04-16-2024, 07:51 PM | #26 | |
Re: 1967 Chevy 327 Alternator Setup
Clay
Clayton Sikes Peoria, Arizona 1967 Chevy K20 Build Thread: https://67-72chevytrucks.com/vboard/...d.php?t=841272 |
04-16-2024, 10:02 PM | #27 |
Who Changed This?
There are sure to be videos online about clocking your alternator. It merely involves removing the 4 screws attaching the two halves together, pulling them slightly apart to allow rotation, and putting the screws back in one the rotation is complete. Careful, because if you go to far apart you'll have to deal with reinstalling the brushes in the holder.
04-16-2024, 10:35 PM | #28 |
I am wondering if the valve covers are squared off more than 67 originals? This may account for some differences.
Does your stock set up have the cast iron water pump pulley? I have only read about this pulley and have never seen one in person. A better question is you goal to make it OEM stock or to just get what you have functioning? Last edited by Accelo; 04-16-2024 at 10:52 PM. |
04-17-2024, 07:44 AM | #29 | |
I was able to reclock it. It gave me a little more room, but it still hits the valve cover. I will post up some pictures later. Clay
04-17-2024, 07:47 AM | #30 | |
I was wondering about the valve covers too. Unfortunately, I don't have the ones that came on it any more so I can't compare, but that may be one of the issues. My pulleys are GM, but not the cast iron ones. As far as goals, I am going for a stock look, but I am not going for factory. Basically, I want the truck to be a driver in a mostly stock manner. I was looking at this alternator setup as well and that brace is available in a reproduction. Clay
04-17-2024, 11:01 AM | #31 |
Your valve covers look to be the same as the stock covers that were on my 283. I went and measured the height from the flat on the top to the flange at approximately 2-3/8".
Also, a few more photos of the alternator position. My engine has a 6-3/4" crank pulley and not knowing what size is on your 327 suggesting a belt would be difficult. Also, I ran a string along the topside of my upper bracket and it measures approximately 14". Not sure if any of this helps but hope it does some.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2020 Toyota CH-R 2020 Acura MDX |
04-17-2024, 11:11 AM | #32 |
Looks like your w/p and crank pulley line up. Their are several different offset pulley's for the alternator. You may also be able to add a spacer behind the one you have. However you may run out of threads. Some of the factory pulleys are recessed on the end for this very reason.
The valve covers are likely the same height but the corners are rounded more. I was thinking this may be the difference? Note: The upper alternator brace bolts to the rear of the alternator. Last edited by Accelo; 04-17-2024 at 08:11 PM. |
04-17-2024, 11:45 AM | #33 | |
04-17-2024, 05:49 PM | #34 |
Who Changed This?
Looking at the picture of Accelo's and 67C10's setups, I see that the adjustment bracket for the alternator bracket mounts to the intake manifold, and it is a lot straighter. Maybe that setup would be better?
04-17-2024, 08:05 PM | #35 |
"I see that the adjustment bracket for the alternator bracket mounts to the intake manifold, and it is a lot straighter. Maybe that setup would be better? "
I believe you may be looking at the wrong picture. This is pg 2. His is on the intake manifold, see picture on pg 1. My apology if I am wrong on this. Last edited by Accelo; 04-17-2024 at 08:12 PM. |
04-17-2024, 09:22 PM | #36 | |
Who Changed This?
04-18-2024, 09:23 AM | #37 |
Clay, did you figure this out? I'm going to get you a picture Saturday of an original 67 327 set up. I might also be able to get you the brackets off a 68 307 if they are the same. But, won't be able to look until Saturday.
04-18-2024, 01:10 PM | #38 |
subd been dealing with this same issue since forever with headers im using a Mr. gasket bracket attaches to the head with the header bolts I have clocked the alternator too still very little adjustment on the belt to the point of having to finagle the pulley on with the belt around next size down is to short and gets the alternator up against the valve cover and on and on and on
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 Last edited by zicc1835; 04-18-2024 at 01:19 PM. |
04-18-2024, 01:20 PM | #39 | |
Clay
04-18-2024, 01:27 PM | #40 | |
I'm not sure why your alternator pulley doesn't line up with the crank pulley. Here's my setup using a lower cast bracket that mounts to the head. I know your heads don't have bolt holes, but maybe this picture will help someone else.
Mike 1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 04-18-2024 at 01:36 PM. |
04-19-2024, 01:12 AM | #41 |
I don't have a '67 or a 327, but I do have a different type of Alternator bracket on my '71 GMC Jimmy with a 350 and SM465 4-speed...
Also, I upgraded to the 12SI internally-regulated Alternator when the O'Reilly warranty part EVRs kept being dud after dud. Short water pump. Semper Fi.
04-19-2024, 12:06 PM | #42 | |
Thanks.
Mike 1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
04-19-2024, 05:04 PM | #43 | |
I usually use a hammer handle to get leverage before tightening the Alternator bolt to the right belt tension. I think the Alternator body would contact the valve cover without a tensioned fan belt. Also the type 12SI is slightly greater in diameter than the type 10 [w/ external regulator]. I'll try to shoot another picture later.
04-20-2024, 07:46 AM | #44 |
Here are the pix I promised:
