#26 |
Re: Zach’s 72 blazer build
My dad picked up a bottle for the welder today and we got some work done. I patched bothe the right and left step up on the bed floor today in preparation for putting the bedsides back on. We also cleaned up the lip up the bed floor that will be covered and primed it.
#27 |
![]() Join Date: Dec 2009
Great progress.
Looking Good. Once the fenders go on. Then you can really see the Real progress of a Good Job Well done. Best part is your Dad is helping you.
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
#28 |
Following
Chris Heinz |
#29 |
I’ve gotten a lot more done on the blazer. I have about 6 weeks to get most of the body work finished on the tub and set it on the other frame so I can send it to get painted. Bedsides are all mounted up and seem to fit great. I have gotten bolts in every hole so far without needing a die grinder. Tonight I got the wheel wells bolted in as well. Next on the list is mount the tailgate and put the top back on so I can mount the doors before I start work on the cab floor.
#30 |
Did a little work on the dash tonight, a previous owner hacked up the radio so I cut it out and put in a double din plate. Still needs a little smoothing but it’s all welded in and should look decent when I’m done.
#31 |
![]() Join Date: Jan 2007
fixed pix. Looks good - how did the bedside install go? Everything line up as it should have?
#32 |
Thanks they fit really well for an aftermarket part with so many bolt holes to get lined up. Every bolt was able to be installed without having to enlarge any holes. I was worried how everything would line up once I started putting more parts but I got the tailgate on with a pretty acceptable gap and the top set on today. Next it’s time to cut down a set of doors and get them mounted up so I can start work on the floor pans and rockers.
#33 |
#34 |
Started working on the floor and inner rockers on the drivers side. So far I have the a pillar repaired, inner rocker tacked and bolted in , and the cab support replaced.
#35 |
Looks great! Did you put the bedsides on first and then the wheel wells? Any challenges with those holes lining up? Might have to pull the trigger on a bed floor and bedsides in 2019 if it is that plug and play.
#36 |
Nope everything lined up great I highly recommend them. The tailgate gap looks very nice and the top fit with the sides well too.
#37 |
I’ve gotten a lot done lately since my last update. Almost all of the wedding has been finished inside the tub and I replaced the cab supports while everything was cut out. I swapped the front axle under the frame so I could test fit some tires before I get it ready for paint. I also decided to go a new route and picked up an aluminum 5.3 to swap in.
#38 |
Nice
#39 |
![]() Join Date: Mar 2009
Looks great! But I must admit I'm a little sad the turbines are leaving.
Jeremy 1969 Blazer 4x4 original cst 1971 Blazer partial 2wd convert 1972 Blazer 4x4 original cst 1970 Blazer 4x4 w/ 2 1/2in lift and 33in tires w/4 wheel camper 1970 4x4 suburban w/ 6in lift and 35in tires 1968 Corvette convertible 1970 Malibu convertible 1959 Brookwood wagon 1972 International Scout ii |
#40 |
#41 |
I love watching these blazers being totally reconstructed. Great work! Mike
Instagram @HomeBuiltC10s Dads 79 GMC Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=642929 1978 Silverado Build http://67-72chevytrucks.com/vboard/s...d.php?t=756016 |
#42 |
The last couple weeks we’ve been prepping the frame and finally got it sprayed in a little warm spell. Sprayed por15 first then too coated gloss black. Everything was taken off the frame and I went ahead and rebuilt the rear drums.
#43 |
Got the rocker boxes in and all underneath the tub undercoated and the tub back on the frame.
#44 |
Now I’m working on body lines and gaps. Hopefully about a month and she’ll be ready for some paint.
#45 |
Nice progress.
Will you make steps to get up in there? .
