07-12-2023, 11:48 PM | #26 |
GEARHEAD
Re: 1971 Buick Boattail Riviera
Tires came last Thursday, got them mounted and on the car Friday. So off we go and about 1.5 miles and ran out of gas. Lol. It was not running great, it was misfiring and not much power. I pulled over to the shoulder near the end of someone's driveway along the highway. I walked to the house, noticing a gas can by a Chevy luv being worked on. Nobody home but the dog. I borrowed the gas can, put a couple gallons in the Riv and head back home.
I add another couple gallons from one of my gas cans and check the timing again. I finally get the timing somewhere close to 8 BTDC. The spec is 4 but come on, nothing is going to run good with that little advance. But I also noticed that the vacuum line to the advance canister didn't have any suction. On a lot of these old GM cars there was a temperature vacuum switch with ported vacuum. Mine was stuck shut. So I ran the vacuum line to another manifold port. I loaded the gas cans into the trunk and try again. Much better results this time. I actually made it to the gas station. It had a bit more power but was still misfiring. I filled the gas cans and returned the borrowed one fuller than when I took it. It did drive nice though. Good smooth ride, the transmission worked great, the brakes were good. Oh yeah, when I took the wheels off to get the new tires on I inspected the brakes. Everything looked good. The pads and shoes are worn fairly evenly but have a lot of miles left in them. No leaks or broken/loose bits. I already had a pertronix ignition conversion kit ordered so I didn't mess with the points anymore. I installed that on Sunday and it was a huge improvement. The misfiring is pretty much gone. I considered putting an HEI distributor in but for a buick 455 they are really expensive compared to a Chevy one. Like $300 from summit. I got a good deal on a scratch and dent pertronix kit at Amazon for $70. The Sunday drive went much better. More power, smoother running. Monday I installed the new PCV and grommet. The rattling noise from the driver side exhaust is some kinda valve thing that is actuated after it warms up. Today I replaced another vacuum line and rerouted the other vacuum lines from the temperature switch. And also found why the vent fan wasn't running. Just a bad ground. Easy fix. Next up is replacing the belts, and thermostat. Then put more miles on it.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
07-14-2023, 06:35 AM | #27 |
That Riv sure is solid for where you're located...
Robert |
07-20-2023, 11:15 PM | #28 |
GEARHEAD
Put some new wipers on. Tried for days to find 18" refills with no luck. I got some rain x beam style but they are ugly, black and have a big clunky mount. I'm keeping the old chrome ones around in case I find refills.
Also replaced the thermostat with a 180f compared to the 196f original. It held in the 180-190 for a while then crept up to 210 by the end of the 20 mile drive. Not great considering it was a cool evening. I'm going to have to see if I can find a radiator shop and flush the system. It ran decent though and I had a pleasant drive. The odometer hit 52222.2 and I really don't know if it's rolled over 100k yet. Wouldn't be surprised either way.
08-20-2023, 07:28 PM | #29 |
GEARHEAD
It's been a busy month. I work on the riv occasionally. My daughter got married a couple weeks ago. Sold a couple parts cars. Worked on the cobra a little. Helped a friend swap the transmission on his square body suburban. Did that pesky job thing to keep the bills paid. Etc. Etc.
I have been trying to flush the coolant system off and on the past couple weeks. It helped quite a bit but during the last longer drive it still creeps up to 200+. Going to keep flushing it and see what happens. The cleaner doesn't cost much. Changed the oil for the first time today. When I got the car it had clean unused oil in it. I added some marvel mystery oil to it and drove with that a while. The oil came out dirty but no moisture and still very good viscosity. Put the same mix back in it. I'm going to add some additive to the gas also and see if it helps the valves. The compression test didn't improve yet and for the one very weak (45 psi) cylinder I used the endoscope and I could see pitting on the wall. Probably had some water in it at some time. The spark plug actually looks good on it. Today I wanted to see if the cruise control would work. I got a new ball stud connector for it since the original plastic one melted on the intake manifold. The dang exhaust crossover really gets hot. Didn't find a direct replacement so I used a steel one and made it work. Then found a loose vacuum connection on the cruise. Then found no vacuum at all to that system. Started tracing vacuum lines again and found that the line from the carb to the vacuum pot on the firewall wasn't connected. Replaced that line but still wasn't getting vacuum to the cruise. I bought the service manual off ebay and found the right routing and got everything connected properly. The ventilation system works now! The fan worked intermittently and I found a bad connector on the high speed relay. The controller on the dash is working now. The ac compressor works and there's still some pressure in the system but it doesn't blow cold air. Old r12 system that was never converted but I think I can get it working. I had intermittent power to the cruise unit when I push the button on the stalk. Going to try and follow the service manual troubleshooting steps and see if I can get it working.
