Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 02-11-2018, 09:47 PM   #26
steven03
Re: Longbed driveshafts
Originally Posted by cruizin01 View Post
Fit the new 4" steel shaft up this week. It was pretty light, almost seemed like aluminum but wasn't. Im happy with it for $250. They were able to use the stock yoke from the 4l80e and the small'ish 1310 rear joint. Should be fine for my setup. I wont know for a little while till I get it on the road though.
Good to hear! 250 sounds like a good price. 4" shaft fit through the factory cross member okay?
steven03 is offline   Reply With Quote
Old 02-11-2018, 09:57 PM   #27
cruizin01
I guess Im not sure which crossmember you're referring to.
dont mind the mufflers. Im replacing the other and have to have my crossover pipe rebuilt.
cruizin01 is offline   Reply With Quote
Old 02-20-2018, 01:28 AM   #28
steven03
Didn't realize you were on a different rear suspension, I thought you were on a trailing arm set up like on my 65'. This is the cross member i was referring to ....edit, not my truck just a pic found off google
Old 10-04-2018, 11:10 AM   #29
71Dragtruck
71Dragtruck's Avatar
Well bumping this thread up for the tumble weeds to blow through LOL.
Anyway I'm changing my setup again and will be playing the driveshaft game late in the spring but have already been doing up some research as I knew it was going to be a run around.
New motor will be in the honest 1200hp range N/A, plus will still have my nitrous on it for play if I want, good for up to 200 shot but setting up to run mostly N/A. Going to a SFI case turbo 400 but going to give a long stock tail housing a try to get my driveshaft length down, only downside to that is will have to run a bushing instead of a roller bearing.
I'm thinking that it should run high 8's on motor, going to put in a 4.57 rear gear, and current tires are 32.3" tall, next set will be 33" both listed with a 102" roll out. Motor will spin 8000, if need be, builder figures a guy will be shifting 7800, with convertor slippage and such and a big safety margin I'd say using 7800rpm for critical speed of the driveshaft through the traps should be more than good as doubt I'll ever see close to that unless I drop rear gearing more yet, right now calculating that center to center on the shaft should be ~ 65".
With all that the calls began, all choices and options point to a CF with only one shop claiming a 5" aluminum would work, most CF shaft makers either can't do a 5" or can only handle a 60-61" max tube length. Still waiting on a couple calls/emails back from one place that initially thinks from past projects they could get it done with a 4" CF but are now doing military contracts and won't change tooling for a one off at this point in time, but late spring could be different.
Anyway I look at it unless the 5" aluminum that one place claims would spin 8000 (sounds high to me and the one calculator I found online, do believe it was DOM .125" tubing), will work, I'll be stuck with a custom 5" CF that is rated 8551rpm, with a nice price tag of ~ $2025 plus trans yoke and shipping.
To be continued...…...
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 10-16-2018, 11:29 AM   #30
'65 chevy lover
Two piece driveshaft with HD carrier bearing and 1350 ujoints.
'65 chevy lover is offline   Reply With Quote
Old 12-07-2018, 06:33 PM   #31
nxtruck
nxtruck's Avatar
Wow! It sounds like you're stepping things up quite a bit. Glad to hear that. That should be a lot of fun!
I'm wondering if a custom 2-piece could be built to live behind that combo. I know it adds a couple more possible breakage points, but, if everything is sized correctly, I wonder if that might be a little easier on the wallet. A 2-piece is definitely a bigger pain to work with, but might be a more affordable option.
Again, just throwing an idea out there. Good luck with it, whichever way you go with it.
Chris
1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas
7.02 @ 95.8, 1.45 60'
1965 Chevy C10 LWB, 355 sbc, TH350, daily driver
nxtruck is offline   Reply With Quote
Old 12-07-2018, 10:43 PM   #32
71Dragtruck
I already had my chassis guy modify my loop and 4-link crossmember to a fit a 5” carbon fiber shaft. I know price is high, but they are way lighter and a lot easier on the center section and trans if the shaft ever does let go, both of which are pricey too, not to mention risk of coming through back of the cab.
A tougher 2 piece would definitely be a option, farm truck runs one, and I have one now that could be built tougher, but I’m going to bite the bullet and go carbon fiber. Guess we will see if it is a wise investment or not.
Sponsored by:
Hard Candy Customs
Old 12-11-2018, 03:49 PM   #33
nxtruck
nxtruck's Avatar
You make some good points about the safety aspect of a hd 2-piece. I hadn't thought about the front shaft wacking the back of the cab in the event of breakage in that area. I did install another d.s. loop just behind the trailing arm crossmember for the front of the rear shaft, but that would only contain the front of that shaft in the event of a failure. A 1-piece would definitely eliminate those particular issues. Along with the added bonus of less weight.
Chris
Old 01-07-2019, 12:13 AM   #34
82C10step
There are driveshaft length and diameter formulas on the web. Use them. I was uneducated about driveshafts years ago and found out what critical rpm means on a driveshaft. It cost me a full exhaust and a TH350. Split the trans from front to back. And made a lot of noise at over 120.
82C10step is offline   Reply With Quote
