01-26-2014, 06:59 AM | #501 |
Re: How about some pics of Static dropped 60-66
64
LIFE IS SHORT HAVE FUN |
01-26-2014, 10:22 AM | #502 |
Ridin' Dirty
1978 C3500 Crewcab (Project) 1979 C2500 Crewcab (Driver/project) 1988 R2500 Crewcab (Driver) 1988 V3500 Crewcab 1988 R2500 Crewcab (Mint, Ex Fire Dept) 1968 Chev Suburban (4x4 conversion) LINK 1970 Chev C20 Suburban (driver/cruiser)LINK 2005 Impala (Incognito vehicle) 2004 Yukon XL Denali (Kid hauler) 1947 Case tractor Facebook Page(1000's of pictures of GM cars and trucks organized into albums) YouTube Channel |
01-26-2014, 12:06 PM | #503 |
But Found Her 25yrs Later!
They became stock in 66.
But you could order many options for earlier years. . Many guys still add them today. That may be the case here with his truck.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
01-28-2014, 09:05 AM | #504 |
Ridin' Dirty
Oh interesting
01-30-2014, 06:37 AM | #505 |
Yes they were an option in 64 and became standard equip. in 66
01-31-2014, 04:22 AM | #506 |
What stock steels do you guys run with that have front Disc brakes?
I'm going for a stock look but lowered. Thanks. |
01-31-2014, 12:39 PM | #507 |
these wheels are 15x8" Camper Specials with 225/75-15 tires 21/2' drop spindles with 2'dropped springs and 5' dropped springs in back
01-31-2014, 01:25 PM | #508 |
I had the same problem Desert.Chevy. I found some 15" "Camper Specials" They are stock for our trucks so they use the hubcaps and there 8'' wide with an offset that will accommodate the disc brakes. I haven't figured out how to post a picture on here but you can check it out on the 60-66 chevy.com Facebook pagehttps://www.facebook.com/groups/191006017617783/ or my personnel https://www.facebook.com/rickeylee.rogers
01-31-2014, 11:09 PM | #509 |
Thank you, it's a 3 inch drop front and just TJ springs in the rear right now. Drop spindles and bags planned for summer.
02-09-2014, 09:51 AM | #510 |
Springs only
02-10-2014, 09:14 AM | #511 |
1961 C60 Viking 8' Dump 261 SM420 2-Speed Rear 1966 C10 Fleetside 350 W/ Saginaw 4 speed 1985 K10 Chevy 6.2 diesel 700r4 longbed 2001 Dodge 3500 Dually 24v NV5600 4x4 USMC Reserves Jason |
02-11-2014, 06:05 AM | #512 |
Thank-you!! The floors are nice. The pass side rocker is the worst. As soon as this crazy weather changes I have plans to replace both rockers. I like this 64 because it's a factory air truck. Check out my post (Lucky Find)
02-11-2014, 09:40 AM | #513 |
That thing is perfect. Fix the rockers and leave everything else alone. I love it. I wish mine didn't have spots of new primer paint on it and a primer door or I'd do the same as yours.
02-11-2014, 05:36 PM | #514 | |
In fact, I wouldn't replace the whole rocker. I would do something far less intrusive and just patch the rot.
02-11-2014, 05:42 PM | #515 |
02-11-2014, 05:51 PM | #516 | |
Welcome to the board ratride, that's a beautiful truck. Is that freshly restored?
02-11-2014, 06:05 PM | #517 | |
Rollin' Old Skool
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
02-11-2014, 06:18 PM | #518 |
Yes 65'.
02-11-2014, 07:17 PM | #519 |
Nice truck RatRide....I like the stance.
02-11-2014, 08:45 PM | #520 |
We're having a truck meet here in GA this Saturday the 15th. If you're close enough come on out. Detail here.
http://67-72chevytrucks.com/vboard/s...d.php?t=611832
Billy 65 C10 ............................... ____ ................ ________-|___\____ .;.;;.:;:;.,;.|__(O)___|____/_(O)| _______________________________ P.S. Send truck money ! |
02-12-2014, 11:52 AM | #521 |
Thanks! With out cutting the front drop springs it sat perfectly level. But with the round wheel wheels, visually it appeared to be lower in the rear. By cutting a half coil, it dropped about an inch, giving it just a little bit of rake. I my opnion it was well worth the extra effort.
02-13-2014, 04:55 AM | #522 |
Very Nice RatRide!!!!!
02-13-2014, 07:57 AM | #523 |
Hmmmmmmmmmm.
02-13-2014, 11:01 AM | #524 | |
How much suspension travel do you have in the rear being that low? Thanks. |
02-13-2014, 12:18 PM | #525 |
Thanks!!!
It was restored about 2-3 years ago. Not show quality but excellent daily driver quality, with the major stuff like motor&trans and body&paint already being done. I like wrenching, and can do bolt on parts but when it comes to the major stuff I'll pay a perfessional. In my opinion the springs have a perfect spring rate. Not too stiff, but stiff enough, along with the sway bars to give good corner handling. The shocks that came in the kit aren't very good though. The front tends to have a floaty bounce. I'm really picky when is comes to my suspension and handling as I tend to do track days with my other cars, but this truck is my daily driver. I wanted a more comfortable, but fun ride that I can zip around corners. I didn't want to put a ton of money into it, that's way I bought the kit. If I had to do it over agin, I don't think I woud recommend this kit. You can probably piece together your own kit with better shocks, and better swaybar endlinks/mounts for around the same price. I'll probably upgrade to better shocks in the future. Theres about 1 inch travel in the front after shaving down the new bumpstops a little. In the rear I have zero travel it's riding on the new bump stops, as I did not c-notch. Last edited by RatRide; 02-13-2014 at 12:44 PM. |
