03-27-2018, 12:21 PM | #26 |
Re: F/S OE 72 Big Block Parts, Brackets, Stove Pipe, Air Cleaner, Towers and/or Reque
03-27-2018, 05:00 PM | #27 |
Always on the hunt...
We can get the 72 BBC P/S setup with both mounting brackets, pump pulley, and remote fill reservoir w/hose to you in CA. 93436 for $23.61 shipped via FedEx ground, total transit time will be 2 days. The provided address is a commercial/business listing correct? A non-residential/commercial address was used for the above quote and it does affect the shipping charge when using FedEx. Will return our info now for sending payment via paypal. Thanks, Mel
03-27-2018, 06:18 PM | #28 |
We can get the above requested BBC parts to you in MI. 48451 for $39.55 shipped via FedEx home delivery/Res. (23" x 20" x 7" @ 12 Lbs.), total transit time will be 4 business days. Will fwd the info now for sending payment via paypal. Thanks, Mel
03-28-2018, 07:58 PM | #29 |
Greg, the 72 BBC alternator 3 pc. bracket setup is under way, your package went out USPS priority on Wed. 03/28 and the projected delivery date listed on the postal receipt is Fri. 03/30. Thanks again, Mel
03-28-2018, 08:19 PM | #30 |
The BBC power steering setup shipped out via FedEx on Wed. 03/28, as of this evening the FedEx website is projecting that you should see the box on Fri. 03/30 by the end of the day. We had to swap out the lower pump cradle bracket because the one that was originally pictured (installed on truck yet) was cracked and was being held together while everything was tight, once I loosened the bolts up to remove the setup the broken ear fell off, see red arrow. I sent the top pictured OE BBC p/s lower cradle bracket in its place. Thanks again, Mel
03-28-2018, 11:12 PM | #31 |
Your box has been shipped out via FedEx on Wed. 03/28, as of this evening the FedEx website is projecting that you should see the box next Tue. 04/03 by the end of the day. Thanks again, Mel
03-29-2018, 01:28 AM | #32 |
Nic, here is that last requested piece to your big block parts lot, OE big block fan shrouds in this condition are getting a bit tougher to find these days. $150 on the shroud and add $20. more for combined shipment with the already paid for big block air cleaner & riser setup packed inside larger box w/shroud. Let us know if its a go and we can have all of it packed up and headed your way tomorrow. Mel
03-29-2018, 07:57 AM | #33 |
03-29-2018, 04:53 PM | #34 |
It's a no go on the big block bracket mounting hardware alone, could possibly be an option if you were purchasing the complete bracket setups and as they were being pulled off of the donor truck all specific hardware could be bagged, tagged and offered. Mel
03-29-2018, 09:19 PM | #35 |
“On The Hunt”
I’ll take the fan shroud
03-29-2018, 11:35 PM | #36 |
If you have a '72 BB alt rod only I need one. Thanks Tom
03-31-2018, 10:33 PM | #37 |
Sorry Tom, we can't cut loose of any of the 72 big block alternator rods by themselves, we've only been offering them as part of the full 3 pc. bracket setup. It seems that the rear brace/rod is the one that everyone is always looking for and also the same reason that we are sitting on all of these one year BBC orphans needing the requested brace. Mel
04-02-2018, 11:52 AM | #38 |
Active Member
Thanks for all the great illustrations Mel, they really help clarify a lot of things. Chuck Higgins
04-02-2018, 12:02 PM | #39 |
Hi Mel would you have any of the rear bracket/rod for the A/C set up.
I’ve circled the needed piece from your thread. |
04-02-2018, 12:03 PM | #40 |
Did the 72 BB AC brackets sell? Also do you have a 72 passenger side exhaust manifold as well? I can pick up next weekend at the swapmeet if you'll be attending to save on shipping as well.
04-03-2018, 03:42 AM | #41 | |
Currently, we only have that rear compressor rod/brace available in matched up BBC SWP A/C bracket setups. At times we do have it available/extra when a buyer decides to purchase the BBC A/C brackets as a 7 pc. setup w/o the two rear braces. |
04-03-2018, 04:08 AM | #42 |
Yes, the 72 big block A/C bracket setup pictured in the first post of this thread is available yet, it was a separate set of BBC A/C brackets that were sold the other day in this thread. On the needed passenger side big block exhaust manifold, we currently have these two RH's pulled and stored on the shelf, will take $60. for the one needing some stud work done and $85. for the bolt on ready one. And yes, a next weekend swapmeet pickup can be arranged. Thanks, Mel
04-03-2018, 10:42 AM | #43 | |
Buddy 2062276643 |
04-03-2018, 11:26 AM | #44 |
Are the BBC 72 Towers, clam shells and clam shell to motor mount bolts still available? If so I will take them.....
04-03-2018, 12:26 PM | #45 |
Yes, as of this morning they are available yet, we also have the 1968-71 style big block towers pulled and ready for shipment. If fine with USPS priority shipment the cost is $20.00, if you prefer Fedex shipment we would need your Zip code and confirmation of residential or business address. Thanks, Mel
04-03-2018, 12:50 PM | #46 | |
04-03-2018, 01:31 PM | #47 | |
04-03-2018, 01:44 PM | #48 |
The payment options are listed in the first post of this F/S thread, let us know how you would like to send payment and we will get that specific info returned to you. Also did you catch the two shipment options mentioned in our last above reply? Mel
04-03-2018, 09:42 PM | #49 |
Per our phone conversation, I’ll take the 72 ac brackets as a 6 piece unit and the exhaust manifold with all the studs. Thanks again, see you this weekend.
04-05-2018, 04:43 PM | #50 |
