Old 11-22-2014, 08:25 PM   #26
mechanicalman
Re: My Build Thread (Sort of)
Originally Posted by engineer_gregh View Post
Couple of hundred more miles and I was not happy with the way the truck ran. It seemed to run hot and was underpowered compared to a big block I had owned in the 80's. So I found someone I trusted to rebuild the engine. I don't have the space, tools, or experience to do it myself. Once torn down we discovered 6 402 pistons and 2 396 pistons, 4 burnt valves with bent push rods, and a crank that was so far out of tolerance it couldn't be turned. Just behind the rear lobe on the cam there was a grove cut all the way around. Believe it or not the truck actually ran ok and didn't skip at all. My mechanic has been rebuilding engines for 30+ years and was amazed it ran at all. So the rebuild begins.
65's and 66's used a grooved rear cam journal.
"the 1965 and 1966 big block 396 had unique rear cam bearings and required a grooved rear cam journal, most cams you buy currently are not grooved, the groove can be cut on a lathe in the last rear journal on the later cams , centered ,and its about .188 wide and .125 deep, if the cam is cut,for that oil groove the standard cam bearing can be used".[/size]
http://www.chevytalk.org/fusionbb/sh...hp?tid/311489/
I believe those heads raised the compression (98cc heads). I believe the stock heads would have had larger chambers.
mechanicalman is offline   Reply With Quote
Old 11-23-2014, 10:18 AM   #27
engineer_gregh
engineer_gregh's Avatar
I don't believe the new cam was grooved so now I'm concerned that I'll have problems in the future. Mechanicalman I hope my engine builder knew what he was doing. I've put about 4K miles since the rebuild with no issues. The gearing and transmission will be a next year project. I would like to have more power out of the hole but the truck runs and drives so good that I just can't justify spending that much money right now. The only addition I've made lately was to add a CPP rear sway bar. It did improve body roll but it seemed to make the truck ride a little rougher. The suspension is less forgiving with rough roads.
1971 Longbed BB Cheyenne Super
1972 Longbed SB Cheyenne Super
1972 Longbed Highlander Custom Deluxe
1975 K5 4x4 full convertible
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=645165
Greg Smyrna TN
engineer_gregh is offline   Reply With Quote
Old 11-23-2014, 10:52 AM   #28
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
[QUOTE= Just behind the rear lobe on the cam there was a grove cut all the way around.E]
That cam was specific to a 1965 396. That groove was for oiling on a 65 396 block which is different than later years BBs.
Sorry, didnt see post #26.
Tom Vogel is offline   Reply With Quote
Old 11-23-2014, 12:48 PM   #29
mechanicalman
That grooved cam was for 65-66, not sure even all of 66; you can't use a non-grooved cam in a 65-66 block. It is ok, however, to use the grooved cam on a later block like you were doing albeit not necessary at all.
No worries, the 3969854 block was for 69-72 396/402/454 2 & 4-Bolt that uses a non-grooved cam. You have the right style cam for your block.
Usually a sway bar will make it ride rougher. If you hit a bump straight on, like a speed-bump or drainage deression, it won't make a difference. You will notice when you hit a speed bump at an angle and go through a drainage depression at an angle that the vehicle will lurch back and forth sideways.
If you used these pistons-
http://www.summitracing.com/parts/sl...make/chevrolet
I figure your compression to be around 8.5:1, perfect for the cam you selected. Unless you used steel shim head gaskets, or had your heads milled then you are close to 9:1.
Old 11-23-2014, 01:25 PM   #30
mechanicalman
Keep in mind that the TH400 has a 2.48:1 first gear ratio and the 700R4 has a 3.05:1 first gear ratio with a .7:1 overdrive.
The 4L80E has a 3.06:1 first gear, BTW, with a .75:1 overdrive.
I'd put in the trans first then address the rear end gears seeing how much lower the first gear is on the over-drives. For instance, if you had a 3.73:1 with the T400 you would have a 9.6:1 overall 1st gear. If you had the 3.73:1 with the 700R4, you would have a 11.2:1 1st gear.
With the 3.42:1 that you have now, with 700R4 you have 10.43:1 first gear.
T400 third gear 1:1 with 3.73:1 is 3.73:1 gas guzzler. With 700R4, 3.73:1 is 2.61:1 ratio highway cruiser. With 4L80 is 2.78:1 cruiser.
I think you will find after you change the trans that you will want a posi anyway so then you will have to change the carrier. Have you seen these style diffs? A posi that does not lock up when you don't need it.
http://www.summitracing.com/parts/dtl-913a315/overview/
Old 11-24-2014, 08:54 AM   #31
engineer_gregh
Mechanicalman I appreciate all the great advice. I'm still running the original 3.08 right now. The rear end and transmission is a next spring project.
Greg Smyrna TN
Old 11-24-2014, 11:03 AM   #32
EdSevered
EdSevered's Avatar
On the bright side, it doesn't look like she needed any body work. She sure is purtty. -Ed
EdSevered is offline   Reply With Quote
Old 11-24-2014, 12:39 PM   #33
engineer_gregh
Thanks Ed. Honestly I went above and beyond what anyone else (normal driver) would have done to the truck. Wheels & tires, rebuilding a transmission that would have probably lasted if left alone, sound proofing the cab, upgraded alternator, long tube headers, bigger cam, three angle valve job, etc.. are what I wanted, and I'm sure that most on this board would have done. I'm building the truck to keep and I want to know that I can take it on long trips with no major issues. Making it mine, is another way to say it.
Greg Smyrna TN
Old 06-24-2015, 08:04 PM   #34
PIG-TECH
PIG-TECH's Avatar
wow sharp looking truck. love the shine on the paint job. i am waiting for my garage to be built. and then i get to start fixing mine up
PIG-TECH is offline   Reply With Quote
Old 08-07-2015, 09:37 PM   #35
engineer_gregh
Updated the wheels and tires. Grandkids like 'em!
Greg Smyrna TN
Old 08-07-2015, 10:23 PM   #36
9teen69
9teen69's Avatar
Looks sweet , really nice truck!
72 Cheyenne SWB C10 (daily driver)
(Super fake cause I just love the glovebox emblem)
70 Camaro RS (frame-off in pieces)
70 Camaro RS (daily driver backup)
69 Custom LWB C10 (son now drives)
9teen69 is offline   Reply With Quote
Old 08-19-2017, 10:32 PM   #37
Big Block
Big Block
Big Block's Avatar
Beautiful truck.
Big Block is offline   Reply With Quote
Old 08-19-2017, 10:45 PM   #38
engineer_gregh
Thank you.
Greg Smyrna TN
Old 10-29-2018, 10:39 PM   #39
72swbcamo
Active Member
You have beautiful grand children. God bless them. Nice truck too.
72swbcamo is offline   Reply With Quote
Old 10-30-2018, 08:24 PM   #40
Red71gmc
I have a 402 in my new purchase that runs really good, but is no power house by any means. I believe it is all stock.
Are you happy with the power improvement of your upgrades to your engine?
Red71gmc is offline   Reply With Quote
Old 10-30-2018, 09:49 PM   #41
Riverdog57
Love the Truck !!! Love the long bed .
Riverdog57 is offline   Reply With Quote