08-28-2023, 09:46 PM | #30 |
GEARHEAD
The original AC system was intact and still had pressure in it. It's still R12 which is expensive and hard to get. But I learned that there's an alternative other than R134. Look up duracool or 12a refrigerant. There's YouTube videos and it's widely available. You can get it on Amazon. I bought a kit off ebay that had refrigerant with dye, sealer, oil, the adapter and instructions.
If you look up the SDS for 134 you'll find it's basically flammable gasses. 12a is pretty much propane and something else like butane maybe. Anyway the 12a will mix fine with R12 so you don't have to evacuate the system. Just need the adapter for a 134 connector to put on the R12 system Schrader valve. My system is a 4.5 pound fill which is bigger than most so I opted to get extra cans of 12a. I started with 23psi still in the system, just a little low after sitting 20+ years. I started with the can that had the oil in it, figuring it wouldn't hurt. Then added the sealer, then straight 12a. Added 5 cans total and the pressure came up to 32 and blows cold. Couldn't be simpler. This stuff is more efficient than 134 and a larger molecule so less prone to leaking. It cost me about $100 with shipping and I have an extra can if I need to add more. I put the new trunk seal on the other day. Had to adjust the catch to get it to latch with the new seal. Hopefully I can tighten it down over time because it sits up higher than the quarters now.
08-29-2023, 09:33 AM | #31 |
Such a nice old ride. Loving these updates.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2020 Toyota CH-R 2020 Acura MDX |
08-29-2023, 01:28 PM | #32 |
I'm not sure if I want to see that Cobra run or this Riv's paint rubbed out first.
You have a lot on your plate. I hope it all stays fun for you.
'71 C/20 350/T350. |
08-29-2023, 09:31 PM | #33 | |
GEARHEAD
I always have multiple projects going. When I get tired of one or hit a snag or waiting for parts I always have something to play with.
09-28-2023, 06:09 PM | #34 |
GEARHEAD
Started putting some time into this project. The starter has been hanging up, the solenoid clicks but doesn't engage with the flywheel and crank. Took it out and bench tested it, nothing wrong that I could see. Lubed it and reinstalled. So far it's working.
I've been wet sanding with the random orbital. Did more of the hood, got the roof and the tops of the rear quarters and half the trunk lid. I'm pretty sure I know what's going on with the paint. I thought the hood was extremely oxidized but now I believe it was primer. The car was resprayed once. Not a good job, probably one of those cheap earl schibe jobs. The color you see on the bottom half is a darker shade than the original. On most of the upper area that darker paint has oxidized off. You can see patches here and there but it's very thin. Then there's a brown primer over the factory paint. I'm basically removing a respray job with a buffer and 1500 grit. Fun times. In some of the pics you can really see the transition of darker newer paint, brown primer with fish eyes, and factory paint. I think I'm pretty set on doing the standard LS swap. I've already got a couple engines, an LM7 and an early 6.0 with iron heads. I have a set of rebuilt heads on the shelf. So probably just go through a short block, swap the cam and valve springs, go through the factory harness and do it as cheap as possible. Looking for a used 4L80 now.
09-30-2023, 12:32 PM | #35 |
That hood's as big as some backyards LOL.
An LS/4L80 would drastically change the character of the car. After careful deliberation, I say "go for it!".
09-30-2023, 10:03 PM | #36 |
I'm a big time LS fan.
