Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 10-26-2011, 02:19 PM   #501
hayhauler71
hayhauler71's Avatar
Re: Lets Play Whatz It? !!
Saw Blade Runout tool
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 10-26-2011, 02:36 PM   #502
RUSHNBOBO
no....
It is used on a hand held power tool which is always used outdoors......
The rollers are adjustable and squeeze or pinch a part of this tool together as it is pulled across; taking the part back to original specs.
RUSHNBOBO is offline   Reply With Quote
Old 10-26-2011, 03:20 PM   #503
hayhauler71
edge roller for metal work
Fuzzy
Old 10-26-2011, 03:35 PM   #504
hayhauler71
Ariens belt adjuster for snow thrower or mower [Need another clue please like the manufacture]
Fuzzy
Old 10-26-2011, 03:37 PM   #505
RUSHNBOBO
no....
It is used on a gas powered hand tool's "attachment or part", ....the tool is used outdoors and often in the woods. Used on a metal part but the part is not sheetmetal it is either a laminated steel or solid....the attachment varies in width depending on the tool but most are approx 1/4 inch wide
Old 10-26-2011, 04:22 PM   #506
Dunenutt
Newbee
Dunenutt's Avatar
It adjusts the slot/gap on a chainsaw bar?
Dunenutt is offline   Reply With Quote
Old 10-26-2011, 05:37 PM   #507
RUSHNBOBO
bar rail closer.......winner
Old 10-28-2011, 08:10 PM   #508
RUSHNBOBO
ttt.....someone put up a pic
Old 10-28-2011, 08:40 PM   #509
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Whatz It?
ETsC10 is offline   Reply With Quote
Old 10-28-2011, 09:35 PM   #510
RUSHNBOBO
is it vacuum pump ?
Old 10-30-2011, 10:07 AM   #511
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Nope...on the right track though.
Old 10-30-2011, 10:42 AM   #512
bmfm64
bmfm64's Avatar
Air compressor?
bmfm64 is offline   Reply With Quote
Old 10-30-2011, 10:48 AM   #513
ETsC10
Hand Crafted C-10
ETsC10's Avatar
YES!
Old airbrush compressor.
Works well...sure wish I had the
airbrush it came with.
Old 10-30-2011, 03:39 PM   #514
RUSHNBOBO
A friend of mine told me that it was a air compressor, and I told him I've never seen one without fins for cooling....Wrong !!!
Old 10-30-2011, 08:46 PM   #515
bmfm64
bmfm64's Avatar
Whatz it?! Name and use.
Old 10-30-2011, 09:33 PM   #516
RUSHNBOBO
Part of a yard hydrant shut off valve
Shut-off valve operates below the frost line. Hydrant cannot freeze because when it is closed, all water in the stand pipe drains out of a hole in the valve which is set in the ground
Old 10-30-2011, 09:37 PM   #517
bmfm64
bmfm64's Avatar
Nope
Old 10-30-2011, 09:38 PM   #518
RUSHNBOBO
close though huh ?
Old 10-30-2011, 09:43 PM   #519
bmfm64
bmfm64's Avatar
I'll say it's used in plumbing...
Old 10-30-2011, 09:53 PM   #520
RUSHNBOBO
Used to temporarily plug a pipe by turning the top and expanding the rubber....so a plumber can fix a broken or leaking section
Old 10-30-2011, 09:54 PM   #521
bmfm64
bmfm64's Avatar
Name?
Old 10-30-2011, 09:55 PM   #522
RUSHNBOBO
brb......
Old 10-30-2011, 09:56 PM   #523
bmfm64
bmfm64's Avatar
I'm sure you will! LOL
Old 10-30-2011, 10:13 PM   #524
RUSHNBOBO
Expanding Drain Plug
Old 10-30-2011, 10:15 PM   #525
bmfm64
bmfm64's Avatar
Nope
