Old 10-14-2004, 09:44 PM   #501
lofly'a
lofly'a's Avatar
TTT - i keep reading this post and learning
-02 avalanche (daily driver)
-66 gto ragtop 389/400 (garage queen, hand-me-down from dad)
-72 Tribute Trans Am (6.0LS/T56 6-speed) in progress
-2003 YUKON (Wife's)
-71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain)
-48 3100 SWB - 12/31/23 LONG TERM Project
lofly'a is offline   Reply With Quote
Old 10-14-2004, 10:00 PM   #502
ChevyCruizer
17's too small
ChevyCruizer's Avatar
it took a long time to read but i have went through this entire thread. awesome source for information. i am just in the start of my project. for sure, i have learned who not to deal with. my 68 is my first old truck and i may be a little slow but i can not figure out what a pinch weld is. any help?
phanton - don't sell it that thing is sweet.
68 C10 SWB SS 5 lug power disc brake conversion 2.5 inch drop spindles van tilt column Air Ride Technologies Cool Ride air bag kits Performance Online tubular upper control arms and shock relocator kits ECE super track panhard bar 1 piece side windows
ChevyCruizer is offline   Reply With Quote
Old 10-14-2004, 10:08 PM   #503
lofly'a
lofly'a's Avatar
i have no desire to lay frame. i can't imagine the thought of losing pressure at speed. it looks cool but "DANGEROUS AS HELL IN MY OPINION". i'll be content if i can bottom out out 3" above the pavement.
Old 10-14-2004, 10:10 PM   #504
smbrouss70
smbrouss70's Avatar
The pinch weld that they are referring to is located on the bottom side of the rocker panels where 2 pieces of metal are "pinched" together, and then spot "welded"
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 10-20-2004, 03:46 PM   #505
BK
BK Built
BK's Avatar
I was wondering if anyone that is layin frame on stock trailing arm can post pics or e-mail at fathead_03@hotmail.com I desire to do this, and am just curious as to how they are all designed. Also, how much room behind the front seats is there with a big notch, enough to fit another set of seats??? And up front, with the crossmember notch, could i Z my frame instead, i was thinking 2". Has anyone done this, and if so, what problems did you encounter? I want to use stock steering box(no rack and pinion) and i think the only problem will be ill have to put another joint or 2 in the steering linkage to clear the upper control arm. Thanks. OH, and last, is there anyone in or around washington/oregon that has done the crossmember notch? I would love to take a look, and also maybe even have you notch mine
BK is offline   Reply With Quote
Old 11-02-2004, 02:45 AM   #506
BK
BK Built
BK's Avatar
Well, ive been contimplating this crossmember drop, as well as z-ing my frame. I picked myself up a late 70's early 80's chevy frame with the full front suspension and whatnot. I was wondering, will the crossmember from it bolt up to my frame, so should i just take the whole front suspension off of it, notch that crossmember, then mount it up to my frame? ALso, i wanted to z the frame, and was wondering, as i want to z the frame 2", should i only go 1" on a crossmember drop, or should i go 2 & 2, or what should i do to get a fair amount of drop while not having to put 30 u-joints in my steering shaft. Thanks. Oh, also, anyone here in washington or souther BC wanna do my crossmember notch??? Thanks.
Old 11-02-2004, 03:10 AM   #507
fastbagged68
fastbagged68's Avatar
Do a 1.25" crossmember drop then see where you framesits and go from there. I personaly would not z your frame. Cut your Air bags mount as short as you can and cut up the crossmember to clear your bags and your panel will sit down on the ground. What size tire you running on the front? Also where your trailing arms mount to the crossmember on the rear you will need to take out your rivets and the peice of 1/8" plate that is there. If you want to lay true frame.
fastbagged68 is offline   Reply With Quote
Old 11-14-2004, 02:59 PM   #508
sixty8c10
MY EX DRIVES A BROOM
sixty8c10's Avatar
keep this thread going lots of info here
They say nobody's perfect.
I'm a nobody, so I must be perfect.
Building Nemo -1968 C10 Long Bed
FRED -1947 KB-2 International
sixty8c10 is offline   Reply With Quote
Old 11-25-2004, 01:42 AM   #509
phantom dually
Project92 SWB stepside
phantom dually's Avatar
Anyone have a interest in all my moded crossmember parts??
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 11-25-2004, 09:42 AM   #510
FuelCellGuy
FUEL CELL GURU
FuelCellGuy's Avatar
I don't understand, are you wanting to sell the crossmember?? If so, how much??
FuelCellGuy is offline   Reply With Quote
Old 11-25-2004, 12:51 PM   #511
phantom dually
I am seriously contemplating selling everything I have. I dont have time to work on this project as my prioritys have changed.
