Old 03-03-2022, 01:36 AM   #26
Boog
laying low
Boog's Avatar
Re: dies randomly at idle in gear
It's been a couple weeks now and I haven't driven the truck much but I am happy to report it is running night and day different.
The manual idle speed adjustment solved the stalling issue and the new distributor took care of the rough running. It starts instantly and take off is cleaner and crisper if that makes sense. Before it was a bit froggy on take off.
I've got a couple more things I want to test and replace if only for their age and it should be like new again.
I believe those shocks are originals too!
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 03-05-2022, 04:13 PM   #27
Boog
laying low
Boog's Avatar
Thumbs up Re: dies randomly at idle in gear
I got around to testing that TPS and it was off. This model is not slotted for you to adjust it so I dremmel'd the two holes a bit and dialed it in. All good now.
The voltage gauge has dropped several times since I've had it but came back up and the battery is new so it's been ready to go but today the gauge dropped to near 10 or so while driving and did not come back up. When I got home the battery tested 11.98 v but it wouldn't even turn over. I cleaned the cables, jumped it and let it run for a while. Wasn't charging so I wiggled the alternator wires around and found the small gauge single wire plug on the back of the alt wasn't making good contact. If that happens again I'll adjust that plug.
Boog
primer is finer
Old 03-05-2022, 04:59 PM   #28
Just call me Sean
Just call me Sean's Avatar
I had a large zip tie holding that plug on mine for the longest time, until I finally replaced the plug.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 03-05-2022, 09:04 PM   #29
Boog
laying low
Boog's Avatar
The plug on mine isn't broken. It had no reason to lose contact. But it did. I'll most likely see that again.
Boog
primer is finer
Old 03-05-2022, 10:43 PM   #30
Just call me Sean
Mine wasn't broken either.
Old 03-15-2022, 06:56 PM   #31
Boog
laying low
Boog's Avatar
I bought a new distributor from Napa for this truck. All the Napa brand specifics in the description and all. The box is all colored label Napa. Inside I find included is this Carquest info. Just seemed funny.
Boog
primer is finer
