Old 03-02-2021, 10:59 AM   #26
superchevy
Got big-block?
superchevy's Avatar
Re: '78 GMC SC 454/T400 long to short bed build
@SCOTI, lol, yeah...
'68 CST SWB factory 396/T400
buddy buckets, a/c, ps, pb
'72 Corvette convertible 454/4spd/ac, ps, pb
'73 GMC Sierra Grande short wide 454/T400 ps, pb, ac
'77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original
'78 GMC Sierra Classic short wide 454/T400 ps, pb, ac
'72 GMC Sprint SP454. 1 of 38 built.
'73 GMC Sprint SP454. 1 of 71 built.
'75 GMC Sprint SP454. 1 of 25 built.
SOLD! '72 GMC K25 4x4 468/4L80e/NP205
build thread
http://67-72chevytrucks.com/vboard/s...23#post4324423
SOLD!'55 Chevy gasser 496/4spd
build thread
http://67-72chevytrucks.com/vboard/s...96#post4324396
superchevy is offline   Reply With Quote
Old 03-02-2021, 08:31 PM   #27
superchevy
Got big-block?
superchevy's Avatar
got the drivers door disassembled this evening...tomorrow start on the dash disassembly...little by little
build thread
build thread
Old 03-03-2021, 09:17 PM   #28
superchevy
Got big-block?
superchevy's Avatar
I removed the dash gauge bezel and dash pad this evening...I was going to disassemble the complete dash; gauge pod, radio, steering column, etc, but I realized it would be a waste of time...everything is in near mint condition...pristine even....I can't improve on it...hell, I'm just going to buff the lower dash paint along with the ashtray and glove box and call it done...
build thread
build thread
Old 03-03-2021, 09:19 PM   #29
superchevy
Got big-block?
superchevy's Avatar
more dash pics
build thread
build thread
Old 03-06-2021, 05:39 PM   #30
superchevy
Got big-block?
superchevy's Avatar
damn, I really like the way this one is going to sit....rolled it outside today to power wash the firewall, front frame, crossmember....tomorrow will disassemble the front suspension/steering....then it's frame painting time and a bunch of new parts to install
build thread
build thread
Old 03-07-2021, 05:09 PM   #31
superchevy
Got big-block?
superchevy's Avatar
man, I hate front end work...nasty, greasy, and hard on this old guys back...I'm done for the day....it's Miller time
build thread
build thread
Old 03-09-2021, 05:58 AM   #32
LT7A
Might be messy, but it looks like you're winning.
Old 03-09-2021, 09:37 PM   #33
superchevy
Got big-block?
superchevy's Avatar
Decided to remove the lower control arm bushings this evening...the drill method is the easiest I've found...going to use Prothane bushings/sleeves, so keeping the existing shells in place...also sprayed down the spindles with oven cleaner to get some of the grease and oil off before blasting/painting.
build thread
build thread
Old 03-11-2021, 09:19 PM   #34
superchevy
Got big-block?
superchevy's Avatar
after soaking in EZ Off oven cleaner for 2 days, I got a chance to power wash some of the greasier front end parts this evening...sprayed on a little Gibbs to slow the flash rust on the machined surfaces...the Prothane control arm bushings showed today too...tomorrow press in the new MOOG ball joints...
build thread
build thread
Old 03-13-2021, 08:41 AM   #35
superchevy
Got big-block?
superchevy's Avatar
I got off work a little early yesterday and finally finished stripping down the front frame...got the brake/fuel lines off...got the steering gearbox off and the master cylinder/booster as well...goal this weekend is to finish cleaning the frame and paint it as well as media blasting a lot of the smaller parts and painting them
build thread
build thread
Old 03-13-2021, 09:12 PM   #36
superchevy
Got big-block?
superchevy's Avatar
Got the new MOOG ball joints pressed in the LCA's....also blasted and painted lots of small parts....tomorrow final clean/paint the front frame and then it's on to installing all the new parts!
build thread
build thread
Old 03-14-2021, 09:56 AM   #37
LT7A
It's looking good. You're making quick work of it.
Old 03-14-2021, 12:01 PM   #38
superchevy
Got big-block?
superchevy's Avatar
Thank you. I try to do a little bit each day so things keep moving along.
build thread
build thread
Old 03-14-2021, 05:36 PM   #39
superchevy
Got big-block?
superchevy's Avatar
finally got the front half of the frame cleaned/scuffed/painted today...it's almost time to throw a bunch of new parts at this thing
build thread
build thread
Old 03-16-2021, 07:40 PM   #40
superchevy
Got big-block?
superchevy's Avatar
the view you have laying under the cab sanding the frame for paint....also, I've decided not to paint the bottom of the cab...I love the original red primer and overspray...there is so little rust...I'm just going to coat it with Gibbs Brand and leave it as is... not hiding anything on this clean ass truck
build thread
build thread
Old 03-19-2021, 10:33 AM   #41
1981_c10
1981_c10's Avatar
love the progress!
Builds:
1962 C10 Recreating Dad's High School Truck
1981 C10
1981_c10 is offline   Reply With Quote
Old 04-01-2021, 07:54 PM   #42
superchevy
Got big-block?
superchevy's Avatar
Thank you. I finally got all the parts in to start to get it back together...got the lower and upper a-arms installed with the new MOOG big block springs...tomorrow evening hoping to get all new steering parts installed along with the sway bar.
build thread
build thread
Old 04-05-2021, 07:26 AM   #43
superchevy
Got big-block?
superchevy's Avatar
Got the new steering and brakes finished up...well mostly, lol
build thread
build thread
Old 04-05-2021, 07:31 AM   #44
superchevy
Got big-block?
superchevy's Avatar
I was now able to set her back down on the ground and add about 800lbs of weight to compress the new big block springs enough so that the upper control arms came off their bump stops and i could torque everything to spec...
build thread
build thread
Old 04-06-2021, 07:19 AM   #45
superchevy
Got big-block?
superchevy's Avatar
not much done today...wheels back off...got the new calipers and brake hoses installed...progress
build thread
build thread
Old 04-06-2021, 07:32 PM   #46
Corts60
Just here to tinker
Corts60's Avatar
Great work! Man that is one clean cab to start with.
Old 04-07-2021, 08:09 AM   #47
LT7A
You do very nice work. Very clean installation.
Old 04-10-2021, 05:41 PM   #48
superchevy
Got big-block?
superchevy's Avatar
Thanks guys! Yes, this cab is soooo clean...
build thread
build thread
Old 04-15-2021, 07:00 PM   #49
superchevy
Got big-block?
superchevy's Avatar
ok, got some more brake work done...specifically finished running the new InLineTube hard lines front and rear...new brake booster and master cylinder installed...
build thread
build thread
Old 04-15-2021, 07:02 PM   #50
superchevy
Got big-block?
superchevy's Avatar
next up, the big block engine stands and new mounts installed...
build thread
build thread
