Old 04-20-2019, 08:26 PM   #26
NC_John
NC_John's Avatar
Re: AC Request
Originally Posted by 87chevy.com View Post
is this a 2002 and lower pcm? If yes, 12v to the ecu is will then the compressor on if the pressure high pressure switch is installed.. Or of the signal wire is grounded.
If it's the 03 and newer think that's can bus and for some reason the aftermarket is being lame on solutions.
Clint
04.
1970 C-10 LWB "Blu"
Instagram (current build pictures) 70_nc_c10
NC_John is offline   Reply With Quote
Old 04-25-2019, 11:51 AM   #27
indymachinist
Re: AC Request
There are 3 main reasons to let the PCM "control" the a/c. 1) the PCM can turn the fans on and off with the a/c 2) the PCM can kick up the idle when the a/c clutch is engaged 3) the PCM can turn off the a/c clutch at high load/high RPM
-Curt
My 1968 Chevy shortbed stepside build
indymachinist is offline   Reply With Quote
Old 04-25-2019, 11:59 AM   #28
First c10
First c10's Avatar
Re: AC Request
Correct but the problem is finding a way to inform the PCM the AC has been turned on.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 06-24-2022, 04:36 PM   #29
orngsikL
orngsikL's Avatar
Re: AC Request
BP automotive says it's possible.
Still trying to figure this one out.
build thread - 1972 C/10 "Ethyl"
1974 C/10 " Paw Paw"
C/10 Club Louisiana
instagram -
@esso_c10
@projectpawpaw
orngsikL is offline   Reply With Quote
Old 07-21-2022, 06:39 PM   #30
chebyshortbox65
chebyshortbox65's Avatar
Re: AC Request
It’s possible I’ve been running a blue/green ecm for over 4 years with the pcm controlling the a/c compressor and fans. The programming has to be set up for it with hp tuners pin 17 blue connector 12v through high pressure switch. Pin 43 blue connector to a/c clutch relay to ground the relay. Pin 55 green ground through the low pressure switch. Pin 18 green connector 12v spliced in line with the compressor 12v supply from the relay output. Factory 03 up a/c transducer pin 1 transducer to pin 80 blue connector. A/c transducer pin 2 to pin 45 blue connector. Transducer pin 3 to 14 green connector. It’s a mix of f-body. 99-02 and 03-06 wiring.
chebyshortbox65 is offline   Reply With Quote
Old 07-22-2022, 01:47 AM   #31
Accelo
Accelo's Avatar
Re: AC Request
I went through the same thought process. I have 2000 ECM so no canbus issues.
I was convinced the ECM could possible compensate for the air on idle issues if I had a air-condition demand on in the computer.
My original tune was alleged the stock tune. Turned out it had been messed with.
So I was concerned about my idle especially with the air-conditioning engaged.
With the air-conditioning engaged it flat out would not idle after it warmed up.
I had the cart before the horse. The tuner was able to get my system straightened out and it idles nicely even air-conditioning engaged.
The ECM requests an idle speed and varies the outputs to achieve the designated idle speed. So it should be able to compensate for variable loads like high alternator output or air loading.
My motor is maybe a 50 rpm higher than stock as it pushes slightly coming to a stop.
My system is working and has decent drive-ability with out an air-conditioning request to the ECM.
I am using a BTR Stage II truck camshaft in a LS1. If you have more cam and/or less displacement I understand how this may be difficult.
I had a goal to use the stock converter and frankly I wish I would have changed it. For the off the line grunt and the idling pushing issue.
Wishing you progress in getting this issue resolved.
Cheers
Accelo is offline   Reply With Quote
Old 07-22-2022, 11:45 AM   #32
Rust-O-Matic
Rust-O-Matic's Avatar
Re: AC Request
This is very interesting. Do you know what service number your pcm is? Do you have any idea exactly what was modified in the tune? Or how this works?
I'm trying to wrap my head around the wiring, because half of these pins aren't A/C related, and the link below shows that most blue/green pcms are missing the components required to recognize the 12v request signal. My understanding is that the BCM sent a serial data signal for the request in '03+ pcms, rather than the standard 12v request like '99-02.
Blue 17 = Signal B (A/T) Trans Fluid Pressure switch
Blue 43 = Fuel injector 7 control
Green 55 = Not used
Green 18 = Clutch start switch (M/T)
Blue 80 = Low reference (ECT)
Blue 45 = 5 volt reference (A/C)
Green 14 = AC refrigerant pressure sensor signal
For anyone who hasn't seen this thread yet, check it out:
https://ls1tech.com/forums/conversio...c-request.html
Rust-O-Matic is offline   Reply With Quote
Old 08-18-2022, 01:53 PM   #33
orngsikL
orngsikL's Avatar
Re: AC Request
im using a E38 Gen 4 PCM.
still fighting this.
I know the transducer switch on the high side line is working and getting a 5v ref and sending out a voltage as related to the pressure, but I still can't get the ECM to read it with HP Tuners VCM scanner.
I have a segment swap done for the fans, just dont know if it's the right one. As this ECM originally came out of a Chevy Express 3500 with a clutch fan.
The fans are working correctly, controlling engine temps, but are not working to control ac head pressure / temps when the engine is under minimum coolant temp for the fans to come on and I blow the relief valve on the ac compressor.
C/10 Club Louisiana
instagram -
@esso_c10
@projectpawpaw
Old 09-02-2022, 01:02 AM   #34
orngsikL
orngsikL's Avatar
Re: AC Request
GOT IT FIGURED OUT TODAY FOR GEN4 with a E38.
So, a little back ground.
The truck and van OS on a e38 used the canbus system, which used the ac control panel and the BCM to communicate with the ECM and tell it when the compressor is on and this tells the ECM to read the ac pressure transducer. Without the canbus and the BCM, it wont work on a truck / van OS.
Now, here's the solution and I got it working tonight:
E38 Camaro OS doesnt use a bcm or a canbus signal to tell the ECM to monitor the AC pressure transducer, it just reads it on it's own via a 5v ref pin on the J1 connector at the ECM, which goes straight to the AC pressure transducer and uses a ground via the switch and a return wire that sends the corresponding voltage back to the ECM. The ECM then converts this voltage to pressure and there is a table in HP Tuners under the fan section that allow you to set the electric cooling fans to come on with your programmed pressures. So you can do a Camaro OS swap, but it has to be compatible with the ECM hardware itself and with your TCM. Also you have to run a Camaro accelerator pedal for the camaro OS.
Mine is working perfect.
Shoot me a email if you need some help.
c10clubLA@gmail.com as I dont get on here much anymore to check the replies and PMs.
C/10 Club Louisiana
instagram -
@esso_c10
@projectpawpaw
Old 09-02-2022, 08:26 PM   #35
67-C10
67-C10's Avatar
Re: AC Request
The jeep guys use a canbus add on to enable the ac request. Ain't that cheap of an option but it does exist. http://www.rpmextreme.com/Product/23...st-Module.aspx
I got my engine from a van 2011 and kept the bcm. The van bcm will take a ground or 12v I forget which but generates the canbus signal to the ecm for ac on request. 03 up gen iii need the hvac module and the bcm to talk to the ecm I believe at least in the trucks and suvs that's the case.
67 C10 2wd Stepside (to be fleetside), Factory AC truck, Big Back Window, just got a 6.0/6l90e to jam in it now.....
Needed: paint and lots of it. and i'm sure lots more misc. parts.
Project 67 short step Build Thread
01 Sierra Crew 6.0
2015 Ford F150 Work gave me truck i really wouldn't buy a ford.
67-C10 is offline   Reply With Quote