Old 11-25-2004, 08:52 PM   #512
71'tahoe
71'tahoe's Avatar
dont lose sight
phantom, ive been reading this post from the begining.I really think that if you sell your parts your truck will never be completed.I think that some off the guys on the site are right,maybe step back,take a breather,and start on it in the new year.I know what its like to be building a new home and not enough time for the truck,as im also doing a couple trucks.I have stepped back for acouple months.Im now back on the site and on this thread first.To be honest and not get to soft on you guys is this thread that got me back in the game.I live for the under construction pics.So phantom dont give up and dont make me come down there and help finish that truck,cause im only an hour or so away.
71'tahoe is offline   Reply With Quote
Old 11-26-2004, 01:27 PM   #513
Chris~GS
turners website doesn't work, he IS still in business though right? does anyone have a phone number so i can get a catalog perhaps?
Chris~GS is offline   Reply With Quote
Old 11-26-2004, 01:39 PM   #514
phantom dually
Please dont waste your time on Turners!! Even though all the parts I got from him bolt up correct and will work great the experience with him has been a nightmare. Not sure if he is even still in bussiness. Air ride makes a set of a arms now for around $700 and a board member here can make you a modded member for around $400. If you decide to use Turner BEWARE!!
Old 11-26-2004, 01:50 PM   #515
fastbagged68
Catalog from turners......sh!T. That guy is a crook. His shop consist of walmart tarps and dirt. If you look in Street Trucks Mag you will see his ads and all those pics are taken @ his shop. His shop is a dive. What parts you need let me know. I have bought alot from this guys and can let you know what works and what doesn't.If you did get his number you wouldn't get through. he never answers his phone and his mail box is alway full.
Old 11-28-2004, 10:00 PM   #516
slammd72
slammd72's Avatar
one of my buddies had on of the first issues of "Truck Builder" and they were starting a "Project 67". they were tackling the front and rear suspension first. they had an awesome replacement crossmember, control arms, bags, and shocks set-up. does anyone know who makes this (or if youve seen it)? id like to see if that would work on all 67-87 1/2 ton frames. any info would help.
P.S. i live off those build pics and will be posting some of my own very soon. so keep em coming!!!
slammd72 is offline   Reply With Quote
Old 11-28-2004, 10:56 PM   #517
98L150
///Relaxed Atmosphere
98L150's Avatar
Attn: Slammed 72
Jim Myers Racing has a mustang 2 crossmember suspension that bolts on these trucks and works very good. We have one on a 67 truck at the shop that is using shockwaves. I do not have them on a website so this web site won't let me post them. If some one can help me with posting them to the web I will gladly post them.
72 Suburban
64 Chevy short fleet
04 Chevy Colorado Sport Reg Cab
2012 Chevy Avalanche
2003 Chevy S10 Blazer Xtreme
http://www.hubgarage.com/mygarage/RA_Jeff
64 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=295915
98L150 is offline   Reply With Quote
Old 11-30-2004, 12:29 PM   #518
grnddwn
belly dragger
grnddwn's Avatar
The one in truck builder was a Scott's one. We (Macgyvers) make a bolt in MII one too but I prefer to use a dropped stock one on the trucks we are building.
grnddwn is offline   Reply With Quote
Old 11-30-2004, 03:02 PM   #519
SCOTI
SCOTI's Avatar
What reasons motivate your preference?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-30-2004, 04:05 PM   #520
grnddwn
belly dragger
grnddwn's Avatar
I like the Chevy parts and the MII crossmember wasn't designed to lay the truck on the ground. Its not that they don't work just fine. I just tend to sell people more on the dropped Chev. The MII does provide you with a better turning radius. The control arms aren't as wide. I think the factory one looks better. Maybe I'm just wierd. Its what i'm used to using
Old 11-30-2004, 08:52 PM   #521
slammd72
slammd72's Avatar
now are all the crossmembers universal from 67-72 to 73-87 1/2tons or no?
Old 11-30-2004, 08:55 PM   #522
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Yes, the 73-87 will work under a 67-72.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 12-01-2004, 12:56 AM   #523
N2TRUX
Happy to be here
N2TRUX's Avatar
Jeff are they the ones you sent me of Steves blue truck?.....
Old 12-01-2004, 01:21 AM   #524
BaggedC10
Under construction!
BaggedC10's Avatar
That's a nice setup! Does anyone have a link as to where I can purchase this front-end? Thanks.
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 12-01-2004, 09:04 AM   #525
N2TRUX
Happy to be here
N2TRUX's Avatar
Sure can... http://www.jimmeyerracing.com/pu6.html
