Old 06-14-2020, 12:49 PM   #26
Ben IV
Re: 70 gmc DIY build
Great project.
Keep up the good work.
Thanks. Pretty sure I follow you on Instagram.
70 GMC custom short bed conversion
69 GMC panel truck
Ben IV is offline   Reply With Quote
Old 06-14-2020, 12:57 PM   #27
Ben IV
So after the lay out and lots of double checking it was time to cut. I cut the outside skin first then marked the inner skin off of the cuts through the top rail. Ended up with this.
69 GMC panel truck
Old 06-14-2020, 01:04 PM   #28
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Looks great! Nice job!
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 06-14-2020, 02:00 PM   #29
SCOTI
SCOTI's Avatar
Getting dizzy just staring @ the puzzle pieces
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-14-2020, 08:03 PM   #30
cornerstone
cornerstone's Avatar
Absolutely the cleanest cut lines I've ever seen... How in the world did you maintain such accuracy? Cut off wheel? The sanded edges look to be a consistent 1/4"... I'm curious how you did it.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 06-14-2020, 08:05 PM   #31
Scurry67
Looks great! Nice work.
67 SWB First Build
http://67-72chevytrucks.com/vboard/s...d.php?t=777171
Scurry67 is offline   Reply With Quote
Old 06-14-2020, 10:38 PM   #32
Ol Blue K20
Originally Posted by cornerstone View Post
absolutely the cleanest cut lines i've ever seen... How in the world did you maintain such accuracy? Cut off wheel? The sanded edges look to be a consistent 1/4"... I'm curious how you did it.
x2!!
Dale
Old 06-15-2020, 08:29 PM   #33
Ben IV
Thanks. I used an air cutoff tool with a 4" .030 disc. The edges I did with a mini air belt sander.
69 GMC panel truck
Old 06-16-2020, 11:17 AM   #34
1971Stepside
Almost Satisfied
1971Stepside's Avatar
amazing work on the bed cut down...I'm not worthy...
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 06-16-2020, 11:57 PM   #35
rwade
rwade's Avatar
What is the paint code number and name? Great job on the cut down.
Wade
rwade is offline   Reply With Quote
Old 06-19-2020, 12:06 AM   #36
Ben IV
After getting things cut apart and cleaned up it was time to stick them back together. Using .023 wire with 75/25 shielding gas.
69 GMC panel truck
Old 06-19-2020, 12:09 AM   #37
Ben IV
Thanks. I think the pictures do it a little too much justice.
Wade
Medium blue I believe.
69 GMC panel truck
Old 06-26-2020, 12:25 PM   #38
Ben IV
After they were welded up. I took my time and skipped around but there was still a slight amount of warping. Probably impossible to have zero warping without body work.
69 GMC panel truck
Old 06-26-2020, 01:03 PM   #39
Ol Blue K20
Looks great to me!
Dale
Old 06-26-2020, 02:21 PM   #40
SCOTI
SCOTI's Avatar
A skilled TIG operator could prob get it done but that's why they charge what they do. Kudos to your effort. Looks great from here!
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-26-2020, 11:38 PM   #41
CryingJoker
Holy cow that's amazing. I'll be honest I couldnt trust myself to cut down a long bed to short. I'd just have to pony up the money and buy new bedsides as I'd probably end up doing it anyway. Keep up the good work.
03 s-10: daily driver
94 s-10: late model toy
70 c10: starting frame off resto
80 c10: for sale just collecting dust
94 c1500: hauler to and from
55 chevy: hot rod project jus reborn
CryingJoker is offline   Reply With Quote
Old 06-27-2020, 10:50 AM   #42
Ben IV
Originally Posted by Ol Blue K20 View Post
Looks great to me!
I have a tig machine and I'm pretty good but never tried it on sheet metal so just stuck with what I know. Thanks
I had most of the tools I needed already and the bed wasn't in perfect shape so I gave it a shot.
69 GMC panel truck
Old 06-27-2020, 11:39 AM   #43
Ben IV
Next was the bed floor. After some research I made the decision not to splice the floor which saved me a lot of cutting and welding. The front is simple just cut 12" off the front and drill new holes in the floor and header panel. Back is a little more involved. I cut off 7 1/2 inches and removed the rear cross sill from the cut off floor to spot weld back under the floor. Then used my air hammer with a pomel to fold the extra 1/2" over like factory. If i were to do it again I think I'd leave more than a 1/2" it would probably fold over easier. I did this with the floor bolted back to the sides to ensure everything lined up.
69 GMC panel truck
Old 06-27-2020, 11:47 AM   #44
Ben IV
Here's what I did in the rear corners. The bedside has 2 bolts through the rear cross sill and I tack welded it to it like the factory did so I don't think 1 less bolt will hurt.
69 GMC panel truck
Old 06-27-2020, 02:05 PM   #45
SCOTI
SCOTI's Avatar
Very nicely done!
Hope I get to see this one some day @ a show or gathering (if we survive 2020).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-27-2020, 03:10 PM   #46
Chevys4life
You have done a very nice job on your bed. Keep up the good work!!!
Chevys4life is offline   Reply With Quote
Old 06-27-2020, 03:13 PM   #47
Chevys4life
Subsribed!!!
Old 06-27-2020, 08:26 PM   #48
Ben IV
Very nicely done!
Thanks. I don't know if it's car show nice but I'd love to go to c10's in the park or LST some day.
Thanks just trying to build a fun driver.
69 GMC panel truck
Old 06-27-2020, 11:50 PM   #49
SCOTI
SCOTI's Avatar
I've never owned "car show nice" rides. They've always been fun/cool drivers. The Patina trend just helps up the status. Once the trend ends, I'll still be building budget drivers that peers will turn their necks for. The only one I ever planned to paint (& attempt to make really nice) is my RetroRod. It was perfect patina back in the late 80's until it was stolen & hacked up. It will get decent paint.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-28-2020, 01:41 PM   #50
Ben IV
Nice to not have to worry about a little scratch or chip. But some people are taking patina too far kinda like they did with the "rat rod" craze.
69 GMC panel truck
