#501 |
6>8 Plugless........
![]() Join Date: Sep 2007
Re: 71 4X4 Frame off Restoration
The door gaps look awesome! Nice work on your cart. I will have a window air in my garage by next summer. It's insulated nicely so there is no reason to sweat in it. Haha
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#502 |
Thanks Guys. I installed an attic fan above my garage in 2008 it's solar powered but it does not exchange the air fast enough on hot days. one of these days I will do something about it.
#503 |
Finally got the lower radiator brackets set up. had to drill out some spot welds and bend the flange under them so they fit and bolt in the larger brackets for my 4 core radiator. I tried to mod the upper brackets but I lose the fan shroud mounting hole so I ordered the ones for larger radiator.
#504 |
I got a phone call Saturday morning to pick up the bed it's ready. pictures are after I got it home. Got some work done this week end took the head lights apart and bead blasted the buckets and mounted the bed to the frame. got some other parts ready for power coating as well.
#505 |
![]() Join Date: Mar 2015
Looking good Dave.
Making progress Posted via Mobile Device |
#506 |
![]() Join Date: Nov 2007
Quad cab, sweet. I have not been a fan of the few extended cabs I've seen (sorry) but I think this will look good since it is essentially a shortened 'burb.
Running in place gets you nowhere fast. -me 1968 GTO 4-spd covnvertible 1970 K-20 4-speed, factory AC. |
#507 |
Bed is looking great!
Brett ![]() 67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594 72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.) 72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614 YouTube: https://www.youtube.com/@6dee7-7dee2 |
#508 |
Yup bed is looking good. I bet your counting the days till cab day?!
BTW, you asked about color for your emblems that need repainting. I used 1 sot pinstriped paint and here are the colors. I used orange, but I think stock is chevy red on the emblems. Both are circled in this image.
Project Reno Build http://67-72chevytrucks.com/vboard/s...d.php?t=392636 Easier to beg forgiveness than ask permission! ![]() |
#509 |
I'm worried that the cab wont fit in the garage after I put on the frame I don't feel comfortable leaving it out side. I found some 17" wheels cheep that I'm going to pick up and see if a 45R on 17" wheel will get it in the garage. We will see if a few week. I need the 17" wheels so I can put my front brake calipers on the 16" wheel I have are not big enough.
Thanks for the color chart I will check it out. |
#510 |
I checked in to the paint and their is a art store not far from me that caries the paint. I will check them out this week end.
#511 |
I did the same thing, but the store that was supposed to have it didn't ended up buying it online from summit. BTW, you will have much better results if you use the 1 shot hardener as well. See my build for hardener part numbers. It definitely helped it flow better and dried much faster.
Good luck! Can't wait to see'm all new looking and shiny Chris
#512 |
I remember your comment on the hardener. I will get some.
#513 |
The bed looks great!
#514 |
I did not get much done on the crew cab this week end. Ended up working on my 1998 flat bed Saturday and Sunday so I can drive it to work. It did pass smog test. I'm giving my company truck back this week as it's not comfortable to drive and the AC smell SH**. it's a 2013 Ford F150 the seat is like sitting on a bolder.
I final got my fender badging Friday. looks purdy dam cool I think. the Cheyenne 30 I got from Paul's GMC. the LSX was from Amazon and the 5.3L was from Newegg. |
#515 |
![]() Join Date: Dec 2012
Looking good!!! I want to get some of the lsx badges. Can you post part numbers of the lsx and 5.3L?
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO ![]() |
#516 |
In my previous post I said I got the LSX badges from Amazon. In fact they came from Ebay. I don't have part number for them. I did a google search for LSX emblem and 1 for 5.3L to find them. when I get home from work Tuesday I will see what info I can give you to order them.
#517 |
Newegg description item #9SIA5921T89453 Body TheEm|5.3-BLK R
Ebay Description CHEVROLET CORVETTE CAMARO PONTIAC WS6 SS RS LSX ENGINE EMBLEMS BADGES QTY 2 NEW the seller ibuythebestdeals |
#518 |
The local store to get the 1 shot paint requires you to be a member and I don't have the required info to join. so I checked out Summit and they don't sell the hardener 4007. so I tried Eastwood and the cost to touch up 1 emblem would be about $70.00. so I Went to Tower Hobbies and ordered some Model Master paint witch I'm familiar with and ordered 5 different red paints for $16.50 if they don't match I can mix and match. thinning with good lacquer thinner will make this paint dry fast and dull the finish witch will help match the color.
#519 |
Thanks for the info....they look sharp!
#520 |
Nice badges!
#521 |
I spent some time after work mixing up some paint to fix one of my Cheyenne 30 emblems and it worked out real good. I mixed 1/4 ounce of red 1/4 ounce of brown and about 1 ounce of yellow to match the color. the scratch was in side the zero about 1/4" square scratch. now its gone.
#522 |
Nice work! Those LS badges are really gonna look nice. I like the direction you went.
Chris
#523 |
Thanks Chris
I'm trying to save money for painting at this point. The badges cost me $90.00 for the LSX and 5.3L. forget what the Cheyenne 30 cost I think about $80.00. Having some custom ones made would have been a lot more. I should be getting my cab back in about 2 weeks. set up seats steering wheel and master cylinder then find a place to get the paint done. |
#524 |
Dave, we may have already discussed this but I don't remember. What Burban parts do you left? Just wondering if there's anything I might be able to use and could buy from you.
Also, was Cesar helpful at all?
56 Chevy step-side 68 Chevy Suburban 69 Corvette Stingray 00 BMW 325 (Daily driver) 09 BMW M3 18 GMC Acadia (Wife's daily driver) |
#525 |
Mr.D I don't have much of anything left from the 69 burb. I do have the 04 burb but I need my cab back to see what I'm going to use out of it. need to test fit some things. you did mention you wanted the core support from the 04.
