Old 08-04-2014, 06:52 AM   #501
mikeleeshields
mikeleeshields's Avatar
Re: 1970 SWB : Porterbuilt to the Extreme "Double E"
I put fluids in the truck yesterday and finally started the truck. Unfortunately when I turned the key off the truck continued to run. I unhooked the battery (positive cable) and it continued to run off of the alternator for almost another minute. I have to figure out what is going on here. It wasn't dieseling it was full blown running. I have a new ignition switch in the system. I would assume it has something to do with the wiring somewhere. With that said I was happy because it ran and idled on it's own, I was pretty happy.
1970 SWB Got My PB Suspension It's On Now- 1970 SWB - Porterbuilt to the Extreme
Mike
mikeleeshields is offline   Reply With Quote
Old 08-04-2014, 08:47 AM   #502
Bennett68C10
Bennett68C10's Avatar
Bodywork is looking good Mike, glad to hear you got it fired up too. Now it's time for a video
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 08-04-2014, 11:09 AM   #503
Bhelton
Bhelton's Avatar
Trucks looking really good Mike!
Bhelton is offline   Reply With Quote
Old 08-04-2014, 12:12 PM   #504
mikeleeshields
Thanks. I may wait to get a video posted until I have some mufflers on. It is pretty loud. The bodywork is a 20 footer right now. Just don't get too close, haha.
Thanks buddy. Long process but fun at the same time.
Mike
Old 08-05-2014, 11:37 AM   #505
mikeleeshields
Bled the brakes last night. Hopefully when I get back in the garage tonight there are no more leaks. Now that I have some brakes I will feel a little more apt to put the driveshaft in and put it in gear.
Unfortunately the darn thing still continues to run when I turn the key off. I put a new ground direct from the frame to the block. I also made sure the coil wire did not have power when the key was off. I guess I have to do more troubleshooting.
Mike
Old 08-05-2014, 12:59 PM   #506
ajgriffin
ajgriffin's Avatar
Great progrèss and glad to hear you got the engine fired up! I'm no engine expert, but I did a quick Google search and came up with this: http://www.badasscars.com/index.cfm/...prod/prd94.htm
Obviously, I can't vouch for the info, but thought I would pass along. You may also want to post something in the engine section here if you haven't already to see if guys can help you out there.
69 C10 SWB -- Left to me by a loving father. Finishing the build we never got the chance to do together
ajgriffin is offline   Reply With Quote
Old 08-05-2014, 04:55 PM   #507
mikeleeshields
Thanks for the help. I have searched this site for some resolution and came up with quite a few things to try. I will start there and go from there.
Mike
Old 08-06-2014, 06:58 AM   #508
mikeleeshields
I checked the brakes last night and there was one little leak so I'm hoping the brakes are good to go. I also installed the driveshaft. One step closer to driving this beast again. I ordered a Lokar gas pedal and throttle cable.
I also installed a one wire alternator last night and did away with the exciter wire and additional wire from the EZ wire harness that ran to the alternator. The truck still continues to run when the key is turned off. I have looked through all of the posts to try and figure this issue out. I will just have to get someone down to look at it I guess.
Mike
Old 08-06-2014, 11:53 PM   #509
jtp67-72
jtp67-72's Avatar
Mike, take wire off of alternator and recrank....if it kills now with key off there is a backfeed through keyswitch...seen this before...got to look up the remedy i did with a diode a long time ago......jim
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791
jtp67-72 is offline   Reply With Quote
Old 08-07-2014, 06:54 AM   #510
mikeleeshields
Thanks Jim. I got the diode from work yesterday. My next question today was going to be "did I need a diode with a one wire alternator". I guess you answered my question. I will try this tonight.
Mike
Old 08-11-2014, 07:19 AM   #511
mikeleeshields
I got the gas pedal and throttle cable installed. Started the truck up and pulled it out of the garage for the first time in about 2 years. Lots of good things that came out of that experiment. The brakes work, the new driveshaft works, and the engine runs on it's own.
Here is what it sounds like started up and running.
https://www.youtube.com/watch?v=vttnpdBmMMo
I also figured out why the thing continued to run. I had hooked my fan up to my coil wire thinking it was an accessory wire, stupid me. I cut that wire and now the truck stops when I turn the key off.