A well built 4L60E will handle a semi stock 6.0 quite well. May be a 2800 stall converter depending on you cam? So let me spend some of your cash. 24 tooth crank reluctor 6.0 iron block. So you need one ECM for the engine and trans control. I like and use the OEM ECM's but some like the Holley stuff. Add L92 heads, upgraded valve springs, upgraded push rods, LS7 lifters and maybe a truinion rocker arm upgrade? LS3 intake and 42 .lb injectors. LS3 DBW throttle body. Cam wise a 220I/225E. Around .600 lift. 114 CL? 3.73 gear wise. Headers? I'm up in west central MN if you want to talk LS swaps. Good luck with your project. |
10-01-2023, 04:57 PM | #37 | ||
GEARHEAD
There is almost zero info out there on doing an LS swap in these cars. Several builds on earlier Rivs but not the boattails. They are an E body and the other brands E body cars are front wheel drive. So no off the shelf mounts are designed for it. But it has a big engine bay, the steering is in front of the crossmember like a GM truck, rear sump oil pan, similar exhaust manifold outlets as a truck. It's probably not a big difference from the 454/TH400 swap I did on the crewcab. I can get universal mounts and just weld the tabs where they need to go or make my own. Not sure I'll jump into this this winter or not. I tend to get into things while other projects are waiting and I do want to get the cobra at least ready for paint if not completely finished. And I would like to finish up the crewcab too, which needs body work and paint and the heater/AC system done. So I "should" be letting this be as is and just drive it until I'm ready to tear into it. Anyone reading this that is familiar with other projects of mine knows everything I have is a long term project and I rarely give up on them. On another note, the last time I drove the car I heard a rattling sound from the front of the engine. Fan/water pump pulley was loose. Weird because the bolts were tight. I took it apart the other day and the pulley was missing the center, like it had been hacked out for some reason. The bolt holes were a bit oblonged out, the bolts were damaged on the threads from it rubbing. So I bought some new bolts and figured I would try and just bolt it back in and see if it would be tight enough but then I looked at the nose of the water pump and found the middle of the pulley. Never seen one break before. A friend is going to see if he has one on a 455 he has. Otherwise I'll have to search around on my own.
10-08-2023, 08:17 PM | #38 |
GEARHEAD
New radiator came last week. I ordered an aluminum 3 row with a shroud and fans. I'm saving the shroud and fans for after the engine swap. It was only $50 extra for that. Last time I got the radiator without the shroud and it costs like $100 or more just for a shroud. The new radiator fit pretty good. I did cut out a small area by the radiator cap for clearance.
Refilled the radiator with antifreeze and then stopped, momentarily because I don't have a good pulley for the fan. I should next weekend but what about now? So I welded the center back into the broken pulley and installed it. I don't trust it for anything more than a short drive and that's what I did. I let it warm up and vent the air out, then drove it around. It stayed between 180-185. When I got home I kept it idling for another 10 minutes or so and it didn't go over 185. That's without the fan shroud. I didn't put it in because it's easier to put the fan and belts on without it in the way. I gotta replace the fan and pulley anyways once I get them. Another problem fixed for a couple hundred bucks.
11-05-2023, 12:47 PM | #39 |
GEARHEAD
Almost a month later I finally found a good pulley. It's kind of odd that you can't really find pulleys for sale new other than aftermarket. I tried one of those too, off ebay. Aluminum pulley that was too large of diameter. The one my friend had was on a 71 engine which has a short water pump and doesn't fit. I called every junkyard within an hour with no luck. So I grabbed the broken pulley and went to the local junkyard. He had already told me he didn't have any old 455s but I figured I could find something that would fit if I looked around.
He had a half barrel full of miscellaneous pulleys and eventually he pulled one out that matches. It has a part number on it that said it was for an Oldsmobile 3.8l 6 banger. OK, don't care as long as it fits mine. Oh and just $20! And I got a refund for the ebay one that didn't fit. Some sandblasting and paint made it look presentable. There is an aluminum spacer between the pulley and fan and it really didn't fit right. The in the middle wasn't quite deep enough. Someone put a narrow washer in as a spacer. Not thin, just narrow like a lock washer but not split. I think that's why the pulley broke. Not enough area to spread the load. I drilled the spacer a bit deeper and sanded the face down a bit flatter. So the cooling system is fixed. I stopped by a guys place here that has an RV I'm going to pull parts from for my free candy van. Wanted to show him this beauty. has another LS (LM7) with about 130k miles he'll sell me for $100. Deal! Driving the riviera it has a miss, likely from the nearly dead cylinder and the other 2 very weak ones. It acts like it's surging on the highway and IDK if it's just from the misfiring or if the tranny is momentarily slipping. I haven't done anything to it yet beyond checking the fluid level after I got it home. I just don't trust it for a longer drive yet. Needs more work.
11-05-2023, 05:48 PM | #40 |
As said I'm big time LS fan but I would be very tempted to pull the Buick engine apart and see what's good and bad if it's a 455. I would not rebuild a Buick 350.
11-05-2023, 09:05 PM | #41 | |
GEARHEAD
I get it, everyone does LS swaps in any kind of vehicle. I'm not doing it because I think it would be cooler, it's not. It's pragmatism, long term enjoyment of the car, simple and affordable. I've only done one LS swap, into my crewcab, and totally worth it.
