#26 |
Re: 69GMC - Lack of Secondaries/Low High-End Power
What intake are you running?
#27 | ||
We have not compression tested yet.
1969 ![]() |
#28 |
![]() Join Date: Dec 2013
Have you pulled the sparkplugs to see what they look like and check to see they are gapped 0.45 with the HEI ?
#29 | |
1969 ![]() |
#30 |
My uncle came up today, big Chevy guy. Said we need to compression test it (which you guys recommended), flush the tank and replace the fuel line. With that being said, I'm going to consider the original problem solved since the fuel supply is bad and the carburetor is too big. If I have any other issues I'll make a new thread.
Thank you all for the help!
1969 ![]() |
#31 |
Before you run away could you tell us what intake you have and what carb was on it before the eddy carb?
#32 |
What transmission? I didn't notice if you mentioned it. If it's a 700r you need the correct linkage adapter for the eddy. Mine did the same and I got lucky it didn't burn the transmission.
#33 | |
If it's the air intake, it's the standard circle with the arm coming off. Intake manifold, I have no clue. Would have to consult my father in law again. I believe the old carb was the original Holly quadrajet. I'd have to go pull it and find out.
1969 ![]() |
#34 | |
Still sounds to me like it's running out of fuel. If this was me I'd stick a fuel pressure gauge on it so I could monitor it from the cab under load and see if it's falling off. Electrical, of course, don't plumb gas to the cab!
