Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 06-06-2021, 10:22 PM   #476
Captainfab
60-66 Nut
Re: Power Brake Booster Adapter Bracket
A dual diaphragm booster is always better than a single diaphragm, but I do not know if that will solve your issue. I gather that you did not have this issue with the 15/16" bore master?
Old 06-07-2021, 12:21 AM   #477
rcodea
I have been chasing an underperforming braking system since installing the rotors and calipers. I started with the 15/16" master, but was getting this long travel and nearly no strong breaking. So i moved to the 1 1/8" to make up what i understood to be a volume vs pedal travel issue....but the pedal is performing the same but at a shorter travel than before.....so now ill try a dual 10.9 booster and see what happens.
I am at a loss but ill get there I guess....just keep throwong money at it right lol
rcodea is offline   Reply With Quote
Old 06-07-2021, 10:43 PM   #478
Captainfab
60-66 Nut
Is your booster pushrod connected in the original hole in the brake pedal or did you drill a new hole 1" higher?
Old 06-08-2021, 12:05 AM   #479
rcodea
The original hole....was i supposed to drill the pedal itself? Wouldnt higher change it from 6:1 to 7:1...which would be bad for the travel but good for assist?
Old 06-10-2021, 11:04 AM   #480
rcodea
hoping to get the booster on this weekend....its a parts store Duralast 54-71046....dual 10.9", from a 93 2500 w/vacuum assist.
i'll report back on how it works out for me.
Old 06-13-2021, 10:05 AM   #481
rcodea
I am happy to say that i have corrected the issue. The single 10.9 wasnt enough assist. the dual 10.9....worked like a champ!
now i just need to let the brakes bed in a bit and start adjusting the prop valve.
O hope this helps someone else out down the road.
~Ryan
Phoenix, AZ
Old 06-13-2021, 10:12 PM   #482
Captainfab
60-66 Nut
Thank you for the follow up and the parts info.
Old 03-17-2022, 04:27 PM   #483
Pinball Chris
I would like to buy one of the 63-66 booster brackets, powdercoated black.
Please pm the payment info.
Thanks,
Chris Barton
Pinball Chris is offline   Reply With Quote
Old 03-17-2022, 07:44 PM   #484
Captainfab
60-66 Nut
PM sent. If you have any issues with the new website, please let me know.
Old 03-17-2022, 07:44 PM   #485
Captainfab
60-66 Nut
Here is a link to my new website and online store where you can see and purchase all of the products that I fabricate for the '60-'72 GM trucks.
https://customfab-cda.com
Old 07-16-2023, 08:32 PM   #486
Captainfab
60-66 Nut
It has been brought to my attention that two of my designed brake booster brackets, That I have been selling here in this forum since 2009, have been copied by Right Stuff Detailing and are being marketed as their own design. I used to sell my booster brackets to them at a wholesale cost, but they have not purchased any from me for over 4 years. Now they have stolen my design and are marketing them on Summit Racing.
https://www.summitracing.com/search/...oster-adapters
I in no way gave them permission to copy my design of brake booster brackets. This is just a dirty trick on their part. I still fabricate and sell all 34 of my products on our website. Here is a link.
I am just a one man business working 80+hrs/7 days a week every week every month to try and make a living so I can pay my bills and buy food for me and my wife. I just wanted to post this on here to let everyone know that what they see on Summit's website are not my products. They are counterfeits. If any of you who support me in this and wish to let Right Stuff or Summit know your feelings, I would certainly appreciate it.
John
Old 02-02-2024, 09:21 PM   #487
karlbenz
I just acquired a 65 C60. It has hydraulic clutch. I looked on you website but wanted to ask if this is what I need. Not sure if there are differences in c10 and c60
https://customfab-cda.com/ols/produc...tch-conversion
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis
1964 GMC K10 383cu in/sm465/twin stick np205
1965 Chevy C60
karlbenz is offline   Reply With Quote
Old 02-02-2024, 10:31 PM   #488
Captainfab
60-66 Nut
That depends on whether your C60 came with a mechanical.clutch or a hydraulic clutch. If it has a mechanical clutch, you will want to purchase the '63-'66 booster bracket with the hydraulic clutch conversion. If it came with a hydraulic clutch from the factory, you will need the '60-'62 booster bracket with the hydraulic clutch. If you aren't sure which one you need you can always email me a few pics.
Old 02-02-2024, 10:35 PM   #489
karlbenz
I’ll get some pics tomorrow. I’m more confused now than I was before 😂 didn’t realize there were that many different applications 😳😁
1965 Chevy C60
Old 02-02-2024, 11:18 PM   #490
Captainfab
60-66 Nut
Yes. I fabricate 5 different booster brackets with the hydraulic clutch conversion. Those are a part of the 35 products that I fabricate and sell on our website
Old 02-03-2024, 11:06 PM   #491
karlbenz
Didn’t get back there till after dark
1965 Chevy C60
Old 02-03-2024, 11:14 PM   #492
Captainfab
60-66 Nut
Yes you have a hydraulic clutch. You will need my '60-'62 booster bracket with the hydraulic clutch conversion. You will have to move your windshield washer reservoir somewhere else such as on the radiator support above the voltage regulator. That is where some trucks had them from the factory.
