Old 08-10-2015, 03:13 PM   #26
corndoggydogg
corndoggydogg's Avatar
Re: 1970 GMC 1/2 Ton 350
Before and after. 2.5" drop spindles up front. 2" drop shackles in back. Also did a full brake overhaul all around and replaced the ball joints while I was at it. The photos don't give a true representation of the stance change. Very subtle and exactly what I was going for. Not slammed, not riding high, and still able to haul loads.
1972 GMC 1/2 Ton
Long Bed
350
My build: http://67-72chevytrucks.com/vboard/s...73#post6961273
corndoggydogg is offline   Reply With Quote
Old 08-10-2015, 03:13 PM   #27
corndoggydogg
New dash pad. Before and after.
1972 GMC 1/2 Ton
Long Bed
350
Old 08-10-2015, 03:19 PM   #28
corndoggydogg
Time to add some speakers and a CD player. PO cut holes in the doors, so decided to use those. Hit the junk yard and pulled a pair of rubber wire looms from a Chrysler 4 door for $5.
1972 GMC 1/2 Ton
Long Bed
350
Old 08-10-2015, 03:25 PM   #29
corndoggydogg
Changed the rear slider glass to a single piece with stainless trim. Went in OK, but the trim is not seated perfectly. Will probably need to redo that at some point in the future. Currently working on installing the new windshield and struggling with that piece of stainless trim. The gasket from LMC appears to be the problem. The trim channel does not have much to grab onto, so i will likely scrap it and buy one from Precision. Wish I had read up on that before purchasing from LMC--pretty negative reviews all around.
1972 GMC 1/2 Ton
Long Bed
350
Old 08-30-2015, 10:20 PM   #30
corndoggydogg
Removed rust, repaired and repainted the bed.
1972 GMC 1/2 Ton
Long Bed
350
Old 08-30-2015, 10:28 PM   #31
corndoggydogg
New side mirrors. Before, during and after.
1972 GMC 1/2 Ton
Long Bed
350
Old 08-30-2015, 10:35 PM   #32
corndoggydogg
Finally replaced the broken windshield. Upgraded to the stainless trim. Tried to do it myself; spend about 3 days trying to install the trim, and eventually broke the replacement windshield in the process. A quick call to Speedy Glass, and had it replaced and properly installed within 48 hours for $200+tax. Very happy with the results and price. Will never try to install a windshield myself--especially on a 67-72. Not worth the brain damage.
1972 GMC 1/2 Ton
Long Bed
350
Old 09-07-2015, 08:34 PM   #33
corndoggydogg
New wheels and tires.
Front: 18" x 8" with 235/65.
Rear: 18" x 9.5" with 275/60.
Purchased an almost new set tires from wowusedtires.com. I have to give them a big plug because they hooked me up with a great deal on great tires. I highly recommend them if you're in the market for used tires.
1972 GMC 1/2 Ton
Long Bed
350
Old 09-08-2015, 11:40 AM   #34
TheCougarine
TheCougarine's Avatar
That looks killer.
TheCougarine is offline   Reply With Quote
Old 09-08-2015, 12:07 PM   #35
tommys72
tommys72's Avatar
Very nice progress!
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 05-16-2016, 03:15 PM   #36
corndoggydogg
New instrument cluster bezel, repainted needles, and restored/painted steering wheel.
1972 GMC 1/2 Ton
Long Bed
350
Old 06-04-2017, 10:37 AM   #37
corndoggydogg
Installed rear roll pan.
1972 GMC 1/2 Ton
Long Bed
350
Old 07-09-2017, 08:49 PM   #38
corndoggydogg
First noteworthy mechanical upgrade in a long while. Replaced the rusted out 2.0" exhaust system. Installed 2.5" pipes, h-tube and Summit Racing 2-chamber "Race" Mufflers (Flowmaster 44 clones, 1/3 the price). Entire set-up ran me $266. Took me about 4 hours to remove the old exhaust and replace with the new. Very happy with the results.
1972 GMC 1/2 Ton
Long Bed
350
Old 02-02-2019, 07:24 PM   #39
corndoggydogg
Restored period correct license plates.
1972 GMC 1/2 Ton
Long Bed
350
Old 02-02-2019, 07:30 PM   #40
corndoggydogg
Finally decided to start on body and paint. Spent the summer stripping paint and doing body work.
1972 GMC 1/2 Ton
Long Bed
350
Old 02-02-2019, 07:32 PM   #41
corndoggydogg
Now that I am down to 100% bare metal, applying epoxy primer one panel at a time.
1972 GMC 1/2 Ton
Long Bed
350
Old 02-02-2019, 08:06 PM   #42
swamp rat
swamp rat's Avatar
Good to see your back at it!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 02-04-2019, 11:35 PM   #43
corndoggydogg
Teaching son how to use a die grinder (on a less than perfect weld).
1972 GMC 1/2 Ton
Long Bed
350
Old 03-24-2019, 10:01 PM   #44
corndoggydogg
Primer now applied to 50%.
1972 GMC 1/2 Ton
Long Bed
350
Old 05-09-2020, 01:57 PM   #45
corndoggydogg
Spent September 2019 working on the front end of the engine. New timing chain, water pump, oil pump, harmonic balancer, paint, seals, belts, hoses, engine mounts, etc.
1972 GMC 1/2 Ton
Long Bed
350
Old 05-09-2020, 02:01 PM   #46
corndoggydogg
Then finished by installing a new aluminum radiator and transmission cooler. This was actually my original September 2019 project. Once I had the old radiator out, I realized I had access to everything else.
1972 GMC 1/2 Ton
Long Bed
350
Old 05-09-2020, 02:08 PM   #47
corndoggydogg
With body work complete and primer on, time to finally start with paint. This was my first test application to make sure the color is right (Summit Racing Coastal Blue).
1972 GMC 1/2 Ton
Long Bed
350
Old 05-09-2020, 02:17 PM   #48
corndoggydogg
Almost 2 years after stripping down to bare metal, repainting begins. Applied accent color to the cab first (Summit Racing Pure White). A few runs and some orange peel, turned out relatively well for my first time painting. Need to change some techniques and adjust gun settings, but ready to apply main color to cab as soon as the materials arrive.
1972 GMC 1/2 Ton
Long Bed
350
Old 05-17-2020, 09:41 PM   #49
corndoggydogg
Paint half done.
Old 05-18-2020, 12:23 AM   #50
cornerstone
cornerstone's Avatar
How do you feel about your results?
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
