Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 11-20-2014, 05:02 PM   #476
rudyyloverboiii
Re: Power Steering Adapter Plates
Hey capn i need the adapter plates
rudyyloverboiii is offline   Reply With Quote
Old 11-21-2014, 12:11 AM   #477
Captainfab
60-66 Nut
How many adapter plates do you need?
I'll send you a PM.
Old 11-27-2014, 04:11 PM   #478
Ronw435
Ronw435's Avatar
Hey Captainfab I am in need of one of your adapter plates for power steering. Do you also know where to get the splined end of the rag joint for the 71 power steering box? My 65 C10 is a smaller diameter than the 71. Also I would like to get the rag joint you showed to weld to my tube with the adapter plate.
Ronw435
Ronw435 is offline   Reply With Quote
Old 11-27-2014, 10:06 PM   #479
Captainfab
60-66 Nut
So you need the steering box adapter plate and the tube and flange? I will send you a PM with ordering and payment info.
You should be able to get the rag joint at your local auto parts supplier.
If for some reason they can't get one for you Summit has them.
http://www.summitracing.com/search/p...ing%20Couplers
Ronw435
Old 12-05-2014, 11:57 AM   #480
Ronw435
Ronw435's Avatar
Just received the power steering plate and rag joint adapter. Great looking products there Captain. Definately quality items. Great instructions!
Thanks Captain and the shipping was fast.
Look forward to getting it all installed.
Ronw435
Old 12-06-2014, 02:41 AM   #481
Captainfab
60-66 Nut
Thanks for the compliments Ronw435
Old 12-14-2014, 06:08 PM   #482
nkoch
captainfab - I believe I need one of your power steering gear plates and tube and flange.
I have been reading the thread and see that there was comments of drilling 4 new holes for the plate, will I have to do that. I have a 66 c10 that already had the power steering gear and pump. When I swapped out the front end to a 79 I don't recall seeing a plate on there previously and since cant find it. Just curious if I will need to re-drill holes or if the plate will mount right up.
nkoch is offline   Reply With Quote
Old 12-15-2014, 12:31 AM   #483
Captainfab
60-66 Nut
You could use those same holes but that may or may not position the steering box in the correct location.
Old 12-15-2014, 08:54 AM   #484
Ronw435
Ronw435's Avatar
Installed Captains power steering plate yesterday. Followed instructions that came with it and it came out great. Great piece and great instructions Captain. Everything lined up perfect. Great to see people making quality parts in "America".
Thanks again Captainfab.
Old 12-16-2014, 01:01 AM   #485
Captainfab
60-66 Nut
I appreciate the purchase.
Old 12-23-2014, 01:34 AM   #486
First c10
First c10's Avatar
I have a 68 k10 without a dippled frame. Can you sent me a pm on the brackets needed to add power steering? Thanks
Scott
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 12-24-2014, 12:29 AM   #487
Captainfab
60-66 Nut
PM sent
Old 01-03-2015, 03:13 PM   #488
_mg
Active Member
_mg's Avatar
I have a '64 K10, picked up a '87 power steering box and pump from a k20. Need the adapter plate and tube and flange. PM with the details please. Thanks!
_mg is offline   Reply With Quote
Old 01-04-2015, 12:22 AM   #489
Captainfab
60-66 Nut
I'll send you a PM
Old 02-16-2015, 04:39 PM   #490
w00dst0ck
w00dst0ck's Avatar
Thread diameter/pitch for '72 power steering box?
It's a masterpro, but Oreilly's doesn't list that information. Adapting to a GEN 3 5.3.
w00dst0ck is offline   Reply With Quote
Old 02-17-2015, 12:07 AM   #491
Captainfab
60-66 Nut
They are 7/16"-14. I also replied to your PM regarding this.
Old 02-17-2015, 05:29 AM   #492
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
I'd like to find 3" trailing arm perches.
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline   Reply With Quote
Old 02-17-2015, 10:44 AM   #493
w00dst0ck
w00dst0ck's Avatar
Referring to the lines, not the mounting hardware as I know my pump is not 7/16-14.
Thanks.
Old 02-17-2015, 11:00 AM   #494
w00dst0ck
w00dst0ck's Avatar
Line fittings on gearbox*
Old 02-17-2015, 11:02 AM   #495
Captainfab
60-66 Nut
Here is the for sale thread for my trailing arm mounts
http://67-72chevytrucks.com/vboard/s...d.php?t=620836
Old 02-17-2015, 11:08 AM   #496
Captainfab
60-66 Nut
OK......Between your posts and PM's to me and jumping between steering box and pump, It has all been confusing. At one point you said that the supplied hardware did not fit your steering box.
If you have a '72 steering box the hose fittings will be SAE. I don't remember the thread pitch off hand, but they are for a 3/8" inverted flare. To adapt those to a the Metric pump on your 5.3 you will either have to have custom hoses made with the appropriate fittings on each end, or you will need the SAE to Metric adapters at the steering box.
Thanks.
Old 02-17-2015, 11:25 AM   #497
w00dst0ck
w00dst0ck's Avatar
FYI guys buying boxes from Oreilly's. I got one yesterday for a '72 and the mounting threads are 3/8-16.
Old 02-17-2015, 11:29 AM   #498
w00dst0ck
w00dst0ck's Avatar
Yeah sorry about that, was a typo. Although it was about the steering box.
Found a thread on adapting the 5.3 stuff to the older boxes. Looks like it's just a Gates fitting and then the factory 3/8 inverted flare lines.
Old 02-18-2015, 12:11 AM   #499
Captainfab
60-66 Nut
I checked a original '71 C20 steering box as well as a few 80's steering boxes and all have 7/16"-14 threads.
Old 02-18-2015, 10:48 AM   #500
w00dst0ck
w00dst0ck's Avatar
I exchanged it and my new one is 7/16-14 as well.
