Old 03-20-2020, 10:14 AM   #26
hatzie
Moderator
hatzie's Avatar
Re: A couple of questions about the 99-06's
Originally Posted by bennylava View Post
Maybe I'm confused here but...
It sounds like yall are saying there are 07 GMC branded trucks that have the 2002 Chevy headlights and grille. Since I've made it clear that's the style I want. I was under the impression that the GMC trucks all used the same headlights, and none of them ever came with chevy headlights that could be found on a chevy truck in 2002.
Or are you saying that I should get a GMC truck from 2007, and it would be very easy to change over to the 02 Chevy front end?
There are at least three different looks for the T800 pickups. GM differentiated the GMC Sierra and the Chevy Silverado by changing the look of the front end.
The 1999-2002 T800 Silverado 1st design is this *
Name:  1999-2001 Silverado Front.jpg
The 2003-2007 T800 Silverado 2nd design is this
Name:  2003-2007 Silverado Front.jpg
The 1999-2007 T800 Sierra is this
The regular Suburban/Yukon/Tahoe SUV, Denali package, and Cadillac SUVs are yet more looks. I'm not sure how much of the underpinnings and sheet metal are interchangeable between the SUVs and Denali SUV and the pickup trucks without doing a full nose transplant.
* NOTE:To further muddy the waters... you can find 2003 Silverado HD trucks with the 1st design sheet metal and lighting.
You at least have to swap the outer body panels and probably the forward lighting harness section from the fuse/relay panel to the lamps, horn, etc.
I'm unsure about whether you can mix and match the radiator support for different headlamps and sheet metal (hood, fenders, and grilles) but I wouldn't count on re-using your radiator support if you're swapping over.
I didn't like the front seat bottoms in the 99-02ish Silverado but the sheet metal looks good IMHO.
You can swap the later Red Silverado tails over to the Amber turn lamp sets GM used on the Early Silverado and both GMC Sierra models. I did this. You need the lamp pigtails from the distribution block to the tails as well as the lamps. See my 2005 build thread.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 04-12-2020, 05:08 PM   #27
CarlsLQ9SS
CarlsLQ9SS's Avatar
The 99-02 fenders will bolt to your radiator support just fine. You will have to change tour headlight buckets to the 99-02 style headlights, and you will have to change the bumper brackets that are welded to the frame also. Then you will need the 99-02 bumper as well as all the bumper brackets and the rest will bolt right on. I have changed the front ends on these trucks many times from the 99-02 to the 03-06 on Silverado and GMC. Here is an example.
CarlsLQ9SS is offline   Reply With Quote
Old 02-26-2023, 05:10 AM   #28
bennylava
bennylava's Avatar
Originally Posted by biketopia View Post
I like the dashs better in the 03&up trucks but it's really preference i suppose.
It appears to be the same dash. Maybe you're referring to some buttons or wood grain?
bennylava is offline   Reply With Quote
