 on the axle tube. Will the new mounts accommodate this bigger size? Thanks
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 02-07-2016, 01:25 AM   #43
Captainfab
60-66 Nut
I don't know why the trailing arm mounts I make for the 14 bolt wouldn't work on your 14 bolt. I haven't had any complaints of them not fitting.
Old 02-15-2016, 10:04 PM   #44
CHIZZLER
CHIZZLER's Avatar
Please send me a PM for the trailing arm 14 bolt mounts. I need to get a set. Thanks
61-crew cab D-max
Old 02-16-2016, 01:05 AM   #45
Captainfab
60-66 Nut
I'll send you a PM.
Old 02-21-2016, 11:31 AM   #46
CHIZZLER
CHIZZLER's Avatar
Parts received. Very nice. Thanks.
61-crew cab D-max
Old 04-06-2016, 12:37 AM   #47
Captainfab
60-66 Nut
I have one set of stock length U-bolts available for $47.50 plus shipping. If there is a genuine interest in these, I will consider stocking them.
Old 06-15-2016, 04:32 AM   #48
BillyT
Hey Captain,
You sold me. I will take one set for a dana 60. Rear was out of a 69 with leaf springs. Measures identical but required much grinding!
M/O mailed today.
Billy
68 Custom SWB
BillyT is offline   Reply With Quote
Old 06-15-2016, 11:26 PM   #49
Captainfab
60-66 Nut
I will let you know when I receive your payment and ship your Dana 60 trailing arm mounts.
Originally Posted by BillyT View Post
Hey Captain,
M/O mailed today.
Billy
Old 07-04-2016, 01:10 AM   #50
Captainfab
60-66 Nut
The U-bolts are sold.
I now have trailing arm mounts for the Dana 44 and the ultra rare 6 lug Dana 60 with the 2-3/4" axle tubes.
