Old 01-09-2018, 10:45 PM   #26
Evldoer
Re: Gen V Engine swap info
Originally Posted by Clyde65 View Post
What have y’all used to connect to the fuel rail??
Fuel line connectoin is the same as the ls engines.
If you are using braided AN line get one of these to connect to the fuel line on the engine
https://www.speedwaymotors.com/LS1-L...lue,59475.html
Evldoer is offline   Reply With Quote
Old 01-10-2018, 09:49 PM   #27
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I tried one of those, too small. I just ordered a 3/8x-06an so we will see if that works.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-10-2018, 10:38 PM   #28
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
Yep, 3/8 is the one you want.
Clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 01-11-2018, 08:16 PM   #29
Clyde65
Clyde65's Avatar
That’s what worked. ThanksClint!!
What rad hoses are y’all using? I’m running a champion radiator so 1-1/2” top and 1-3/4 lower.
Also, what about MAF sensor? Cold air intake??
Clyde65
Rebuild of Clyde
support our troops!
Old 01-11-2018, 08:50 PM   #30
Evldoer
My bad for the wrong link for the fuel line connector. I edited that post for a 3/8" connector.
I ordered the gm factory hoses and radiator for a 2015 silverado. This means i will need to run the coolant tank also because the gm radiator does not have a fill cap. They are cheap.
Old 01-12-2018, 09:23 PM   #31
Clyde65
Clyde65's Avatar
That’s cool E!
The stock Rad won’t fit, too wide for me. Jags that run has a coupling with a rad cap housing in it if that’s something you need.
Clyde65
Rebuild of Clyde
support our troops!
Old 01-13-2018, 11:54 PM   #32
87chevy.com
Stock 454 rad, amazon coupler, think it was the 36mm. 32 fit loose, 34mm was ok, 36 felt like you had to wrestle it on.. so went with that one. 2 hoses spiced, lower stock ls truck
http://67-72chevytrucks.com/vboard/s...&postcount=171
Clint
Old 01-14-2018, 09:58 AM   #33
Clyde65
Clyde65's Avatar
I have a Champion, 1-3/4 in on both.
Also, did you say upper is f-body?
I have a reducer 1-1/2 to 1-3/4.
Thanks!!
Clyde65
Rebuild of Clyde
support our troops!
Old 01-14-2018, 12:20 PM   #34
87chevy.com
Thanks!!
One was an body and another was the same size but with a 90 and a length of strait... 2 fbody ones should work out the same
Clint
Old 01-14-2018, 12:33 PM   #35
Clyde65
Clyde65's Avatar
These do not have steam ports correct? I’m not where the truck is so...
Clyde65
Rebuild of Clyde
support our troops!
Old 01-14-2018, 07:51 PM   #36
Evldoer
Here are some pics of a 2wd 78 c10 using the 2014 silverado radiator, coolant recovery tank and radiator hoses. I trimmed some off the upper hose for a near perfect fit.
Prices from Rock Auto
Radiator. 100$
Coolant tank 37$
Lower radiator hose 48$
Upper radiator hose 17$
Obviously this is not a bolt in modification, there will be some fab work to do but everything fits great
Old 01-14-2018, 07:56 PM   #37
Evldoer
If you plan on getting rid of the vacuum pump on your gen 5 there are 2 oil supply/return ports that need to be plugged. From the GM dealer the part number is
11546665 for the oil plug.
Sold individually. You will need 2
Old 01-21-2018, 12:00 AM   #38
Clyde65
Clyde65's Avatar
Any ideas on cruise control on this swap???
Clyde65
Rebuild of Clyde
support our troops!
Old 01-21-2018, 10:47 AM   #39
Evldoer
I need to call Motech and get some info on their miscle car module. If that does not turn out i have another idea in the works but dont want to share much until I can make it work.
How far are you into your swap?
Old 01-21-2018, 12:05 PM   #40
Clyde65
Clyde65's Avatar
I’m almost at start up. Everything is on and I’m working on MAF sensor,CAI, exhaust.
I’ve heard that Dakota Digital and Rostra are the only options since cruise was handled by the BMC stock...I don’t have a BCM on my harness.
Please do let me know, it’s not a necessity but a nice to have!!
Clyde65
Rebuild of Clyde
support our troops!
Old 01-21-2018, 01:10 PM   #41
Evldoer
Sounds like you are farther along than i am. Did you have the vats removed from your ecm yet? If so did you send it out or have someone local take care of it. I still need this done.
Old 01-21-2018, 08:45 PM   #42
Clyde65
Clyde65's Avatar
I sent it out....there wasn’t anyone close that was experienced with the L83/86 PCM reprogram.
Clyde65
Rebuild of Clyde
support our troops!
Old 01-23-2018, 03:45 PM   #43
Marine15Z28
How did you bolt on the power steering pump, idler etc...Thanks
Marine15Z28 is offline   Reply With Quote
Old 01-23-2018, 04:18 PM   #44
87chevy.com
http://67-72chevytrucks.com/vboard/s...2&postcount=18
Custom bracket
Old 01-24-2018, 11:07 PM   #45
vannatta20
vannatta20's Avatar
Here is Motechs power steering mount adapter. Uses a 2012 Jeep wrangler pump. Also is a view of their standalone harness with ECU/Bussman mount
vannatta20 is offline   Reply With Quote
Old 02-04-2018, 02:43 PM   #46
vannatta20
vannatta20's Avatar
Billet ac adapter to convert the ac compressor to standard fittings
Old 02-04-2018, 04:50 PM   #47
Marine15Z28
Nice, how much. The Motech PS solution is good but I still rather have it on the driver side tho. Who modified the stock harnesses for L83 swaps?
Old 02-04-2018, 06:28 PM   #48
vannatta20
vannatta20's Avatar
I think its 80$ for the billet adapter. I modify harnesses and do programming if anyone needs it done.
Old 02-04-2018, 11:31 PM   #49
Izzeren
What engine mounts are you guys using? I have a 74' C10 and currently have the Dirty Dingo mounts. The problem is you have to move the AC and delete the vacum pump for the mounts to fit in the engine correctly which leaves the issue of brackets to mount the AC unit in top of getting a bracket for the power steering. They do make those brakets, but spending $600 in brackets alone in top of replacing the AC unit with a different one along with a different water pump is a bit pricey. If that is the route I need to go so be it I will bite the bullet but would like to see what other options are out there.
If I read this correctly you do not need the BCM for cruise and tap shift correct? If that is the case what do you have to do?
Also if you are using those mounts what are you doing for headers?
Any other information is greatly appreciated. We are just getting back started and have yet to set the engine in the truck yet for our 1st test fit.
Sorry guess I should mention it is a 2016 L83 with 6l80e trans.
Izzeren is offline   Reply With Quote
Old 02-04-2018, 11:39 PM   #50
87chevy.com
Does that fit the jeep swap, or the 73-87 squares?
Almost positive it wouldn't fit a square body.
I modified the stock hose ends. Close but clearance is there.
Clint
