Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 01-24-2022, 12:39 PM   #26
BigBird05
Re: 1971 K5 Blazer - down under
If that is an "S" as suspected. It would be a pre-December St Louis build.
BigBird05 is offline   Reply With Quote
Old 06-16-2022, 08:34 AM   #27
68ls1
68ls1's Avatar
Been a while
So a little while ago the shop pulled off guard, door, carpet etc to check out the extent of rust and lower door hinge issue. Photos attached.
I finally got an opportunity to go and see in person today.
My original plan was to leave as was, fix issues, put on road and drive for a bit.
After seeing it today, and a chat with main man (Shane), I have decided to go ahead and strip it down, remove paint and then body work and paint.
As Shane said, that the rocker and lower hinge appear to be only areas that need rust or panel repair, his words "that is nothing". Floor looks really solid, just some holes to fill, guard was really good, Pretty sure quarters will need some remedial work, so in the scheme it is in really good shape, so let's get on with it.
This has changed my parts requirements in the short term.
Now I need to decide on color. Had always wanted white, but I kinda like the original light yellow. Have also thought about a lighter blue metallic. Want to go with Highlander interior, so
White with grey plaid
Light yellow with grey plaid
Blue with blue plaid
68ls1 is offline   Reply With Quote
Old 06-16-2022, 01:39 PM   #28
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Good to see an update. When life hands you lemons, make lemonade: I'd go the original light yellow color. That's my favorite 72 color. Grey or orange plaid would be stunning. Any plaid color paired with that light yellow would be great (even green).
Old 06-16-2022, 01:41 PM   #29
1rippen6
I'm a big fan of the light yellow also!
1rippen6 is offline   Reply With Quote
Old 06-16-2022, 07:49 PM   #30
68ls1
68ls1's Avatar
May have come across wrong, but I am so pleased that there was no other areas that need metal replacement. The fact it is in such good shape, and will require minimal work/time in body prep is the reason I am going this way, so will only assemble once. I didn't want it disappearing in to paint jail.
Here are some images of 70 Camaro they did a build for me
Old 07-22-2022, 03:04 AM   #31
68ls1
68ls1's Avatar
Tear down completed. No nasty surprises, paint removal next week. The frame is possibly better than I had hoped, just had to remove the tow hitch that had been welded on. Need to make brackets to hold front anti sway bar, a good clean and then off for powder coating.
Can anyone suggest a supplier for Truckworld seat covers. I am after a white set with grey plaid.
Old 08-09-2022, 10:39 PM   #32
68ls1
68ls1's Avatar
Back from blaster, no surprises . Doesn't appear to be any large accident damage
Name:  Drivers quarter.jpg
Old 08-09-2022, 10:41 PM   #33
68ls1
68ls1's Avatar
Drivers rocker and lower A Pillar is by far the worst area.
Name:  Drivers Rocker 1.jpg
Name:  Drivers Rocker 2.jpg
Name:  DRivers lower A Pillar.jpg
Name:  Drivers toe board.jpg
Old 08-09-2022, 10:42 PM   #34
68ls1
68ls1's Avatar
Passenger rocker, looks like will just need to replace outer
Name:  Passenger Rocker top.jpg
Name:  Passenger lower A Pillar.jpg
Name:  Passenger toe board.jpg
Old 08-09-2022, 10:43 PM   #35
68ls1
68ls1's Avatar
and rear of bed, will make up some patches to fix
Name:  Rear bed 1.jpg
Name:  Rear Bed 2.jpg
Old 08-10-2022, 07:29 AM   #36
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Good deal. How were the doors?
Reach out to SoCoC10 regarding seat covers.
Old 08-10-2022, 08:25 AM   #37
68ls1
68ls1's Avatar
Doors are really good, expected back from media blasting tomorrow. As you can notice no media blast on large flat surfaces, will hand strip those.
Thanks Pete for lead will contact him
Old 08-31-2022, 03:04 AM   #38
68ls1
68ls1's Avatar
Pics of doors, bottom corners were worse than expected but are an easy fix. Someone was good at hiding holes . Bottom of doors are as good as i could hope for
Tailgate was also pretty good, just a small depression on inner to sort.
There is a small dent around tail lights on passenger side, on the lower section. Will unpick quarter, so can do the repair from the inside
All in all still very happy overall with the body.
Dropped engine at rebuilders, will tear down and report. Had a remanufactured tag on rear side of block so assume it has had at least one rebuild.
If rebuildable, plan is around 9.5 to 1 compression using AFR Eliminator heads (or like), small cam, Comp Cams X4260HR, Edelbrock Performer EPS manifold and Holley Terminator Stealth with Hyperspark ignition
Local gear specialist picked up transfer case, will pull it down and put new bearings and any other items it may need. Thinks the damaged rear yoke might be able to be machined.
I have Turbo 350 to drop off to my local transmission guy to recondition tomorrow.
Waiting on lots of parts currently shipping via ocean freight. Alcan springs should be available around Sept 9th
Pete do you have pics of transfer case colour, or where on your rebuild thread I can find, so I can forward to the rebuilder?
Old 08-31-2022, 08:59 AM   #39
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Not bad at all. Glad the sheet metal won’t be too much of a barrier toward the rebuild.
Folks have said Chrysler red is a close match to the red used to paint the transfer case. I believe that can be had in a spray can too.
Old 09-08-2022, 08:58 AM   #40
68ls1
68ls1's Avatar
After unpicking quarters. more rust spots were revealed. Every corner of panels had some amount, and behind door strikers. Lower A pillar on passenger side needs some work. More filler than expected,
Nothing that can't be sorted pretty easily for these guys. Inner rockers done. Hope to have all the tub sorted by end of next week.
And I'll know i have a rust free, straight Blazer
And this is a lot of filler. Panel will be repaired from the inside.
Old 09-08-2022, 09:52 PM   #41
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Making quick work of the body. Nice!
Old 09-14-2022, 03:08 AM   #42
68ls1
68ls1's Avatar
Some more progress pics
Old 09-16-2022, 10:11 PM   #43
68ls1
68ls1's Avatar
More progress pics
Old 10-10-2022, 11:49 PM   #44
68ls1
68ls1's Avatar
So this is what we salvaged from engine, currently at machinist, and the goodies going in to it
Transfer case done (so is Turbo 350, but no pics)
Also a lot have parts have arrived, just waiting on shipping forwarder to say come collect. Frame at powdercoaters.
Hopefully next update will be the reassembly of chassis and drive train install
cheers Roger
Old 10-11-2022, 06:59 AM   #45
Louisvillekytruck
Nice work looking good
Louisvillekytruck is offline   Reply With Quote
Old 10-11-2022, 08:16 AM   #46
68ls1
68ls1's Avatar
thanks
Old 10-28-2022, 06:19 AM   #47
68ls1
68ls1's Avatar
We have come a long way
Old 10-28-2022, 09:31 AM   #48
best view
I hope you paint it light yellow
best view is offline   Reply With Quote
Old 10-28-2022, 09:32 AM   #49
best view
And I vote for green hylander
Old 02-01-2024, 08:42 PM   #50
68ls1
68ls1's Avatar
Progress pics, back as a rolling frame, engine, trans & transfer case, all rebuilt and in frame. Waiting on some bushes to fit Gen 2 front sway bar, fuel tank in fab shop getting in tank pump for fuel injection fitted.
