Old 04-25-2015, 09:57 AM   #26
Marty68
Re: Another way to skin the cat; the High Torque 292 LS swap
awesome.you need to look at it a while to see what it really is.
Marty68 is offline   Reply With Quote
Old 04-25-2015, 10:36 AM   #27
dayj1
Re: Finished Product
Originally Posted by Beetle View Post
This. This right here has me motivated to want to do this to mine. So how do I make an adapter for the carb'd intake to accept the throttle body? Is it OK I clone yours? It looks damn good, just wish there was a way to hide the fuel rails
One more question. What radiator did you use? I seen you covered it when you talked about the fans but I was wondering what you did about the steam port. I am researching LS swaps and I keep seeing "steam port" come up. Dunno what it is but seems you gotta have it.
Sure, clone away! The TB adapter was water jetted from 1/2 aluminum plate. The outside is shaped exactly like a square bore carb gasket and the inside has a 75mm hole.
The radiator is a stock 4 core '72 C10. I just had the nipple for the heater outlet brazed shut. My steam line runs from the pipe between the heads to the back of the waterpump. You can see it fairly well in this photo. It's just a rubber hose.
dayj1 is offline   Reply With Quote
Old 04-25-2015, 10:37 AM   #28
dayj1
Thanks for all the compliments!
Old 04-25-2015, 11:43 AM   #29
dec010974
dec010974's Avatar
dayj1, what are the part numbers for the holley intake and fuel rails? I have the holley LSx dual plane intake.
dec010974 is offline   Reply With Quote
Old 04-25-2015, 12:09 PM   #30
Houston Ben
Houston Ben's Avatar
All I can say is...WOW!!! Would you come to Texas and rebuild mine?? lol!
Houston Ben is offline   Reply With Quote
Old 04-25-2015, 12:17 PM   #31
whitels1
whitels1's Avatar
Great Job! I dig the old school valve covers and the air filter/housing set up.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 04-25-2015, 11:41 PM   #32
dayj1
300-137 for the intake and 534-219 for the rails.
Thanks!
Old 04-25-2015, 11:55 PM   #33
Beetle
Beetle's Avatar
Know of any place that sells a carb to tb adapter? My google-fu sucks, and I don't know of anyone with a waterjet
Jason
TEAM C10 HOT ROD POWER TOUR
689 Short Step
68 Step
Trucks Sold: 70 GMC, 72 K5
Members met: Andy4639 GCncsuHD CSGAS zicc1835 hotrod farm truck Mingrao Bhelton brenthiggins
Beetle is offline   Reply With Quote
Old 04-25-2015, 11:58 PM   #34
GMC-YA68
GMC-YA68's Avatar
sounds like DAYJ1's buddy with the waterjet may be able to make some side cash if he wants to mass produce a batch of those intake to MAF plates! I dig the setup. Wouldn't have ever crossed my mind to do it that way. Great work and ideas.
-Keegan-
'72 Jimmy 4x4 - 5.3/4L65E/NP205 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=663780
GMC-YA68 is offline   Reply With Quote
Old 04-26-2015, 12:06 AM   #35
Beetle
Beetle's Avatar
I would buy one! No joke
Jason
689 Short Step
68 Step
Old 04-26-2015, 09:13 AM   #36
dec010974
dec010974's Avatar
I would buy one also.
Old 04-26-2015, 11:26 AM   #37
Zane M
Amazing!
Thanks for sharing.
Zane M is offline   Reply With Quote
Old 04-26-2015, 12:28 PM   #38
dec010974
dec010974's Avatar
Just an idea. Combine the carb spacer with the throttle body adapter and you can this set up as dayj1. It may be a little taller but I'm sure you get idea. I don't own a water jet either, but there is more than 1 way to skin a cat. Since both pieces are aluminum your nearest tig welder can do the job. I estimate dayj1 piece can be duplicated for less that a $100.00. Or dayj1 can Sell them for less. "I'm just say in".
Old 04-26-2015, 10:51 PM   #39
dayj1
I sent a message to the guy that cut mine to see if he has any interest in making more. I'll post an update here when I find out something. I can't sell on this board as I don't have a premium membership. So, I don't want to make this a for sale thread and get it closed.
When I was researching my build, I thought of several possibilities in addition to the one that was just posted.
The most options are available for drive by cable. You could remove the injector pod from a GM TBI throttle body from a 4.3L, 5.7L, or 454. There are lots of inexpensive adapters out there that will allow one of those to bolt up to a square bore intake. They wouldn't require an adapter for a breather and they already have an IAC and a TPS sensor. Another option is to just run a carb. As long as you didn't hook up fuel to it, it will only meter air. It wouldn't require adapters of any kind and there are kits out there to add the TPS sensor.
For DBW, the Gen 4 guys have this: http://www.ebay.com/itm/121522882229...S:1123&vxp=mtr For Gen 3 you'd have to run the adapter above and a 3 to 4 bolt adapter.
Old 04-27-2015, 10:42 AM   #40
mattcrp1
mattcrp1's Avatar
Nice work. Looks factory.
