Old 03-12-2019, 10:35 PM   #26
'69 Gmc
Seems like I have more room between the bellhousing and firewall from the same angle. Maybe that truck I got the linkages from is farther back. Trying to figure it out with the other truck over an hour away.
'69 Gmc is offline   Reply With Quote
Old 03-12-2019, 10:40 PM   #27
'69 Gmc
This 2/3 linkage that was in the pile of stuff when I got the truck fits and moves perfect.
Old 03-12-2019, 10:46 PM   #28
'69 Gmc
The other linkages I have for 1/R hit the clutch rod and the other rod when trying move into the gears.
Old 03-12-2019, 10:49 PM   #29
'69 Gmc
I feel like i need this 1/R linkage I found a pic of on the site. It looks like it comes over to clear the clutch rod then more straight up to the column ear.
Old 03-12-2019, 10:55 PM   #30
Grumpy old man
Grumpy old man's Avatar
Re: 3 spd shift linkages??
Take a picture of the engine to frame mounts , Is it in the front 2 holes or back 2 holes ?
___________
l..l .
___________
___________
. l..l
___________
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 03-12-2019, 11:11 PM   #31
'69 Gmc
___________
l..l .
___________
___________
. l..l
___________
Mine is in the front two holes
Old 03-12-2019, 11:49 PM   #32
The linkage rods I have are loose, not in a truck. I have an assortment. Just let me know if a picture of them all together will help. i should just get a picture anyway and post it. If I have every variation it may help clarify
Old 03-13-2019, 12:35 AM   #33
'69 Gmc
Pics may help. For me It’s hard to tell what’ll work without trying it on the truck. They guy that has the truck I got the ones off of had about a dozen loose ones. Just didn’t know what I was looking for. I bought one set off eBay for our trucks of unknown origin. They don’t seem to be 6 cyl ones because they aren’t long compared to others, but neither rod fits either location on my truck. Are the small ears the rods go to at the trans all the same? One short one for 2/3 and a longer one for 1/R indexed differently? I’ll attach a picture of the ebay ones I bought. Anybody have an idea what they fit?
Old 03-13-2019, 07:12 AM   #34
I'm in the same boat with my collection. I figure if and when I need them I can try till something works. Still, maybe I have some that are different from what you've had and just seeing them might tell a story. I'll get them out before I head out this morning.
Old 03-13-2019, 12:01 PM   #35
Here is what I have and I have no idea what is what. If anyone recognizes any, please identify so we can reference against those. The first and second picture shows all and it looks like only two identical pairs at the bottom. The very lowest one is slightly different from the pair it is under, only at the lower end bend. You can tell better on the second picture. The third picture has only the ones that are different... it's minus the two that matched another. They are all lined up at the lower ends to give an idea of length differences
Old 03-13-2019, 01:42 PM   #36
weim55
I definitely have a pair off the truck from an original 67 327 three speed. I'll be reusing mine but maybe my example can help ID the correct one from special K. I won't be able to take some pics until hopefully this weekend.
Steve weim55 Colorado
weim55 is offline   Reply With Quote
Old 03-13-2019, 05:34 PM   #37
'69 Gmc
Wow surely someone on here knows which ones are which from those pics. I’ll lay mine out when I get home and see which ones of those I have.
