Old 08-02-2021, 09:57 PM   #476
butch2000
Re: What did you do yo your truck today??
I washed it ?
butch2000 is offline   Reply With Quote
Old 08-05-2021, 03:00 PM   #477
Just call me Sean
Just call me Sean's Avatar
Picked up a steering box at the junkyard for the '93.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 08-05-2021, 04:55 PM   #478
butch2000
I washed this one , clay bar then waxed , still looks good for original paint !!
Old 08-05-2021, 07:27 PM   #479
Just call me Sean
Cool Volkswagen.
Old 08-05-2021, 10:22 PM   #480
butch2000
Thanks , that was our father son project , Original paint AC Caddy , may get deleted ??
Old 08-05-2021, 10:26 PM   #481
butch2000
not sure how that happened , ??
Old 08-05-2021, 10:31 PM   #482
butch2000
Started this one today sitting since 2019
Old 08-06-2021, 12:19 AM   #483
Just call me Sean
I have to resize my pictures or they post upside down.
Did you do an engine swap? My brother had one and he put in a bigger engine. I think a VR6?
Old 08-06-2021, 10:03 AM   #484
butch2000
yes we did a 1.9 diesel with bigger turbo , tweaked pump , about 160 hp , fun to drive , rolls a little coal !
Old 08-06-2021, 07:07 PM   #485
Just call me Sean
Nice. Looks like it's in good shape.
Old 08-15-2021, 02:29 PM   #486
Just call me Sean
I changed the seals on the power steering high pressure line and the fitting that screws into the pump. Started leaking after I put on the used pump.
Old 08-15-2021, 06:28 PM   #487
firestopper
firestopper's Avatar
wash and a drive
firestopper is offline   Reply With Quote
Old 08-22-2021, 10:26 PM   #488
mikelom
Replaced the power steering pump. Also, the flowmaster that I ordered from 4wheelonline arrived today. I'm planning to install it tomorrow.
mikelom is offline   Reply With Quote
Old 08-23-2021, 07:21 PM   #489
Just call me Sean
Front brakes again.
Old 08-28-2021, 10:29 AM   #490
angertheloner
angertheloner's Avatar
Originally Posted by Readyforduty24 View Post
i replaced my head lights, front turn signals and corner marker lights with a more modern looking style. i also replaced all the bulbs in the tail lights and back up lights with L.E.D.s. Then i replaced the fuel tank straps as the rear strap rusted through and my fuel tank almost dropped out from under my baby.
What bulb did you use for the reverse lights.
There are 10 kinds of people in the world: those who understand binary and those who don't.
1985 C20 Scottsdale 350/SM465
1978 C10 Silverado Big 10 3 on the Tree (sold)
angertheloner is offline   Reply With Quote
Old 08-29-2021, 12:09 PM   #491
Snarl95
Snarl95's Avatar
washed and waxed
1995 k3500 cclb srw 6.5 turbo diesel.
The lessons that hurt are the lessons that teach.
There is always a price to pay.
You are free to make any decision you want. You are not free from the consequences.
Snarl95 is offline   Reply With Quote
Old 08-29-2021, 07:50 PM   #492
1971 GMC SHORTY
1971 GMC SHORTY's Avatar
Put Rear Firestone Air Bags, Compressor, 5gallon Tank all Wired And put Extra Air Fitting To plug line To Check Air Pressure
1966 GMC K25 V6 351E Original Utility Truck
2000 C3500 Hot Rod Utility Truck
2003 ROAD KING 100th 124ci 6 Speed
145CI M/P Pro Street FXR
2002 FXDP
2007 2500HD DURAMAX. DD
Studio Teamsters / Mechanic
Retired GM Master Tech 20 Years
Retired Ford Tech 15 Years
1971 GMC SHORTY is offline   Reply With Quote
Old 09-01-2021, 04:18 PM   #493
Just call me Sean
Picked up a center link at the junkyard for the '93. Non wearable part seems to be worn out.
Old 10-08-2021, 06:12 PM   #494
Just call me Sean
A/C compressor locked up today.
Old 10-16-2021, 02:10 PM   #495
Just call me Sean
Driveshaft center support bearing came out of the mount again. This time I'm gluing it to the rubber.
Old 10-28-2021, 12:44 AM   #496
Just call me Sean
Changed the EGR valve.
Old 10-29-2021, 12:34 AM   #497
sweetk30
sweetk30's Avatar
Rear dana 80 pinion seal in my 3500-HD truck . She was worn out and leaking at only 83,300 miles .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 11-01-2021, 01:29 AM   #498
Just call me Sean
I repositioned the plug wires on the '99, it was misfiring and I could see the residue from where they were arcing. I'll pick up new wires soon. I also exchanged the lifetime warranty plug wires on the '93 as it was misfiring too.
Old 11-09-2021, 06:50 AM   #499
Been needing tires for the 'Burb. Friday I picked up a screw at Lowes that took it down flat while loading up cinder block... Argh! I got a closer look at that flat and decided to pull them all and install the wheels and tires off my '72, which will be sitting till spring at least. I like the look but it's temporary. Although the same size tire (285/75-16) the 8" rims cause tires to rub. I'll get the old tires off the 7" Accurides and mount the better tires. First I want to paint those wheels argent for a closer to factory look. I had them that color originally on my old '92.
Old 11-13-2021, 07:35 PM   #500
Just call me Sean
Pulled the distributor from the '99 to check the gear for wear. Seemed fine. I need to find a scanner that reads CMP retard.