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
Old 04-27-2015, 11:06 AM   #41
ls1nova71
ls1nova71's Avatar
Wow, Jonathan, this looks awesome! I assume this is what you need the cruise lever for? I haven't forgotten about it, just been really busy but will get it done, I promise. Couple of questions though, first, is the pump really loud in the tank in the cab? I had a buddy who put a pump in the stock opening and it worked, but he hated the noise. Second, how did you get the speedometer to work with the original face? I assume it's pretty close to accurate, but the odometer is off?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 04-27-2015, 11:20 AM   #42
mattcrp1
mattcrp1's Avatar
Quick question for the spedo swap guys, will that s10 set up work with a '76 type dash/cluster?
IG mattcrp1
Old 04-27-2015, 11:27 AM   #43
Matt Cramer
Nice work! My project has a lot of similar elements - 4.8, in tank pump, 2010 Camaro manifolds - but the fabrication work on mine isn't nearly as good, and right now it's still using the ugly truck manifold. Given me a bit to think about...
Matt Cramer
1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD
4.8 LS build thread
Matt Cramer is offline   Reply With Quote
Old 04-27-2015, 04:13 PM   #44
dayj1
Originally Posted by Matt Cramer View Post
Nice work!
Thanks!
Thanks, Eric! And, yes, this truck is why I need another cruise lever.
On the tank, the jury is still out. I bought a real Delco EP381 pump from Rock Auto instead of one of the cheapo "gray market" ones on eBay in hopes that a genuine Delco pump would be the quietest available pump. I also put rubber pads between the tank and the cab at all mounting bolts. It's about 1/4" thick rubber from the ends of the radiator hoses that I cut up to fit my engine. At first it was annoyingly loud. I have enough dynamat to cover the front and back of the tank but I only put it on the front for now. That got it tolerable where it really only bothers me at idle when there is no road noise. I'd say that cut the noise in half and it's really at the point now that I will probably be happy with it when I get the radio working. Long term, I plan on some interior updates. At that time, I'll dynamat the back of the tank and put some rubber/foam between the bottom of the tank and the cab. I'll also cover the tank with a carpet kit. I think those two things will get it where I want to be noise wise.
On the speedo I took a slightly "one-off" approach. A '94 S10/Sonoma cluster is a one year only deal. It's 85 MPH instead of the 120 MPH of the later S10 speedos but the mechanics are the same as far as how the mount, etc. The S10 sweep is less than the C10 (just like the later speedo) and when you add the extra sweep of the C10 back in, the 85 MPH S10 speedo works out to 100 MPH. I had to modify the odometer to 6 digits and it took a fair bit of work to fit it to the factory face. It works, but your kits certainly make it an easier proposition to go your way
The best I can say is "maybe". I think you would have to re-number the face to match the S10 sweep similar to Eric's kits for the 67-72. The easiest fix for a squarebody is to get an electric speedo out of a squarebody suburban.
Old 04-27-2015, 06:18 PM   #45
dec010974
dec010974's Avatar
And here is is with everything in place (including the wiring) and I've put about 200 miles on it this week. It's running great.
I read the information on the single pane intake, from Holley's website. Holley claims that the operating rpm range the Holley 300-137 is from 2500-7000. the dual plane intake rpm range is 1500-6500. How does this affect drivability? since my current setup is LQ4, FI, what is your opinion?
Old 04-27-2015, 09:07 PM   #46
dayj1
The dual plane is Holley part #300-130, right? If so, it doesn't have any bosses for injectors. The intake runners are at different heights, so it would be pretty difficult to go MPFI with that intake. GM does make part #19244037, but it's the better part of $500 and I think it is for rectangle port heads.
With that said, Holley does say the single plane intake (300-137) is for 2500-7000 RPM and they also say it is for displacements of 5.3L and up (not a problem for you, but I have a 4.8). I was worried about 2 things with my setup; 1) The MAF being so close to the TB and 2) The single plane intake. In my case, neither one seems to have made any difference. The 4.8 in my '72 is running a bone stock tune except that the rear o2s, evap, and vats are disabled. It runs and acts just like the 4.8 in my daily driver 2012 Silverado.
Old 04-27-2015, 09:33 PM   #47
clinebarger
I bought one of those 4-bolt to 3-bolt adaptors, I have no idea what AssHat came up with that, But you will have a major Vacuum leak using it the way it is on stock throttle bodies.
You either need to have it machined for a Stock O-ring gasket or get a aftermarket paper gasket.
clinebarger is offline   Reply With Quote
Old 04-27-2015, 10:15 PM   #48
Ozzy2013
Ozzy2013's Avatar
Awesome job !
Ozzy2013 is offline   Reply With Quote
Old 04-27-2015, 11:18 PM   #49
dec010974
dec010974's Avatar
Wow, unbelievable! so basically you have a bone, stock tune on your pcm? So once I send my pcm out to be reflashed (remove vats, rear o2 sensors), get it back, and set it up, I should be good to go? I thought you may have used a local tuner to calibrate the fuel trims, engine idle, drive tune it, and a few other parameters, needed to make this puppy idle/run/shift smoothly. what injectors did you use with the holley fuel rails 534-219? thanks for the info. dayj1 for president.
clinebarger I will always use gaskets. metal to metal fastening will always need gaskets. I learned that many times, lesson a long time ago.
Old 04-27-2015, 11:52 PM   #50
ls1nova71
ls1nova71's Avatar
I have a couple of those 85mph speedos, but when I tried it, I couldn't get to be as accurate as the 120mph ones. But to be honest, I didn't spend a whole lot of time on it. Looks good though!
