04-29-2019, 03:48 PM | #26 |
Re: Quality hose clamps
Those are the only clamps I will use now,I use to use worm drive clamps in the past,but found them to loosen of and/ or strip out when over tightening them,I have been trying to find these in larger sizes for heater hoes and rad hose applications
04-30-2019, 09:50 AM | #27 |
05-01-2019, 02:17 AM | #28 |
Good stuff Killer Bee.
I was looking for an equivalent of your fuel clamps for 5/8" & 3/4" hose. Came up short for new ones, because the band width is 1/2" for water pump and intake ports. New ones are 3/4" wide, though the "Corvette" replacements might fit. But then I came across these. Pulled the trigger on two pair (yikes), heater and bypass hoses. They're original I'd say, looks like a thick band. https://www.ebay.com/itm/NOS-WITTEK-...72.m2749.l2649 Not right for this truck, but better than the average worm drive seems. Not sure about the 5/8" heater hose yet, maybe Wittek. I probably won't install tower clamps for any of the water hoses. My truck still had the original tower clamps for power steering, flame arrestor and fuel tank. They're still nice, so I'll probably install those. All the original water hose clamps are gone, probably for good reason.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
05-01-2019, 09:57 AM | #29 |
Sorry didn't have time to read every post in this thread, but the quality ones I've found at the Witteks (either orig or repro company) from Eckler's Corvette. The ones I got from truck and car restoration places were paper thin garbage, but the Eckler's ones, while pricier, actually worked as good clamps, which is nice!
It's actually not clear to me that tower clamps were still used on the trucks in 69/70 but the motors came from Tonawanda and should be the same as cars, so I don't know what o believe!
05-01-2019, 11:31 AM | #30 |
^^ expensive but look like good quality and OE style
as far as how late tower clamps were installed.. feb 71 longhorn all four radiator clamps and nov 71 mfr 72 my k1500 burb gas fill hose
I started out with nothing - and I still have most of it |
05-01-2019, 05:22 PM | #31 | |
Zane's 71 Build |
05-01-2019, 08:38 PM | #32 | |
but they do seem to work good with even tension so ill give 'em a pass on the metric heads
05-03-2019, 02:30 AM | #33 |
Ah metric. My truck was metric free until I installed the Moog steering linkage. Some of their "SAE" tie rods are metric, according to they you get what you get.
I think I found a set of 5/8" hose clamps to "match" the 3/4" I ordered the other day. Parts book says they're 7/8", but also says 3/4-1". Seller says they're a 1" opening and that should be correct for a 5/8" hose, which is a pinch under 1". Book says they were used in various applications, they run back to the 50s if I recall. Hit and miss through 72 or so. Were about half what I paid for the 3/4" Hopefully that just leaves the 1.5" lines. At this point I think near solid band worm-drives, to match things up. Otherwise I'd be all over T-bolts. Edit: They're exactly for 5/8" ID hose
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 05-09-2019 at 07:23 PM. |
05-03-2019, 10:04 AM | #34 |
Here’s a SPID picture I saved, it lists worm gear clamps as a special order item. I had never heard of, or seen this before.
72 3/4t Custom Deluxe 402/auto 66k Original paint 71 3/4t 4x4 Custom Deluxe 10k original miles Original paint 71 3/4t Cheyenne 402 70k original paint 72 3/4t 4x4 Custom deluxe 72 3/4t 4x4 Custom deluxe 91k original paint 72 Cheyenne/30 Dually 69 Camaro SS396 4-speed 13 GMC 2500HD Duramax I bought new 05 Jeep Wrangler "Willys Edition" 12k miles (I bought new) 85 3/4 ton 4x4 Scottsdale 33k miles original paint 86 1 ton 4x4 SRW Silverado 454 restored 80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint 95 GMC 1 ton dually 4x4 my dad bought new 95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles 2002 2500HD 4x4 regular cab 6.0L 67k miles 2002 2500HD 4x4 regular cab 8.1L 28k miles 2003 GMC 2500HD 4x4 regular cab Diesel 93k miles 67-72 Parts for sale |
05-03-2019, 08:58 PM | #35 |
Who Changed This?
YESSS! "Truckster", in post #5 in this thread asked me about this after I mentioned I had seen them on an SPID here. So, one of those rare options, but really exist.
05-03-2019, 09:28 PM | #36 |
I just worked a very long day and I can hardly believe what I am reading here.
" I'll take the 350 V8, Turbo Hydra-Matic, and OH YES, the worm gear clamps, of course!" I never really thought about clamps. I just re-tighten my worm gear clamps occasionally, but they do leak sometimes, agreed. Good thread. -BA
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. |
05-03-2019, 11:32 PM | #37 | |
Who Changed This?