Mike
Old 08-11-2014, 08:34 AM   #512
BigDaddyV
BigDaddyV's Avatar
Looking good bud! Glad to hear you figured out that problem
J. Vess, 6'6", Gearhead, Welder, Fabricator, Nutcase
1955 Chevy Stepside "Dudley"
My daily http://www.67-72chevytrucks.com/vboa...d.php?t=760288
1972 Chevy C10, Project "Chevro~Layed out" Nether Storm
Build Thread http://67-72chevytrucks.com/vboard/s...23#post6007523
BigDaddyV is offline   Reply With Quote
Old 08-11-2014, 10:24 AM   #513
mikeleeshields
Mike
Old 08-11-2014, 12:02 PM   #514
mikeleeshields
I now have a new goal of getting this thing to a local car show the 23 of this month. Now that it actually moves I am one step closer.
I started mounting the bed again. I will also try to set up my air ride so that I don't have to take an air tank with me, lol. The fenders should go on tonight possibly.
Mike
Old 08-11-2014, 12:49 PM   #515
Bennett68C10
Looks good Mike, hope you make it to the show
Keith
66 Suburban
IG: bennett68c10
Old 08-12-2014, 07:18 AM   #516
mikeleeshields
Thanks Keith.
Mike
Old 08-12-2014, 07:24 AM   #517
mikeleeshields
Worked on trying to setup my bedfloor last night. With the use of some good ol cardboard I started laying out the bedfloor a couple different ways.
I can't decide if I want to mount the air components towards the cab or towards the rear of the bed. If I keep everything in the back I can keep my floor at the regular height in the front with a flip up panel to see the PB parts. They are too nice to hide. Anyone have any opinions. I kinda like the idea of the last picture where I mount the parts in the rear and bring the notch cover down to encase the tank like it is part of the notch cover.
I am sure I will think of a couple different ways before it is over.
Mike
Old 08-12-2014, 09:39 PM   #518
mikeleeshields
Any preferences fellas.
Mike
Old 08-12-2014, 10:09 PM   #519
Hardesty454
Hardesty454's Avatar
Air parts up front look cleaner
Rob
1971 c10 - ground up in progress
Tripp's Speed Shop Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=589750
Hardesty454 is offline   Reply With Quote
Old 08-13-2014, 07:28 AM   #520
mikeleeshields
Thanks Rob for your thoughts. I will continue to ponder this setup.
Mike
Old 08-13-2014, 07:38 AM   #521
BigDaddyV
BigDaddyV's Avatar
I'm going for hidden. but in the rear around your Fuel tank looks good.
Old 08-14-2014, 04:18 PM   #522
mikeleeshields
I am hoping to make some progress with the bed tonight. We will see how that goes.
Mike
Old 08-14-2014, 11:46 PM   #523
jtp67-72
jtp67-72's Avatar
Mike, are u sure those are 69010 headers?? I ordered the coated set after i saw how they fit your firewall on the pass. side but when i got them the pass. header is different...look at this link and then your pass side...they are different....the ones i got are like the ones in link...pass side front tube goes over on mine and under on yours....the problem is yours look like they turn down more at firewall (pass side) and i think these will hit firewall (don't have cab back on yet)........thanx jim
http://www.jegs.com/i/Hedman/500/690...15C=1797532060
Old 08-15-2014, 12:13 PM   #524
mikeleeshields
Jim,
I got mine from Summit http://www.summitracing.com/parts/hed-69010 I do see what you are talking about with the front tube placement. The summit add doesn't even show a picture. I can take a couple more pictures of the placement in relationship to the firewall if you would like.
Mike
Old 08-15-2014, 12:18 PM   #525
mikeleeshields
I put on the fenders, grille, and a bumper I had laying around. It doesn't fit the greatest but it will work for the show this weekend.
For some reason my driver's side isn't fitting up the greatest. I had to shim my core support on the drivers side to get the fender to line up. This kind of throws things out of whack. I will have to figure this out when I tear it back apart I guess.
Mike
