Old 02-09-2022, 12:29 AM   #26
static80
Re: Time for a Canadian build thread
OK, I made an attempt at folding over the rear corner of the shortened box side. First step is to trace the box corner and make a 1/4" plate form. Second step is to draw your bend line and tack the form into the bed. Then start lightly tapping the edge over. Lots of small light taps and try to bring it over evenly tapping the high spots.
static80 is offline   Reply With Quote
Old 02-09-2022, 01:34 AM   #27
SkinnyG
SkinnyG's Avatar
Yeah - the wrinkles and taps are how you can shrink the curves.
Looks awesome.
We should go do smoke shows together when they're both done, eh?!
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 02-12-2022, 07:16 PM   #28
66C10LB
Looks like the tapping over of that bedside flange is working nicely over the 1/4 inch plate. Is the plate staying in place OK while tapping?
66C10LB is offline   Reply With Quote
Old 02-12-2022, 10:05 PM   #29
static80
I tacked the plate to the bedside before I started tapping the flange over so that it will stay in place.
Old 02-12-2022, 10:11 PM   #30
static80
Fit the back corner on and I'm not disappointed. One thing is that I couldn't tack the flange for the top 2/3 because there is no access with the stake pocket there so I had to put the tacks on the outside. I'm tempted to tack all the way on the outside and hide the seam...
Old 02-12-2022, 10:17 PM   #31
static80
The front is a bit different. The flange that's tipped over is 3/4" instead of 3/8" and it's past 90 degrees. I made the template 1/4" undersized and wrapped a 1 x 1/4 flat bar around it. Then I put a bevel on the flatbar so that I could tip the flange past 90 like original. I also had to cut a couple of the tight bends so that I didn't loose the crispness of the shape on the box side.
Old 02-13-2022, 12:05 AM   #32
caseyjones
That looks really good!
My understanding is that guys will pull apart the rear cap from the stake pocket to get access to tack everything together from the inside of the box sides. It looks like there are spot spot welds along the edge that mates up with the tailgate. After doing all the work to tip that edge it would be a shame to weld that seam up solid...
caseyjones is offline   Reply With Quote
Old 02-19-2022, 10:07 PM   #33
static80
As suggested I pulled the stake pocket and rear cap apart for the drivers side. The drivers side had some damage so pulling it apart had the added benefit of letting me straighten out the cap. I got the drivers side shortened up but haven't finished welding and stuff because I have to spend the time shimming and aligning all the body panels before I totally commit.
I had to loose the braces that attach above the wheel arches because of tire clearance so now the drivers box side isn't as straight as I would like. I guess I'll have to design some other kind of brace to try to remedy that.
And then because the 96 Camaro already donated it's transmission to this truck I figured I'd see if the steering rack would be usable as well. Still some figuring to do but it looks like I might be able to shorten the inner tie rod ends and flip the outers to the underside of the steering arms it might work. I'm on the search for some disk brake spindles that I can use to mock up the steering.
