Old 02-11-2014, 10:55 AM   #476
naphtali5725
naphtali5725's Avatar
Re: My new project 86 Silverado
Originally Posted by Paul83 View Post
That dash is going to look good. Nice work.
thanks, i was thinking about making a pad for it so there would be no glare from the aluminum, or else I'll have to paint it, we'll see
My build thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=515829
Disabled Veteran
82nd Airborne Division
Operations: Desert Shield, Desert Storm, and Uphold Democracy
naphtali5725 is offline   Reply With Quote
Old 02-11-2014, 11:01 AM   #477
naphtali5725
anyone have thoughts on an entry level mig welder? one that's easy to learn on, and that isn't too horribly expensive
My build thread...
Disabled Veteran
Old 02-11-2014, 02:34 PM   #478
NONHOG
NONHOG's Avatar
About 17 years ago I went to Lowes. (Eagle?) and picked up a 110V Lincoln
I really like it. I could upgrade. I have yet to feel the need.
(that day will come LOL)
"I feel the need for speed!"... as soon as I am done with my nap.
NONHOG is offline   Reply With Quote
Old 02-11-2014, 09:50 PM   #479
chevybuilder18
chevybuilder18's Avatar
I'd have to agree, argon gas is a protective layer from oxygen, which can at a moleculor level cataminate the arc and make it weaker. However there is other migs like the chicago electric 90 amp flux core from harbor frieght, which comes with the wire ect. But I'd like a argon wire feed over this any day, just a lot cheaper. Don't get me wrong, settings and stuff are excellent, doing welds aren't hard but keeping a beed going is the tough part since its non gas mig, and oxygen disrupts the arc
Her name is Quicksilver
1978 Chevrolet silverado, shortbox stepside currently being swapped IN is a LM7 5300 vortec, 4l80E, factory 4.11s, slammed, a dream ride and coined QUICKSILVER
gotta pay $$ if you wanna play
chevybuilder18 is offline   Reply With Quote
Old 02-11-2014, 10:51 PM   #480
rs74
rs74's Avatar
Not sure about cheap but I like Miller welders.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 02-16-2014, 10:35 AM   #481
naphtali5725
thanks guys for the welder input, i'll keep my eye for a good deal somewhere
sent some more cash to my engine builder, about 50% paid up so far for my Pontiac 461.
i'd like to get an aluminum radiator, something that fits in the stock location(any suggestions)?
still deciding what gauges i want.
truck came with factory a/c, but i'm not putting it back in, whats the best solution to delete the a/c? i'll do a search around, if anyone has opinions, they're appreciated
updates/pics soon
My build thread...
Disabled Veteran
Old 02-16-2014, 11:30 AM   #482
rs74
rs74's Avatar
Are you going to run a heater or wanting to do away with all of it? http://www.acdelete.com/pages/73-90_Truck.htm makes a delete kit that still allows you to run a fan for the heater. Or I believe that http://www.vintageair.com/2013catalo...ebpgs%2036.pdf might offer block off plates for the wholes in the firewall. There was a thread in the general 73-87 forum here that showed where someone had blocked theirs off. Maybe it was Greenlee's 4x4 build thread now that I think about it. I will have to look.
Roy
1987 R10 shortie
Old 02-16-2014, 11:31 AM   #483
rs74
rs74's Avatar
http://67-72chevytrucks.com/vboard/s...=425848&page=6
Roy
1987 R10 shortie
Old 02-16-2014, 07:27 PM   #484
bigguy
Don't know what your price range is, but I do all of my work with my Hobart 210mvp. I used it daily in a body shop as well as welding on my frame. It's pretty flexible.
bigguy is offline   Reply With Quote
Old 02-18-2014, 09:50 AM   #485
naphtali5725
hey guys, just paid for premium membership, i have a lot of left over parts from my build... i'll be posting them for sale soon with pics...
if you need anything specific, let me know
My build thread...
Disabled Veteran
Old 02-23-2014, 01:40 PM   #486
naphtali5725
what a worthless piece of &%$#*@ razzle, frazzle
took an hour to do just this, compressor gets hot, cuts off... pressure lasts about 10min if that (200psi compressor)
i need one that will hold up to continuous DA sander use....
this sucks and i can't afford a new one...
