07-12-2018, 09:02 PM | #26 |
Re: Engine build and swap price
I’m not sure about how great the 383 option is either— but I do know that the 400 block is a problem and that’s why they use the 350 block with 400 crank to get those extra inches. The 400s are too prone to overheating- not a fairy tale, I personally know 3 that it happened to.
1951 GMC 250 Open Express Pickup 1968 Suburban C10 1971 C20 Olive “People are shocked when they find out I’m not a good electrician” Dad told me “Son, never strike a man in anger- unless you’re certain you can get away with it” |
07-13-2018, 04:22 PM | #27 |
Moderator
For an extra $100 you would be better of IMO, to go with https://www.summitracing.com/parts/mll-bp3833ct1
Roller cammed 383 stroker...just add carb, correct dist and water pump... |
07-13-2018, 04:24 PM | #28 | |
07-13-2018, 04:29 PM | #29 |
Moderator
The Summit page incorrectly says that 350 he was looking at needs a serpentine belt system...it doesnt...I just read the responses on Summit re the serpentine system,,,,m at Summit made a woopsy in a response.
The 383 I recommended is a full long block...sure it needs dressing... But who would install a new engine without replacing water pump and new distributor with correct gear for roller cam... Last edited by AussieinNC; 07-13-2018 at 04:35 PM. |
