04-22-2015, 12:03 AM | #26 |
Re: What oil and oil filter are you high mileage guys using
267K - what ever the local chevy dealer uses, still running strong.
04-22-2015, 07:20 AM | #27 |
AC Delco filters and Castrol 5W-30 in my 2005 GMC Sierra. It now has 272,XXX miles on it and still going strong ! Previous truck was a 1995 GMC, ran the same oil and filter, when I gave it to my oldest son it had 365,XXX miles on it, the one before that was a 1984 Chevy Scottsdale C10, it had 280,XXX miles on it, cant remember what type of oil and filters I used back then though.
Can you see were I'm going with this ??? Regular old motor oil and regular changes is were its at ! Every 3000 miles and the motors will last a long time.
2016 Silverado2005 GMC Sierra 2002 Chevy Slverado Extra Cab (youngest sons) 2009 GMC Denali (oldest sons) 2015 Lexus 250i (wifes) 1972 Chevy C10 LWB, 5.3 / 4L60e swap "COLOR OF MONEY" http://www.louisianaclassictruckclub.com |
04-27-2015, 05:45 PM | #28 |
IT Guy/ Father/ Chevy lover
valvoline 5w30 high mileage and a bosch filter, the k&N one is nice in design but a pain to get off, So I went bosch. 288k on my 05 crew 5.3
78 Chevy (Pictures) SOLD 79 Chevy LWB (pasture) 83 Chevy LWB (crushed rusted beyond repair) 02 TrailBlazer SOLD 03 VW Passat wagonSOLD 95 extended cab silveradoSOLD (still in family) 05 Crew Cab Silverado 5.3 (The Turd) WTB: 66 El camino Technology Specialist aspiring to be a gear head. |
05-09-2015, 11:07 AM | #29 |
Registered Truck Offender
I run Mobile-1 in my fleet of work trucks (small fleet,, only 4) until they hit 150,000 then run Castrol GTX until they die (which has not happened yet @ 225,000)
Nothing but Wix or Napa gold (also wix) filters,, EVER on anything I own
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
02-03-2016, 03:24 PM | #30 |
Mechanic buddy of mine has a 2500 Suburban with a 6.0. He told me he was getting some lifter noise at cold idle (150,000 miles). He said he changed to Castrol syntec 10W30 and a quart of Lucas. No more noises and operates just like it should (now has over 200,000). I made the same swap in my 99 2500 with the 6.0 and got the same results. WIX filters!!!
choctawchevyclassics |
02-05-2016, 07:43 AM | #31 |
royal purple 5w30 wix filter
1971 K30 burb carbed LS6 th400 np205 d70f 14bff 4whl discs lifted 35 bfg's 1994 k3500 rcsb trophy truck ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's 1998 K3500 rclb ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's 1999 k3500 crewcab dually 4x4 496ci 4l85e bw4401 9.25ifs 14bff g80 6" lift 37 bfg's |
02-28-2016, 09:51 AM | #32 |
Rotella 15w40 with purolator filter. This a turboed 5.3 with 200k, running 17lbs boost!
02-28-2016, 01:15 PM | #33 |
I only use Mobil 1 or K&N filters. I also use Amsoil in everything I drive.
04-03-2016, 06:50 PM | #34 |
Does any one else have a problem with the wix filters leaking?
04-04-2016, 06:28 AM | #35 | |
Have you checked the mounting surface to make sure there isn't a crack or imperfection on the block?
04-05-2016, 02:52 AM | #36 |
I run Ams Oil Full Synthetic oil with the Ams Oil Ea0 oil filters in all my toys. If I can't find the Ea0 filter I run wix.
1969 Chevy c20(Miss Hackjob) |
04-07-2016, 10:31 PM | #37 |
My 2007 Suburban with aluminum 5.3 used 2-3 litres of oil from 42,000km to 190,000km
I work in a diesel repair shop and see 700-900,000 km on Duramax and Cummins... I asked "how come"? My boss says 15W40 Shell and a fuel filter eveytime.. I switched my Burb to reg 5W30 Dyno oil and always use Wix filters I am not kidding, the Burb at 235,000km now uses 1/2 liter per 5000km now Never was a ticker We just bought a 2006 5.3 L33 Z71 cab 1/2 from wind generator construction company 451,000km on it it been ticking a left side lifter for 2 weeks Dropped the oil today and added 15 W40 Shell and no more noise Just saying |
04-16-2016, 06:26 PM | #38 |
I never had the problem on any of my vehicles until i switched to the wix.It could be that I may not be getting them tight enough.That is one good thing about the fram is the grip they put on the filter.