My build thread...
Disabled Veteran
Old 02-23-2014, 03:37 PM   #487
Sodell
Sodell's Avatar
I don't even try to use my DA with my compressor. I use an electric one at the house...
Scott
87 Chevy 2WD SWB, 88 4x4 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=610652
Sodell is offline   Reply With Quote
Old 02-23-2014, 03:39 PM   #488
naphtali5725
yeah i have an electric jitterbug, but not a DA... i'll have to get a new compressor, or an electric DA, cause i have so many DA discs... i don't have money for either
My build thread...
Disabled Veteran
Old 02-23-2014, 04:11 PM   #489
Sodell
Sodell's Avatar
I guess you stripped them down and no primer?
Scott
Old 02-23-2014, 04:13 PM   #490
naphtali5725
i sanded inside the fenders, then epoxy primed.... then weather turned cold...
sanding down outside now, will epoxy prime when i'm done... probably better for me to get electric DA
My build thread...
Disabled Veteran
Old 02-23-2014, 04:35 PM   #491
Sodell
Sodell's Avatar
it has slowed me down the past few months for sure, sitting here watching the Daytona 500, cold outside..
Scott
Old 02-23-2014, 04:37 PM   #492
Sodell
Sodell's Avatar
Well it's last years race anyway...
Scott
Old 02-27-2014, 12:11 AM   #493
naphtali5725
i got my combination valve, and the rest of the stainless brake lines all clamped in to the frame etc. will be getting braided hoses for the front in the next few days...
trying to get the under dash stuff all done...
cleaned up the brake pedal and assembly... painted it with flat black rattle can, will post pics tomorrow...
cleaned the fuel tank mounts, was going to paint them too, but it turned cold here in the mountains, so i'll wait on that.
going to tear down the steering column, and check it all over, and replace turn signal switch etc.
more updates and pics the next couple o' days
My build thread...
Disabled Veteran
Old 02-27-2014, 12:17 AM   #494
rs74
rs74's Avatar
How did the brake line that runs from the distribution block up front to the rear fit? They were Inline Tube right? I bought mine from Summit (Right Stuff Detailing) and they did not fit as good as I would have liked. They needed to be longer to look and fit like the factory lines.
Roy
1987 R10 shortie
Old 02-27-2014, 12:35 AM   #495
naphtali5725
yeah, inline tube... i agree, they didn't seem to fit as nice as i would have liked... but this isn't a show truck... i did the best i could to make sure they were straight and tucked in like the originals... the lines from the combination valve to the front wheels were a friggin pain to get straightened out like i wanted.
as long as they work, don't leak and last another 20 yrs i'll be satisfied LOL
My build thread...
Disabled Veteran
Old 02-27-2014, 12:41 AM   #496
rs74
rs74's Avatar
Thanks. I was curious. Everyone says Inline Tube so I wondered just how good they were. They sound like they fit just about like the ones I got from Right stuff.
Roy
1987 R10 shortie
Old 02-27-2014, 12:44 AM   #497
naphtali5725
if i had a tubing bender etc. etc. i could have fine tuned the bends, but i just used my hands and a saw horse hehehehe, shade tree'in style
My build thread...
Disabled Veteran
Old 03-12-2014, 10:12 PM   #498
naphtali5725
75 degrees yesterday, in the 20's tonite...
if it would stay 70 and above i could finish priming/painting my damn cab, i need a shop... grrrrrr
My build thread...
Disabled Veteran
Old 04-09-2014, 10:55 AM   #499
naphtali5725
had another seizure a week ago, so i've been laid up...
paid some more on my engine, 2700 so far, so hopefully i'll have it paid for soon
for now i'm not working on it, just collecting parts so i can dig in when i get better...
will update as soon as i can
My build thread...
Disabled Veteran
Old 04-09-2014, 11:12 AM   #500
rs74
rs74's Avatar
Man, sorry to hear about that. Take care of yourself.
Roy
1987 R10 shortie
