Old 03-17-2016, 07:59 AM   #26
burnin oil
Re: 4l80e+GV or NV4500+GV
There is nothing new about a GV other than the adapters offered. They are an old design borrowed from Europe. I cant remember the letter series but research lyshum (sp) over drive and you will find what I am talking about. From memory it was a 70s Volvo or Jaguar J or P type OD unit. Fairly common across the pond. Supposedly the original GV units still had the Lyshum tag on it. Spend some time on Google researching before dropping your coin. Has someone else said don't back up using it and the GV locks it out in lower gears. Not to back into the automatic part of the thread but the GV has a similar setup in it and will cook itself at low speed/RPMs.
burnin oil is offline   Reply With Quote
Old 03-17-2016, 09:48 AM   #27
I don't know anything about trucks other than what I have encountered personally, through sharing experiences with others, as well as what the old farts taught me. I'm learning here now, as well, with no plans to stop.
"I've got gut feeling judgement based on seat of the pants technology acquired through experience and observation of the Real World test track"
Old 03-17-2016, 11:10 AM   #28
burnin oil
I messed up the company name. Lysholm was super charger company and Laycock made the OD units. Happy googling.
Old 03-17-2016, 01:24 PM   #29
Thanos
Thanos's Avatar
It has on and off switch as well...
Thanos is offline   Reply With Quote
Old 03-17-2016, 09:57 PM   #30
Thanos
Thanos's Avatar
Honestly 450ftlbs is not all that much unless you drive a Honda 99% of the time.
LMAO I didn't realize you posted this **** till somebody pointed it out and was laughing.
My 95 Dodge diesel made 440 ftlbs at 1600 rpm and a whopping 175HP. That thing was a turd stock. Look at the new diesels with warranties pushing 900ftlbs with a warranty! I am also the guy who uses granny gear in a transmission every single day and cannot think of having a truck without it. I run a pretty wild motor in the truck and do anything I want with it when I want. One of these days it will get a NV4500 but until then it gets the job done with the factory 4spd. Last month I hauled 75 tons of gravel with my 5500. The average load was 5 tons. I wouldn't even have tried it using double over but I sure enjoyed having 1000ftlbs of torque and the under drive gear in the auxillary transmission.
Also why are you so obsessed on comparing diesels to gas engines??????????
Like comparing apples to oranges, this is a classic truck not a duramax or cummins. The very frame on these old trucks cannot handle a max output of one of todays diesels...
Oh man we got some laughs out of this gem thanks!
Old 03-18-2016, 07:27 AM   #31
burnin oil
I drive both not to mention that you asked about a transmission whose main application was behind diesels. There is also a diesel swap section on this board with a ton of guys running mostly Cummins swapped into our trucks. So with that in mind my statement stays the same that 450 ftlbs really is not a lot of power. I personally put double that through a NV4500 for years. Not to mention you are the one who talked about towing so I just threw in my personnel experience. Most of what I know about GV came from the diesel world. Look at my screen name and you should be able to figure out my fascination with diesels even though I still enjoy 7k RPM shifts of a gasser. Yes my daily driver does that and has for the last few years.
Old 03-18-2016, 08:18 AM   #32
And diesel is also a great degreaser. Am I still being relevant?
Old 03-18-2016, 09:30 AM   #33
Thanos
Thanos's Avatar
I can't take any of your posts serious. Moving on...
Old 03-18-2016, 09:36 AM   #34
burnin oil
Yes because we can clean the transmission prior to rebuild.
Old 03-18-2016, 10:04 AM   #35
Aruba1
I like changing gears, the first car I learned to drive was a stick, I like driving my 72 (5.3L, 4:10, 1996 NV-4500) but I 90% of the time (when I am not towing anything) I wish I had put an automatic instead.
Aruba1 is offline   Reply With Quote
