09-26-2015, 09:22 AM | #26 |
Re: 68 sb, 283 vs 4.8 ls
I've put over 6,000 miles on my 5.3/4L80E (and a turbo!) setup this summer.
Be warned, if you LS swap, your gonna drive the wheels off the thing. That's what always happens. Get a proper tune done on the engine too; the crisp throttle response, gains at all RPM, and smooth power delivery are great. The old small blocks were great, but there's just better stuff available to the backyard hot rodder now. Have fun and good luck.
1970 C10 Turbo LM7 5.3/LS6 cam PT7675/4L80E/Holley Dominator EFI/E85 Moser 9" 3.25/4 wheel discs 11.16@121.07 |
09-26-2015, 09:34 AM | #27 |
Quick Time makes a bellhousing to put a Muncie behind an LS. here's the link to it at Summit: http://m.summitracing.com/search?keyword=Rm6036
Definitely go LS, especially if you plan on road tripping it. The efficiency of the fuel injection combined with the cylinder head design just can't be beat. The 4.8 is a really under appreciated engine also so they can be had for pretty cheap. They have a near perfect rod/stroke ratio and share the block with the 5.3 so if you ever feel you need the extra displacement it's an easy fix. Good luck!
1971 Chevy Custom Camper/20, Hugger Orange with White Top 31,000 original miles (when purchased), 402, TH400, PS, PB, AC As of May 2017 it now has a turbo LS in it! (Still looks stock though) |
09-26-2015, 03:48 PM | #28 |
Mine is to much of an original rust bucket to LS'it .If I had a mismatched truck then yes it would be a smart thing to do.Save your parts you take off!!! Somebody here might need them.
It builds on my intelligence when I make a mistake, Boy am I building on it! '67 C-10,'70 Nova SS |
09-27-2015, 03:24 PM | #29 |
still think the older 283/327 carb/point engines are better less chance of breakdowns,simple to work on,i have one over 55 years old never been touched since new runs great,will a newer engine still run 55+ years from now? had a big car 67 caprice 283 car was ready to go at 90 mph,could cruise that big car at 110 miles on in without over heating,very snapy engine,build/change whatever you want but always the 293/327 is chevys best sbc ever made, {my option}
09-27-2015, 08:30 PM | #30 |
Go LS, you will never look back. No throttle pumping or choke pulling. No cold start issues, great reliability, good power and good fuel mileage. It's the best thing I've done on my truck.
09-27-2015, 08:38 PM | #31 |
Alot of us like old skool, and alot of us like the modern setups. the choice is ALL yours as it was with the rest of us. There's plus and minus with both, its a hobby we all enjoy and have something in common with. I'm old skool, (yea, I enjoy pumping the gas on those cold starts just to keep it running, but enjoy it, its what I grew up with). but I do enjoy seeing those new fangled engines in our trucks also. It makes it fun. You have alot of opinions now, Just go in the direction thats deep down in your gut and feel good about it....
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
09-28-2015, 08:09 AM | #32 | |
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
09-28-2015, 09:13 AM | #33 | |
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
09-28-2015, 10:44 AM | #34 |
I think the 2 sides have very good points but I also think if this was a voting thread the LS would win by a landslide.
And if the only way you could vote was if you had actually owned a sbc & an LSX swap LSX would win 100 to 0. IMO |
09-28-2015, 01:32 PM | #35 |
Personally, I'd probably go with the 283. It's simple, and not nearly as much work to install. And well tuned 283 should run fine for a long time. If you do go that route, make sure to find somebody that knows what they're doing when it comes to tuning. Carburetor tuning is becoming a lost art.
Newer, more modern engines can still have problems as well. I see lots of leaks on cars that are less than 10 years old. I also see quite a few newer cars that burn a lot of oil. I think it would surprise most people to find out how many "reliable cars" aren't nearly as reliable as the general public thinks. |
09-28-2015, 03:28 PM | #36 | |
Coil on plug ignition accurate to within a tenth of a degree Gerotor oil pump mounted on crank snout Low tension rings Lightweight valvetrain Stable cylinder block and bottom end Optimum rod/stroke ratio Hollow, lightweight camshaft Greatly improved thermal efficiency (cool em with a heater core!) Accurate fueling Injector targeted directly at back of intake valve And more I'm forgetting. The biggest myth in hot rodding is "LS" engines make all the power in their heads.
