Old 04-04-2020, 11:13 AM   #26
skymangs
skymangs's Avatar
Re: Orson the 49 GMC ~ Chris C.
The 49 getting blow apart
skymangs is offline   Reply With Quote
Old 04-13-2020, 12:41 PM   #27
skymangs
skymangs's Avatar
Well in the process of installing the spindles and upper ball joints, one of the lowers and an outer tie rod end spun on us. Then both sway bar end links broke. So you’re getting new upper and lower ball joints, drop spindles, new outer tie rod ends, and end links. Parts are on order. Meanwhile we’ll be working on getting the cab on and driveline set.
Old 04-13-2020, 12:44 PM   #28
skymangs
skymangs's Avatar
more pics
Old 04-13-2020, 12:46 PM   #29
8man
New parts! Moving along.
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 04-13-2020, 12:51 PM   #30
skymangs
skymangs's Avatar
yup, not as fast as I’d like. But it’s their first one, so I give slack!
Old 04-13-2020, 01:00 PM   #31
8man
Spoken like a true DAD!
8man-aka Robert
Old 04-13-2020, 02:11 PM   #32
skymangs
skymangs's Avatar
what can I say?
Old 04-21-2020, 03:25 PM   #33
skymangs
skymangs's Avatar
The front suspension is all buttoned up. New upper/lower ball joints, outer tie rod ends, sway bar end links, and 2" drop spindles installed. The pads and rotors looked good. Just waiting on the 2” spacers to arrive (fri) and then those torque thrust His go on the front.
Old 04-21-2020, 03:30 PM   #34
skymangs
skymangs's Avatar
and here’s the cab, going on the frame for the first time.
Old 04-21-2020, 03:34 PM   #35
skymangs
skymangs's Avatar
Last few.
Old 04-24-2020, 12:02 AM   #36
Gregski
Post Whore
Gregski's Avatar
loving this build, especially the sit in a lawn chair and stare at it pic, I do that all the time
please forgive me but I am taking liberties to correct your side pics as they add value but are giving me vertigo (I use a free program called IrfanView to rotate them as the iPhone has a mind of its own sometimes)
Gregski is offline   Reply With Quote
Old 04-24-2020, 12:08 AM   #37
Gregski
Post Whore
Gregski's Avatar
one more maybe
Old 04-24-2020, 08:29 AM   #38
skymangs
skymangs's Avatar
Thanks, not sure why they do that. The picture is oriented properly. When I upload them they rotate.
Old 04-27-2020, 10:17 AM   #39
skymangs
skymangs's Avatar
Removing the old clamshells and building motor mount adapters
Old 04-27-2020, 11:37 AM   #40
skymangs
skymangs's Avatar
Here’s the finished adapter and it on the engine
Old 04-27-2020, 11:40 AM   #41
Gregski
Post Whore
Gregski's Avatar
Nice work as always, I've been rackin' my brain trying to figure out a way to use the clam shells without an adapter so just weld something to them, I like to keep it simple and join Part A to Part B and avoid Part C if I can help it
not saying I figured it out, I'm just saying I'm still having thoughts on it, ha ha
keep going! loving your build
Old 04-27-2020, 02:45 PM   #42
skymangs
skymangs's Avatar
Check out my 49 LS1 (in my sig) I used the clamshells in that (granted it was a Camaro stub, not an S10). I’ve just found that it’s less work to start from scratch!
Old 04-29-2020, 12:34 PM   #43
skymangs
skymangs's Avatar
They have gotten the motor all mocked up. Next step is to build motor mounts, then pull the cab, build the trans crossmember, fuel system, exhaust, and initial start up!
Old 04-29-2020, 09:50 PM   #44
skymangs
skymangs's Avatar
motor mounts built
Old 04-29-2020, 10:04 PM   #45
skymangs
skymangs's Avatar
Tomorrow morning they’ll pull the driveline and seam the motor mounts in
Old 04-29-2020, 11:22 PM   #46
skymangs
skymangs's Avatar
So then we start modifying the transmission crossmember. We begin by cutting off the last 6” on each end. Then bolt the center section back on to the transmission.
Old 04-29-2020, 11:29 PM   #47
Gregski
Post Whore
Gregski's Avatar
hope you don't mind I find your work very interesting and want folks to see the pics oriented properly
you can save these and repost them in your thread and they will upload correctly and I can nuke these if you like, or just let them be
Old 04-29-2020, 11:32 PM   #48
skymangs
skymangs's Avatar
Then you hold the ends under the center section in approximately the portion they will be in bolted down, Mark the overlap and cut. Now remove the crossmember and weld the ends on.
Old 04-29-2020, 11:41 PM   #49
skymangs
skymangs's Avatar
The passenger side is easy, just duplicate the factory bolt holes. On the driver’s side you’ll need to create a shelf using a piece of 1x1x11ga or even some 11ga flat steel.
Old 04-30-2020, 01:56 AM   #50
joedoh
joedoh's Avatar
love it! nice work!
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
