Old 01-08-2015, 07:17 PM   #26
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: 6.0/4l80 first start
damn man, I never left the lights in too....I'm lazy, and thats a great idea.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 01-08-2015, 07:34 PM   #27
slowcpe
slowcpe's Avatar
Yeah I didn't do that. We took it off one piece of a time. I'm sure I'd prefer your method.
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 01-08-2015, 07:52 PM   #28
elimontfort
elimontfort's Avatar
Yeah I just couldn't pull it has one piece kinda hard when I'm working by myself. I really want to do another swap. It's kinda like getting addicted to boost. Once you felt it you only want to turbo everything afterwards.
elimontfort is offline   Reply With Quote
Old 01-09-2015, 09:21 AM   #29
Wasted Income
Boosted Member
Wasted Income's Avatar
Its really not that bad, IF you have a helper to muscle it off with you. Nothing a six pack of milwaukees finest can't fix.
Pull the bumper, loosen the core support mounts, remove the radiator hoses, remove the wiring bulkhead at the firewall, remove any oil cooler or trans cooler lines, remove the cowl to get to the fender bolts, remove 8 fender bolts (2 on cowl, 2 on middle of A-pillar, 2 at bottom of A-pillar, 2 bolting inner fender to firewall), lift it off, and go to work. Makes life much easier.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 01-09-2015, 09:27 AM   #30
elimontfort
Oh I know man. I wish I could have it just wasn't an option. I like your truck wasted! How do you like that intake?
Old 01-09-2015, 09:46 AM   #31
Wasted Income
Boosted Member
Thanks. I like it a lot.
Turbo diesel
Old 01-09-2015, 10:42 AM   #32
elimontfort
So I have a problem ive been trying to trouble shoot and Im pretty sure it in the ecm. my problem is the fans kick on at 208 like normal but they will not shut off. temp drops to about 187 and they stay on. if I leave the truck running and I pull the relays for the fan they die when I put them back in they come back on. If I shut the truck off and start it back up they stay off till the temp gets up to 208 again then they wont shut off. Each fan is wired independently with a 30 amp relay and 40 amp fuse and gets its own signal from the ECM.
Old 01-09-2015, 10:57 AM   #33
elimontfort
Here is how I have the fans wired up.
Old 01-09-2015, 11:06 AM   #34
slotard
What's the off temperature supposed to be on your relay? If it expects to get down to 180 or something, and can't, it won't turn off.
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 01-09-2015, 11:09 AM   #35
Wasted Income
Boosted Member
Yea, who did the tune? I'd check to see that the "off" temp in the tune didn't get fat fingered somehow.
Turbo diesel
Old 01-09-2015, 11:23 AM   #36
elimontfort
I sent an email today asking them what the off temp is I have no clue what it was set at. I"d assume it would be around 190 ish?
Old 01-09-2015, 12:15 PM   #37
Wasted Income
Boosted Member
Yes, typically it would be in that range. They will have to look at your specific flash file to rule that out as a cause.
It should also shut off when you go WOT. I can't remember if it will do it or not with the key on and the engine off, but you can try pressing the pedal to the floor with the engine off and see if the fan cuts off. That might help rule out relay problems.
Turbo diesel
Old 01-09-2015, 12:53 PM   #38
slotard
Why does it turn off at WOT?
1973 C20, 350/350
Old 01-09-2015, 02:47 PM   #39
Wasted Income
Boosted Member
Ugh, you'd think it was a monday, not a friday. Sorry, I was thinking AC compressor.
However, the fans may shut off at a certain vehicle speed.
Turbo diesel
Old 01-09-2015, 03:03 PM   #40
ls1nova71
ls1nova71's Avatar
The fans are supposed to turn off at about 40mph if I remember correctly. You could put the truck up on jack stands and run it and see if they go off. But my bet is also it's in the tune.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 01-20-2015, 10:16 PM   #41
elimontfort
So the shop who did the tune said its set at 200. I'm gonna check and see if the ECM is actually disconnecting the ground for the fans tomorrow.
Old 01-21-2015, 11:45 AM   #42
ls1nova71
ls1nova71's Avatar
Is the 200, on or off temp? Since the PCM supplies ground, and the way you describe it working, you're going to find it's the PCM that's keeping them on, if your wire from the PCM was shorted to ground, it would make the fans stay on, but they would be on all the time, even with the key off. Did you try running it down the road to see if they go off at speed?
Old 01-21-2015, 01:09 PM   #43
elimontfort
They are set to turn off at 200. I getting ready to take it down the road now to see if they shut off.
Old 01-21-2015, 01:10 PM   #44
elimontfort
And I agree with you ls1 that it's the PCM keeping them on. But the tuner swears it's set at 200.
Old 01-21-2015, 01:35 PM   #45
elimontfort
They are not going off at speed. Took it up to 70 still on.
Old 01-22-2015, 12:09 AM   #46
ls1nova71
ls1nova71's Avatar
Well I'm reasonably sure they are supposed to turn off at highway speeds. Do you have access to any kind of a scanner? Also, not sure if it will work or not, but if you unhook the temp sender it will make the PCM think it's -40*, and that should shut the fans off I would think, of course it will set a code and may force the fans on, not sure because I've never tried it, just thinking out loud. I'm still betting the off temp is set way too low, and isn't actually 200*.
Old 01-22-2015, 01:51 AM   #47
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
ls1nova - Mine failed fans OFF when I overuled the IAT in the process of switching to Speed Density. (solving this with a MAPT)
Old 01-22-2015, 03:23 AM   #48
ls1nova71
ls1nova71's Avatar
I was referring to the coolant temperature sensor. I wouldn't think the intake air temp sensor would affect it, thats odd.
Old 01-22-2015, 08:44 AM   #49
elimontfort
LS1 I have a scanner that's how I've been seeing my temps. It's shows live data and I can also freeze frame with it. When I get home I'll unplug the temp sensor. I'm also pulling my wiring out again and gonna triple check it.
Old 01-22-2015, 10:53 AM   #50
elimontfort
Unplugged the temp sensor still stays on. Motor stumbled but other than that nothing else.
