09-24-2020, 08:30 PM | #26 | |
Who Changed This?
Re: C30 heavy duty rear axle top speed
09-24-2020, 09:20 PM | #27 |
The Gear Vendors OD's (I have 2-- one behind a TH350 and one behind a SM465) uses a speed signal generator inline with the speedo cable to create a voltage signal to the little computer brain as to when you are going fast enough to kick in the planetary gear OD which is about +/- 45 mph minimum, so that is something to keep in mind with the GV verses a manual OD.
09-24-2020, 09:27 PM | #28 |
09-24-2020, 11:19 PM | #29 |
On my 1964 C30, it had 5:14. I bought a Dana 70HD, with sway bar out of a 77 Chevy C30 dually, installed 4:10 with posi. Bolted right in, welded some shock mounts and shortened or lengthened the drive line, can't remember. 65 mph at 3,000 rpm. Had a ratio adapter built for the speedometer so speedo is right on.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1964 C-30 383/4 speed, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison |
09-25-2020, 09:57 AM | #30 | |
This is the exact same setup as mine... 70HD, shorted drive shaft, welded suspension brackets and repositioned leaf brackets. I like the leaf springs setup. What stock with the truck or it came from the donor? Did you had to reposition the rear leaf brackets or was it a bolt-on?
09-25-2020, 11:43 PM | #31 | |
09-29-2020, 09:11 AM | #32 |
I would leave that original rear in place and add an auxiliary transmission. You would not have to alter your PTO set-up, you would be leaving that truck as the cool not too common 11k# axle option that it is, and be doing what an innovative minded truck owner might have done back in the day. There was a company called Brownie that made units for this application and I know of guys doing their own engineering to install back to back transmissions. Twin sticking is just too dang cool and a totally vintage truckin' way to go. These days you could simply (other than the $1,600 cost) install an Advance Adapters Ranger 2spd. With an auxiliary transmission you will also have the ability to split shift, but would not have to if you didn't want. I believe you will gain a higher speed overdrive over using an overdrive transmission.
https://www.advanceadapters.com/cate...-splitter/236/
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 09-29-2020 at 09:21 AM. |
