Old 08-01-2019, 08:58 PM   #26
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 90 crew 1 ton Cummins 47re swap
Very nice project you have going here! I hope your FASS is one of the new styles that don't lose their prime all the time. MAKE SURE YOU SEND IN THE WARRANTY CARD! They won't warranty it without it and you will need it. I'd return it if you could. The stock lift pumps are tough as nails.
Your build is looking good and you will like the anteater!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 08-02-2019, 06:46 PM   #27
74project
About the fass pump. My thoughts were that when on a dirt road doing 50 or off roading with a 40 gallon tank that's a lot of air in the tank and in the lines.. I haven't heard one bad thing about the original lift pump but finding a sending unit and so forth but when researching for a sending unit it seemed like I was getting no where, so I copied the "suburban doomsday build". Have the tank mocked up and the screamin mounts. They were a pain to install by yourself well built tho...
Anybody have good body mounts? Ordered some but they dont fit and are not built as well as the original ones..
Also looking for a 23 spring coupler for t-case and a brake like for rear diff see pic.. hope you all r doing well. Vegas is hot as dog balls..
74project is offline   Reply With Quote
Old 08-05-2019, 02:56 AM   #28
Madkidd007
Madkidd007's Avatar
I’ve gotta side with everyone else, leave the pump mechanical. A 12V is a doomsday motor as it can run with zero electrical. I’d either run a stock pickup just verified to be close to the bottom or sump the tank. The stock lift pump is such a good design people retrofit them into the VE trucks before going electrical. It’s crazy the combination of factory parts you can use to make it all work, only aftermarket part on mine is the exhaust and radiator.
70 C10 highschool truck now C20 cummins powered
72 Crew Denali, Bigger, Stronger, Faster, well you get the point.....
the ole 65 continental
Syclone killer AWD T56 LS
Paypal please pay as Goods&Services Madkidd00000007@yahoo.com
Madkidd007 is offline   Reply With Quote
Old 08-05-2019, 02:10 PM   #29
DieselSJ
On your rear brakes, scrap the load sensing valve. There have been a couple threads on here. GM added it to pass 1 specific fed.gov test and they are nothing but problems when they get older. I removed mine and I don't notice any difference loaded or empty.
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find
87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4
DieselSJ is offline   Reply With Quote
Old 08-08-2019, 08:32 PM   #30
Dieselwrencher
Just build your own pick up tube. I have done it several times. You heat the brass or solder joint that holds the OEM pick up in the sending unit. Or you can even drill a new hole if the fuel sender is attached to the stock pick up. But you drill a 3/8" hole and use 3/8" line. Bend it how you need it, put a 30* slash cut on it and place it about 1/16" or 1/8" off the bottom of the tank. Braze or solder the new tube in. You can flare the end for a hose, or even add a tube nut before you flare it.
Now on the air removing pumps.... They do do a nice job of removing the air from the fuel. But that does you 0 good when your pump motor craps the bed and you are in BFE, or anywhere for that matter. Very few people stock those motors so now you are down and out. I have had horrible issues with the Fass pumps losing prime the last 2 to 3 years and that leads to mad customers. Who do you think they call when FASS doesn't answer? I'm just trying to save you some head aches. Supposedly FASS has redesigned the new versions to fix this but IDK. I quit selling them.
I also agree, get that load sense valve out of their. hey just create more head aches than they're worth IMO.
Ryan
Old 09-26-2019, 10:56 PM   #31
74project
Couple pics..
Old 09-26-2019, 11:06 PM   #32
74project
Best thing I figured out for cleaning was using the scotch-brite as pads for grease and dirt along with the concrete cleaner from the 99 cents store.. works amazing..
Old 11-02-2019, 09:09 PM   #33
74project
Hello,
Got the motor and transmission mounted, all frame boxed in. I'm not sure if it was worth buying the precut plates from diy4x4..had to spend a ton of time grinding, sanding, and cutting to make fit. Need to figure out the power steering lines right now until I'm able to move on.. there is a ton of stuff that I'm still trying to figure out and it seems my Google skills are slacking. Like the waste gate on the turbo, sensors, and other stuff. It's been fun so far and still think I can get her running by Christmas..cheers.
Old 11-09-2019, 09:32 PM   #34
74project
Fellas seen too many of these.. always keep a fire extinguisher in ur ride with some leather gloves... get that hood open asap..
Old 11-18-2019, 02:32 PM   #35
1972K20
1972K20's Avatar
Your build is looking good! What paint did you put on the frame? Your welds look good too!
1972K20 is offline   Reply With Quote
Old 11-19-2019, 08:28 PM   #36
74project
Purchased the por15 gloss off of Amazon. Working on putting a coolant bypass on #6 it's super tight tho.. my air intake is also hitting the brake booster.
Old 11-19-2019, 08:34 PM   #37
74project
Trans fan mounted.. also purchased a 98 jeep Cherokee steering shaft for 70 bucks works great.
Old 11-20-2019, 12:58 AM   #38
randy500
Looking really good.
Too bad the frame boxing kit didnt fit better, for the cost it really should.
randy500 is offline   Reply With Quote
Old 11-20-2019, 01:01 AM   #39
randy500
Have you thought about removing those aluminum heater hose extension tubes? I found hydraulic line fittings to adapt the huge pipe thread holes to 5/8 and 3/4 hose barbs.
Old 11-20-2019, 06:44 PM   #40
74project
No I haven't thought much about the aluminium fittings.. to be truly honest I dont think much in general..haha I will search ur posts..
Old 11-23-2019, 05:57 PM   #41
74project
Working on a 50 gallon tank..
Old 11-24-2019, 09:10 PM   #42
74project
Dropped this thing on my hand... so had to come with something a little easier..worked out ok tho..
Old 11-25-2019, 12:42 AM   #43
1972K20
1972K20's Avatar
Ouch...that's one way to do it.
Old 12-10-2019, 01:24 PM   #44
74project
Hey guys anybody know where to get a new bulk head connector?
Old 12-10-2019, 01:45 PM   #45
Madkidd007
Madkidd007's Avatar
Ouch I think that’s 89-91 only because of the extra terminals. If you take a picture of the fuse block side to help show, I may have one at home.
Old 12-10-2019, 01:57 PM   #46
74project
I didn't want to rewire everything but this is a mess..
Old 12-10-2019, 09:57 PM   #47
Madkidd007
Madkidd007's Avatar
Unfortunately I don’t have an 88-91. Do the other two connectors lock together? Once it’s installed if they do I’d imagine that one side would still be enough to hold it tight. Especially since the terminals will have friction on them too
Old 12-24-2019, 11:28 PM   #48
74project
Merry Christmas every body..****ters full! Got her wired up and ready to start. had to change the heater core since it was... well there.. my buddy is still making my tank. Ran into a couple hiccups with the transfer case shifter and intake hitting my brake master...has anyone used spray foam in the roof on r trucks? I'm also closing in the fender holes.. trying to sound deaden as much as I can on all areas of the truck..cheers.
Old 12-24-2019, 11:37 PM   #49
74project
Also made a heat shield for ac box, transmission lines, and..wrapped up wire harness..
Old 12-25-2019, 12:51 AM   #50
randy500
Its one thing after another to build, modify etc. looks great! I like your intercooler mounts and the ac heat shield.
What is your idea on the intake clearance?
Also wondering what the aircraft style lines are for?
