Old 02-19-2015, 12:26 PM   #26
Longhorn 70
Longhorn 70's Avatar
Re: Drop question? 1 inch down on left compared to the right ?
Originally Posted by NC_John View Post
wouldn't new springs eliminate that?
They should eliminate it.....do they for sure? That would depend on the springs. Mine were Moog brand and were only 5 years old. A new set in and baddabing, both sides equal.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 02-19-2015, 01:24 PM   #27
Fitz
Originally Posted by jbassC10 View Post
My left front side drop is about 1 inch roughly lower than the front right side.
I've measured this at different locations to make sure it was just a hair higher elevation in the parkin lot then or over there etc. ~Tyler
You might not have a problem. When I built my truck I dropped it 4 1/2 inches in front and 5 in the rear with ECE drop coils and spindles. The first set of pictures is front and rear when assembly was finished. The 'experts' here claimed I could not have used the parts I said I did because the gaps between fender arch and wheels were HUGE. The second pics are taken after 200 miles on the truck after the suspension settled in. Compare the gaps. I believe your suspension is in the same state. Drive it a bit and check it again. I don't think you have "chevy lean" with new springs. I think it just needs to settle some.
Fitz is offline   Reply With Quote
drop