04-18-2016, 09:07 PM | #39 |
I only have 80K on my 2006 WT 4wd 4.8 engine but I use what NAPA has on sale 5-30 non-synthetic and always an AC Delco filter. I change oil every 5000 miles.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T |
05-13-2016, 10:02 PM | #40 |
01 Tahoe. 230k Mobil 1 full synthetic and mobil 1 filter.
http://67-72chevytrucks.com/vboard/s...25#post7532025 71 Cheyenne K10. 283/Th350/NP205. 3.07s non posi. 31x10.5 Bighorns.L31 350 Vortec swap in progress. 79 Suburban K20. 350/350. 6" lift. 35x12.5 Toyos. 93 Burb K1500. 350/4l60e Parting out. 2001 Tahoe LT, 5.3, autoride, 265/75s, leather, loaded, family hauler, 243k miles! |
06-26-2016, 12:08 PM | #41 |
Valvoline MaxLife 5w30 and Wix filters when the the dash tells me to.
125k on my 2003 8.1. Has always used a little oil... I just keep it full. |
06-26-2016, 12:42 PM | #42 | |
I run castrol high mileage or kendal high mileage 5w30 , either a puratolor, carquest or napa gold filter
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
06-30-2016, 03:00 PM | #43 |
Valvoline 5w30 High Mileage usually with a Napa Gold but have run an AC Delco from time to time in a pinch.
Wallmart is by far the cheapest place to buy the Valvoline High Mileage by nearly $10 sometimes for a 5 quart jug. |
07-07-2016, 12:25 AM | #44 |
Chevys Kick A$$
Almost 205k on my '95 I have always used 10-30 high mileage synthetic blend every 3k miles or so with a WIX filter. Little lifter noise and a tired old 5.7 burns some oil and leaks a bit but still runs good when it needs to get used.
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER I would rather push a Chevy then drive a ford!!
07-07-2016, 10:45 PM | #45 |
The Mobil 1 filter is quite tall compared to most. I prefer that one over all others.
2001 Silverado 1500, with a 325 Vortex motor, 4x4, with over 213,000 miles and countless hours of idling. |
07-08-2016, 11:54 PM | #46 |
Basic valvoline oil or high mileage version (factory weight recommendations)with usually a fram high mileage filter. Change every $5k miles. Many don't like Fram, but I have never had a problem....
1995 GMC 4x4 1/2 ton 1999 Jeep Wrangler w/ 33's 68 camaro 350/350 1987 Chevy 3/4 ton 4x4 Suzuki DRZ 400s Dual Sport 1971 chevy long bed 2x4 194? Dodge 2.5 ton 1980 Chevy Cheyenne 4x4 1/2 ton I6/sm455 1989 Chevy V30 crewcab dually 454/TH400 |
07-17-2016, 02:38 PM | #47 |
A final note about filters used on my 2001 Silverado 5.3 litters Vortex motor: I bought a NAPA oil filter and then realized how short this filter is compared to a Mobil 1 filter, so I didn't use it and saved it as a backup filter in case I have to use it someday. Tall filters like the Mobil 1 and a couple of others are much easier to install and remove, because sometimes you can just grab it with your hands and spin it few turns. With a short filter, most times I have to use a wrench to remove or install it.
01-25-2020, 07:05 PM | #48 | |
01-25-2020, 07:45 PM | #49 |
Moderator
5W30 Synthetic with WIX or NAPA Gold filters.
Stay away from the oiled cotton air filters... Change the air filter at least every 20K with the Stock K47 (hi capacity) AC Delco A1618C paper element. It has deeper pleats than the standard cap filters and it fits in the standard capacity air filter box.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 01-25-2020 at 07:56 PM. |
01-26-2020, 08:54 AM | #50 |
Castrol high mileage, normally 10W40W and WIX filters.
