03-28-2022, 12:47 AM | #26 |
Junior Member
Re: My’56 Chevy Shortbox Build
I had read that the GM tubes are thinner than the Ford so was going to watch that. Thanks
04-04-2022, 12:48 PM | #27 |
i love a good double triangulated 4-link!
have you seen the 4-link calculator spread sheet? here's a link to d/l it if not. use it, trust it, design with it. small changes can be the difference between a good set-up and a great one! i always suggest making the upper link frame mounts with adjustable holes so you can change the anti-squat if needed. set up some holes below 100% estimate, and some above, or around whatever range you are shooting for. https://www.crawlpedia.com/files/4_link_calculator.xls when i did the trailing arms for my 55 i wasn't going to run it, did, and 6" longer links made a HUGE change to a more correct geometry. |
04-04-2022, 01:31 PM | #28 |
Junior Member
Thanks, yeah I was watching some vids on that, was going to pre-heat as I went to avoid that.
04-04-2022, 01:35 PM | #29 | |
Junior Member
04-05-2022, 11:47 AM | #30 | |
another thought, i've always gone on the theory that the upper to lower links should be ~30deg or more vs the upper links to the frame or each other. probably either will work, and my double triangulated 4-links have been in jeeps. Last edited by 6DoF; 04-05-2022 at 11:53 AM. |
04-05-2022, 04:28 PM | #31 |
everybody got a 56! I need to work on mine.
me too, i have done a bunch of 4 links on bagged trucks with upper triangulated 4 links and that is the rule of thumb i used.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
04-06-2022, 03:25 PM | #32 |
doing the bags was nice, only having to account for 1/3 the travel and limited articulation was great!
