12-29-2021, 06:28 PM | #26 |
Re: Interest in Dummy Gas Cap Filler Neck?
I am definitely interested in one.
1970 Stock SWB C10 without A/C 1970 Stock LWB C10 CST with Factory A/C |
12-29-2021, 08:15 PM | #27 |
I too believe patched holes take away from originality, it looks bare without it sticking out. I think your original looked great and without seeing under your grommet I'm not understanding what's going on. However for those that are still in body work stage it would be rather easy to have a welded flange on inside that could be tacked to inside of cab for mounting versus the retainer style. With that option the neck could be as Long as you wanted.
12-29-2021, 09:12 PM | #28 |
Here are some images that should help show how the filler neck is attached. It is clamped onto the grommet. The step in the filler neck pushes on the outer lip of the grommet, and the welded bracket pushes on the back of the grommet. I've also included some images of what it would look like with a spacer that would shift the cap farther away from the cab. I think the spacer would make the filler neck look too fat. Opinions?
12-29-2021, 10:20 PM | #29 |
Looks good as well!
12-29-2021, 10:46 PM | #30 |
BlahBlahBlah
If I was ever to move a tank I would want a dummy one. Why don't you measure one that's on a truck now and go with that length?
12-29-2021, 10:48 PM | #31 |
I’d take one.
Posted via Mobile Device |
12-29-2021, 10:49 PM | #32 |
It has to clamp against something. That's the reason it is sticking out less than stock. If I simply make it stick out the stock length, then it would be loose without adding a spacer on the outside.
12-30-2021, 10:44 AM | #33 |
Any reason you couldn't add a couple of washers or a small spacer between the filler neck part and the bracket where the bolt goes through to extend it out?
1970 Chevy CST/10 1970 Chevy CST/10 1972 Chevy C/10 1972 Chevy Suburban K/10 2019 Silverado 2500 Duramax Kevin |
12-30-2021, 11:05 AM | #34 |
I definetly think you have received the interest in the filler neck! Now it seems many would like it a bit longer, take your time and think it over. Maybe possibe maybe not! I have not looked at filler neck your using or how grommet fits the tube so I do not understand the adjustments. Would a large rubber style washer fit between cab and Grommet? All I know is when finished I would like a neck that holds in place. Yours looks great and will do the job.
12-30-2021, 12:29 PM | #35 |
The problem with doing that is that the larger portion of the filler neck that is outside would no longer be clamped against the grommet, so the filler neck would just be loose.
12-30-2021, 12:36 PM | #36 | |
12-30-2021, 01:08 PM | #37 |
i would be in for one, just the way you have it.
12-30-2021, 01:35 PM | #38 |
I recommend that it not be so deep on the inside, have a wall just under the cap to make it idiot proof. I am sure that somebody not familiar with the truck would still try to fill it there since the gas pump nozzle would still fit inside and then have gas shoot back at them.
1969 Custom Camper C20; Factree Air, 350/TH400/Dana 70U with C30 wheel cylinders, Disk brakes, H4 conversion, headlight relay mod, 3G 135 amp alternator. 7500 GVW |
12-30-2021, 01:37 PM | #39 |
I love the inspiration (and would normal jump in) but I'm having to go a step further than this. I plan to to convert mine to a power inverted 120v outlet inside the dummy gas fill. With a dual battery bank setup, it should be able to drive a sound system, compressor or other tools & accessories when parked for events. If you came up with that kind of setup, it would be worth chipping in for $400-500... even if it didn't include the inverter or dual battery setup.
Regardless, nice work.
1971 GMC C15 Sierra Grande SWB 1972 Chevy C10 Custom Deluxe LWB 2018 GMC Yukon Denali |
12-30-2021, 02:01 PM | #40 | |
12-30-2021, 02:03 PM | #41 | |
12-30-2021, 02:28 PM | #42 | |
Made in America by Americans |
12-30-2021, 02:30 PM | #43 | |
Edit: I found it. https://www.amazon.com/Weatherproof-.../dp/B07XF5D8HK Last edited by pjmoreland; 12-30-2021 at 02:55 PM. |
12-30-2021, 03:16 PM | #44 | ||
PJ, this would save me a lot of time and effort. Consider me part of the group!
12-30-2021, 05:12 PM | #45 |
At the body shop.
I want a spring prank snake under the cap
" That didnt make it any newer " " Dont antique the equipment " |
12-30-2021, 05:42 PM | #46 |
12-30-2021, 05:47 PM | #47 |
I modified the design to work with a power outlet. There would need to be two versions of the clamp plate though for those who don't want the power outlet. Here are some images of the power outlet version.
12-30-2021, 05:49 PM | #48 |
Here are some images of the regular non-power-outlet version.
12-30-2021, 06:06 PM | #49 |
another option, just tack weld the gas cap on to avoid any accidental fuel nozzle dings and gas
1967custom |
12-30-2021, 06:29 PM | #50 |
70+ ( Old Skool Club )
Or JB Weld it to the filler neck
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
