Old 06-15-2023, 03:22 PM   #501
Kartch1
Re: slammed 57
The truck is looking amazing! We talked a while back when I was "slammed" with the pandemic stuff. You really helped me getting going on my project. Thanks!!!
Random question: Do you remember the backspacing on your front rims? My Scotts seems like the rotor sits pretty far back towards the frame. Also, what did you end up with on clearance between the front tire and fender?
Thanks again for helping me out so much at the beginning of my project.
Kartch1 is offline   Reply With Quote
Old 06-17-2023, 02:09 PM   #502
slammed57
slammed57's Avatar
Re: slammed 57
Hey bud, good hearing from you, glad to see your getting some work done on it. For my front wheels they are 8" wide with 4.5" back spacing on them. if you get a measurement from your rotor to your frame I'll compare it to mine, also your hub to hub track width.
as for tire to fender I have 3.5" of clearance. Remember when you ride these trucks low your going to need some clearance for turning. having then this low your always going to rub some where ( its just the nature of the beast) question is, when you get a good turning radius do you want it to rub on the outer lip of the wheel opening of the fender or the frame. I pick the frame because its a smooth surface and no one will ever see the rub mark . the wheel opening on your fender is going to chew up your tires and even worse damage your fender a bit. mine rubs just ever so slightly on the frame at full steering lock. hope this helps.
My 57 current build
http://67-72chevytrucks.com/vboard/s...d.php?t=662590
slammed57 is offline   Reply With Quote
Old 06-24-2023, 08:36 PM   #503
slammed57
slammed57's Avatar
Re: slammed 57
AAAAAnd it is in! now back to color sanding and polishing the rest of the truck!
My 57 current build
Old 06-24-2023, 10:53 PM   #504
BIGglaSS
BIGglaSS's Avatar
Re: slammed 57
Looks good! Get'r done!
My museum of good intentions: 1957 3100 BBW restomod -- 1970 442 W30
BIGglaSS is offline   Reply With Quote
Old 06-29-2023, 12:06 AM   #505
Kartch1
Re: slammed 57
Thanks so much, I really appreciate it. I will message you some measurement tomorrow. What you say makes total sense. I went with the Scotts Hotrod superslam after talking to you a while back. Great kit.
Your project is looking great!! So awesome to see it come together.
Old 01-01-2024, 04:40 PM   #506
8man
Re: slammed 57
I just went through your build and wanted to say very nice work. Thanks for sharing.
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 03-23-2024, 08:44 PM   #507
slammed57
slammed57's Avatar
Re: slammed 57
Well been working slow motion here. Had my mother in law and father in law pass away so I been dealing with them and their assets. But I did manage to finish up the engine bay took it for a spin around the block a few times, then to have a rear main seal redone due to it leaking, so I had to pull the tranny to fix it. But it’s done and runs REAL good and zero leaks. I also added a hydroboost system for the cam gave me poor vacuum for the brakes( I had a gut feeling that was going to happen) but it stops on a dime now. Iam moving on to finish color sanding and getting the rest together. Talk to y’all soon
My 57 current build
Old 03-23-2024, 10:47 PM   #508
dsraven
Re: slammed 57
sorry to hear about your loss, never good. hope you can work through it. best wishes for that and prayers for you and your family.
truck looks great.
Old 03-24-2024, 04:57 AM   #509
Rickysnickers
Re: slammed 57
Sorry about the passing of your parents. Condolences to you and your family.
Old 03-24-2024, 12:57 PM   #510
Kevin_C
Re: slammed 57
My condolences.
1955 chevy longbed shortened, C4 vette suspension front and rear with flatout kit. Gen V LT1/8L90
http://67-72chevytrucks.com/vboard/s...d.php?t=746958
Kevin_C is offline   Reply With Quote
Old 03-25-2024, 07:52 PM   #511
Jason 56
Re: slammed 57
So sorry for your loss. I find tinkering with my project helps occupy my mind during difficult times. On a different note… Hydroboost looks good!
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build
Jason 56 is offline   Reply With Quote
Old 03-26-2024, 12:49 PM   #512
58CameoAZ
Re: slammed 57
Hey Slammed,
Just stopped by to catch up on your build and seen your post, My Condolences
on your loss , So Very, Very Sorry Guy.
Amazing progress on your truck Buddy! looks Awesome!
Allen,
Payson Az.
58CameoAZ is offline   Reply With Quote
Old 03-28-2024, 01:28 PM   #513
oldman3
oldman3's Avatar
Re: slammed 57
Sorry for your loss.
oldman3 is offline   Reply With Quote
Old 03-31-2024, 09:55 AM   #514
my56chevytruck
my56chevytruck's Avatar
Re: slammed 57
My friend, I am so sorry for your loss.
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