Old 03-14-2019, 05:34 AM   #38
I edited my post and the quote, lower end is slightly different on the left end and lower ends are lined up. To be clear. The first and second picture are the same except I moved 1/4 turn. See what a difference that made with the first two at the top in the first and on the right in the second? I'll leave these as they lay for easier reference until things get sorted out
Old 03-15-2019, 12:48 AM   #39
'69 Gmc
I’ve stared at special-k’s linkages too much.lol. I think the obvious is the left side/lower ones with the hook on the trans side are 2/3 linkages to clear the clutch fork. The 2/3 linkage I have that works is the second in line in the pic where they are lined up at the bottom. Also, the 1/R linkage I pulled off that tuck last weeked is the longer top/right rod that has the small linkage attached. I have the other rod that has the small linkage attached too, it’s a little longer and has that extra bend compared to the 2/3 one I have that works for me(that extra bend makes it hit my clutch rod). I believe right now the two with attached links are a set (6cyl). The pics I’ve seen of a 7 bolt trans, the 1/R rod at the trans is somewhat straight. As of now I’m really thinking the middle rod(in the pic of 9 lined up on the bottom) is looking like a winner. Seems similarly shaped to the longer one with the link attached, but shorter. I’d like someone that had one that works to compare to that one.
Attached one with the extra bend, one like the long one with the link, and the one in the middle of my pic, I don’t even see in yours?
Old 03-15-2019, 08:29 AM   #40
I wish more people with assembled running 3spd trucks would join in to help out. Hint HINT!! Is anybody out there???????????????
Old 03-15-2019, 01:26 PM   #41
Dragcamaro
Would pics of a 1970 250/3 spd column Saginaw setup help for pics?
If so I can try to climb under mine tonight if the snow is melted enough.... my truck is unmolested to my knowledge so should be setup as from factory.
Dragcamaro is offline   Reply With Quote
Old 03-15-2019, 10:28 PM   #42
'69 Gmc
Is your 67 3spd a 7bolt?
Old 03-16-2019, 10:29 AM   #43
NewBayColony
NewBayColony's Avatar
OK, so I took mine out for pictures. I have a 72 292 with the 7 bolt side cover. Name:  20190314_142544.jpg
I've got more pictures but the program won't let me upload them. I'll get them up as soon as I figure it out.
72 C20 292 3OTT
77 GMC 2500 4x4 Longstepper 350 4sp
50 3100 ex Airforce/Town of Mendon fire truck
72 GMC 1500 2wd short stepside 250 4sp
78 GMC 2500 4x Longstepper 292 4sp
54 6400 Chevy 5 window 4 sp 2sp vac rear end Shell oil truck/dump truck (Norman)
NewBayColony is offline   Reply With Quote
Old 03-16-2019, 06:39 PM   #44
weim55
Yes, factory 327 column shift three speed w/Saginaw 7 bolt side cover transmission. Should be able get pics tomorrow (Sunday) if the snow isn't too deep to get into the shed.....
Old 03-16-2019, 06:41 PM   #45
'69 Gmc
Well... I went back to the donor truck today. The motor/trans is in the rear location. Explains the rods too long. I got another rod from him. Got home and it hits the clutch rod. Now I know what I need who’s got one??
Old 03-17-2019, 09:05 AM   #46
NewBayColony
72 C20 292 3OTT
Old 03-17-2019, 09:16 AM   #47
NewBayColony
Finally got them to upload. I had to resize them.
What I'm looking for is one that is around 1" longer on the 2/3 arm (bottom-shorter 24" arm) and one that is 4" shorter than the top 29"1/R arm.
So in other words I'm looking for a 25" with a hook and a 25" straight piece. These are approximate numbers. Anything close, I would buy.
So, Special K, to bother you again, could you measure what you have? Thanks a ton for doing what you have done already.
72 C20 292 3OTT
Old 03-17-2019, 11:02 AM   #48
Yes, I think it would be helpful with it's application mentioned. Once this issue with this truck is solved this thread could be helpful for all the 3spd linkage questions.
If you see what you need in my picture I'll let it go.
Originally Posted by NewBayColony View Post
Attachment 1885992
Yeah, I'll do that today.
Old 03-17-2019, 05:25 PM   #49
weim55
OK, here you go, this is a picture of the first reverse rod off a '67 327 V8 saginaw three speed C 10. It measures exactly 26 3/8". And that measurement is just the rod, none of the attachments.
Old 03-17-2019, 05:27 PM   #50
weim55
2nd Pic.
