Old 07-31-2014, 03:09 PM   #26
Cash3481
Loves all GMC trucks
Cash3481's Avatar
Re: One Year Only Stuff 67-72...
I think the 67 auto column shift indicator was more round than the other years at the back of it.
Wasn't there a year the column indicator housing was metal?
Were 67 seat belts mentioned yet.
67-8 core supports have a splash pan on the bottom of them.
67-8 fuse Blocks are orientated 90 degrees as opposed to other years.
Radio delete trucks had radio delete cowl panels and I think no antenna hole in firewall
67-8 windshield and rear window trim is skinner than newer years
I hope I helped the cause...
Mike
Cash3481 is offline   Reply With Quote
Old 08-01-2014, 03:37 PM   #27
GobbleStalker
GobbleStalker Calls
GobbleStalker's Avatar
I beleive the stamping on a 67 tailgate different then a 70-72. The 67 didn't have a lip at each edge. Can't tell now I sold mine last year but it was all original and I found that out from this sight also. Went to check my 67 vs my 72 and it was correct.
72 Chev Longbox Highlander edition. Med Olive/White/ Med Olive 350 4bbl with 350Turbo trans. Truck currently under construction. Project Cappaccino.
Stay Tuned!
1967 Chevy C10, 327, 4.11 posi 3 spd. The Driver Truck! SOLD!
09 GMC Sierra SLT All Terrain pkg.
2014 Jeep Wrangler Sahara unlimited. ( The wifes ride )
GobbleStalker is offline   Reply With Quote
Old 08-03-2014, 07:57 PM   #28
michael bustamante
michael bustamante's Avatar
Originally Posted by GobbleStalker View Post
I beleive the stamping on a 6tailgate different then a 70-72. The 67 didn't have a lip at each edge. Can't tell now I sold mine last year but it was all original and I found that out from this sight also. Went to check my 67 vs my 72 and it was correct.
Well this is interesting. I have a 67 fleeet taigate still but no other to compare it to.
1967custom
michael bustamante is offline   Reply With Quote
Old 08-07-2014, 09:59 PM   #29
1972RedNeck
1972RedNeck's Avatar
Since nobody has specified 1/2 tons to 1 tons only, small back windows were available through '72.
1972RedNeck is offline   Reply With Quote
Old 08-12-2014, 09:03 AM   #30
'71 Cheyenne Super chrome tailgate handle. Did that already get mentioned? '71 Disc brake decal?? (sorry,too lazy to check)
Old 08-12-2014, 10:07 AM   #31
Originally Posted by casper1969 View Post
I believe the rear tail light trim option in 67 was the eye brow only where as years after were the whole light trim and only top bar for tail gate trim where as following years had the bottom trim as well...
That's how both '67 & '68 were. It came with the side trim.
Originally Posted by Jake1971 View Post
Not sure why people are saying the fold forward seat was 1967 only. My 1971 C10 had the original fold-forward bench seat with the dealer papers stuffed into the back of the seat when I bought it in 1986.
You can take a bolt out and lean the seats forward,but the way the original upholstery wraps to the bottom it won't allow folding. Does it have the original or an original type cover?
Old 08-12-2014, 01:26 PM   #32
casper1969
casper1969's Avatar
I wasnt sure about 68 but I do now thanks
casper1969 is offline   Reply With Quote
Old 08-12-2014, 03:19 PM   #33
There's plenty to be not sure about,that's for sure. My problem is,for everything I learn it seems I'll get unsure of something I already knew. Like '68 front trim,whether every truck got it or just Customs and CSTs. I'll have to look at pictures because I questioned myself.
Old 08-12-2014, 03:41 PM   #34
john
member #16
john's Avatar
67-68 emergency brake was hand pull, 69-72 were foot pedal.
67-70 throttle rod 71-72 cable control.
john is offline   Reply With Quote
Old 08-12-2014, 07:46 PM   #35
casper1969
casper1969's Avatar
Yes same here but I rest assured I will learn more and more from all the knowledgeable people here
Old 08-13-2014, 03:16 PM   #36
sixtyeightC10
I don't know if this considered relevant or important or not, but the 1968 and (some 1969?) years had the larger journal crank 327 as where before 1968 they only had a small journal crank 327.
Plus, only a handful of these were factory ordered with the 300 HP version, mine just happened to be one of them.
sixtyeightC10 is offline   Reply With Quote
Old 08-14-2014, 08:44 AM   #37
That's a good one. It's a true '68-only item,327 large journal. It's the 010 block used for the first SS350 Camaro (350hp) in '68 as well. Forged crank and higher nickle alloy block.
Old 08-14-2014, 09:05 AM   #38
sixtyeightC10
Before I replaced the heads, when I purchased spark plugs and oil filters, I had to use the camaro or nova specs as that when I had used the truck specs those parts were all wrong.
1968 C10, 327 large journal crank, TH400 trans, 12 bolt 3.73 geared rear axle, and rear leaf springs. HEI, Delco 10SI, and brake booster upgrades.
Formerly known as mtndewmaniac66.
Old 08-14-2014, 12:18 PM   #39
71Crew
What about 72 only etreme bend tow hooks
71Crew is offline   Reply With Quote
Old 08-14-2014, 02:11 PM   #40
hvacfatboy
I believe also that 67-68 had steel air boxes on firewall for heat and 69-72 were plastic also the foot print was different.
hvacfatboy is offline   Reply With Quote
Old 08-15-2014, 03:05 PM   #41
BigRed76
BigRed76's Avatar
1970 1/2 ton 2wd rear axle was one year only being the same width as 71/72 but still being 6 lug like 67-69.
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 08-15-2014, 09:16 PM   #42
casper1969
casper1969's Avatar
I put a posi trac 12 bolt from a 76 chevy and bolted
Right in my 69 1/2 ton only had to change shock
Mount location width didnt change only shock mounts
And perch width is a tad bit wider
Old 08-15-2014, 10:05 PM   #43
colgad
colgad's Avatar
Anyone mention about the 67 frame not having the indent for a power steering gear?
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline   Reply With Quote
Old 08-16-2014, 08:50 PM   #44
BigRed76
BigRed76's Avatar
But a 76 2wd half ton would be 5 lug, not 6 lug like the 70.
Zach
Old 08-16-2014, 08:59 PM   #45
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Here's the tie rod bracket used to secure the 72-only steering stabilizer for K-model (4wd) applications. The Dana 44 axle for 72 had a bracket for the other end I believe is not present on preceding model year Dana 44s.
Old 08-17-2014, 12:42 PM   #46
I forgot about the '72 K-series steering stabilizers. Did anyone mention the '72 step bumper?
Old 08-17-2014, 02:29 PM   #47
burb71
Active Member
1968 only side markers, not lights just reflectors.
burb71 is offline   Reply With Quote
Old 08-17-2014, 05:52 PM   #48
'72s had starting instructions on the back of the driver side visor
Old 08-17-2014, 09:30 PM   #49
70shortfleet
70shortfleet's Avatar
Did anyone mention 72 doors are one year only and 72 big block motor mounts are one year only
70shortfleet is offline   Reply With Quote
Old 08-17-2014, 10:20 PM   #50
Cash3481
Cash3481's Avatar
The original poster was updating the first post.
Not sure if anyone mentioned the rearview mirror raised pad on one of the years trucks... I think it was 71? Someone correct me!
Mike
Mike
If your helping someone and expecting something in return... your doing business not kindness!
