Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 08-02-2015, 01:35 PM   #476
BigRed76
BigRed76's Avatar
Re: D52 Caliper Rear Disc Brake Brackets
Originally Posted by Captainfab View Post
Zach, is that the same caliper you posted a pic of in post #455 above? If so, my apologies. That nub will need to be cut off or ground down to clear the lever. I guess I wasn't looking at that previous pic correctly.
Yes it is the same caliper is posted in post #455. Once I got all of the hardware on I had a feeling it would need cut off but I wanted to double check with you first. It's not a big deal, I'm just excited to finish this project.
By the way, excellent job on the brackets, they fit great!
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 08-05-2015, 11:25 PM   #477
72mitch
I would like a set of your uncoated brackets for a 72 c10 and also e-brake levers for Eldorado calipers thanks mitch
72mitch is offline   Reply With Quote
Old 08-05-2015, 11:51 PM   #478
Captainfab
60-66 Nut
Mitch, I will send you a PM with ordering and payment info.
Old 08-27-2015, 08:58 AM   #479
COOP3726
Do you have the brackets for a 85 c10 10 bolt rearend and how much are they?
Thanks.
COOP3726 is offline   Reply With Quote
Old 08-28-2015, 01:50 AM   #480
Captainfab
60-66 Nut
The answers to your questions are in post #1 of this for sale thread........
Thanks.
Old 09-15-2015, 07:31 PM   #481
rydeordie
Pm'd you Captainfab
Instagram: rydeordie72 https://instagram.com/rydeordiechevy/
rydeordie is offline   Reply With Quote
Old 09-15-2015, 11:38 PM   #482
Captainfab
60-66 Nut
I replied to your PM. You did not specify which rear disc brackets you were interested in.
Originally Posted by rydeordie View Post
Pm'd you Captainfab
Old 09-16-2015, 07:26 PM   #483
ol_skool_chevy
ol_skool_chevy's Avatar
'92-'02 AWD Astro...............NOT to be mistaken for the Ford Aerostar AWD....like i did.
Grrrrrrrrrrrrrrrr. the bolt pattern was wrong. Back to the pick and pull I go.
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 10-01-2015, 05:47 PM   #484
rydeordie
PM sent Captain Fab
Old 10-01-2015, 11:58 PM   #485
Captainfab
60-66 Nut
PM replied to.
PM sent Captain Fab
Old 10-07-2015, 11:54 PM   #486
Zackarymc
http://www.wilwood.com/BrakeKits/Bra...no=140-11385-D
Ok I've gotta run these rotors and calipers cause I've got 5 4 3/4 axles. Will these brackets work. I don't like the wilwoodo kit because they make me buy the parking brake kit. Trying to save a few bucks!
Zackarymc is offline   Reply With Quote
Old 10-08-2015, 01:00 AM   #487
Captainfab
60-66 Nut
The Astro/Safari rotors have the 5 x 5" wheel stud pattern. That is why they are used for this C10 application. If you must have a rotor for a 5 x 4.75" wheel stud pattern, you will have to redrill the Astro/Safari rotors. The other option is that I have been working on a set of rear disc brackets for trucks with the 5 x 4.75" wheel stud pattern. With those you have the option of a standard front caliper or an e-brake caliper. I just do not have a for sale thread for them yet. Send me a PM if you are interested.
Old 10-22-2015, 06:54 PM   #488
Gmcbroken
Alright all this brake talk has me lost.What wilwood kit works with this kit..I'm tryin to figure out a price for everything. Is there a website for this or no
Gmcbroken is offline   Reply With Quote
Old 10-22-2015, 11:13 PM   #489
Captainfab
60-66 Nut
If you want to run the Wilwood dual piston D52 calipers you simply need the Calipers with the 1.25" diameter pistons for the 1.28" thick rotors in your choice of color.
Here is Wilwood's website.
http://www.wilwood.com/Calipers/Cali...spx?subname=GM D52 Dual Piston
Old 10-23-2015, 12:07 AM   #490
Gmcbroken
So with your bracket I can run that setup on the rear. Is the front rotor the same thickness? Will the d52 caliper with 1.25 diameter pistons bolt up to the front as well with no problem? Or is the rotor different then 1.28 or bolt pattern different?
Old 10-23-2015, 12:54 AM   #491
Captainfab
60-66 Nut
Yes, my D52 brackets are designed to accept the Wilwood dual piston calipers.....just as shown in the pics.
Your front rotors could be 1" thick or 1.25" thick. I do not know what you have. On the front you will want to run the Wilwood dual piston D52 calipers with the 2" diameter pistons.
Old 11-23-2015, 09:30 AM   #492
BIGJOEGS
Hi I'm interested in a set of brackets. Do you have any in stock?
Thanks Joe
BIGJOEGS is offline   Reply With Quote
Old 11-23-2015, 01:58 PM   #493
Dobok
Hey Captain; I talked to you awhile ago about me swappin a 66-12 bolt to my 94 GMC !!! You said it would work no problem and I agreed but I decided to change the 12 bolt a little !! I might be shortening the 12 rear diff a couple of inches and adding the Torino ends to it too !! Will I still be able to use your brackets !!! Thanks
Dobok is offline   Reply With Quote
Old 11-23-2015, 09:11 PM   #494
BIGJOEGS
Thanks Joe
PM sent
Old 11-24-2015, 12:27 AM   #495
Captainfab
60-66 Nut
I replied to both of your PM's
Thanks Joe
PM sent
Old 11-24-2015, 12:36 AM   #496
Captainfab
60-66 Nut
No. None of my rear disc brackets will bolt up to a Torino housing end. They are all designed to bolt up to the Impala/Truck backing plate bolt pattern.
If you are shortening the housing, why not use these ends so you can use the D52 rear disc brackets instead of Ford brakes of some sort?
http://www.moserengineering.com/othe...lip-axles.html
I have the base plates already machined to act as the bearing retainer with these housing ends.
When you order your axles you will need to be sure to order them with the correct brake offset.
Old 11-25-2015, 12:17 AM   #497
Dobok
Thanks Captain; Not sure that I am going to cut any off( but I want too)so I guess I will have to check with some other people and see what I can do !! I really do love your setup though and who knows what will happen as I have to do some motor work first and get that out of the way !!! It now looks like I have some options so that is great !! Will let you know when I do it and keep up the great work too !! Thanks for all your efforts !!!!!!
Old 11-25-2015, 11:47 PM   #498
Willi2ds
I'm in!! I'd like to get a set.
Willi2ds is offline   Reply With Quote
Old 11-26-2015, 12:14 AM   #499
Captainfab
60-66 Nut
Old 11-30-2015, 12:04 PM   #500
rydeordie
Payment sent.
