Old 01-27-2017, 12:09 PM   #501
83GMCK2500
Re: Let's Build A 1 Ton Crew Cab 4x4
Mmmm, pretty spiny thing. Glad they finally got the correct bearing in for you.
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 01-27-2017, 05:10 PM   #502
NastyBuzzard
NastyBuzzard's Avatar
Doing some mock up. I need to know if I'm going to be able to use my 6.5 serpentine setup. Man I hope so but it isn't looking good. Maybe if I didn't have the dual alternator setup. Idk.
Here is the original setup..
It does look like I can clear the x over pipe with my xmember tho..
1988 GMC R3500- Cut Brothers 4WD Conversion Kit, 6.5 TD NV4500/NP208 D60 14BFF
2020 1500 Silverado 3.0 Babymax
2002 2500 Silverado- 6.6/ Allison
2010 CTS V- The "NastyBuzzard"
1979 Trans Am - Eventually getting 6.0/T56 swap with boost
NastyBuzzard is offline   Reply With Quote
Old 01-30-2017, 08:55 AM   #503
NastyBuzzard
Looks like it will all fit except the vacuum pump. Which is what people have told me so... Woohoo!
Did more tinkering, cleaning and test fitting.
What direction is the vacuum pump distributor supposed to face?
I spent some time helping with building the plasma cutter this weekend as well. Also spent some more time working on the actual finish work of my shop.
I need to get an engine leveler so I can install the 6.5 without damaging anything. I have new motor mounts mounted and I am ready to get this thing installed and wired.
Old 01-31-2017, 11:02 AM   #504
NastyBuzzard
I finished the DS brakes. I need to make changes to the adapter brackets and clock the caliper some. Currently you have to shave a good portion of the top bolt to be able to bolt on the caliper bracket.
The offset is turning out to be perfect for me though. I am not a huge fan of wheels sticking out way past the fenders and can always add spacers or whatever if I desire. On my 87 ls truck I built with the H3 calipers up front the wheels stuck outside the fender about 1". Not a huge fan.
So ready to get this diesel in and fire it off to help light a fire under my ass to make quicker progress on getting it together. Just trying not to cut corners and I still have the rear disc conversion bracket to design.
Old 01-31-2017, 12:31 PM   #505
83GMCK2500
Hot damn, that looks gooooood. I'm also in the keep-the-tires-covered camp.
Devin
New Daily, the '96
Old 02-06-2017, 10:17 AM   #506
NastyBuzzard
First off let me say, I am tired of these busy damn weekends. We had 2 events this weekend, a wedding reception and superbowl. Those 2 events lead to me only getting an hour and a half to even look at my shop.
Guess what? Next weekend is our valentines thing so probably wont get jack done then either.
Anyways, one thing that has been holding me up is I needed to get trans mounted. & I didn't want to install it dirty or unpainted. To do that though I had to fix my water pipe and drain..
I still have to dig some more of the trench but it does work for now.
First round of cleaning on the NV4500.. Damn thing was dirty and all the cracks and crevices don't help. That was all I had time for.
The front wheels are now back on the ground though, so now to finish the brake conversion in the rear.
Old 02-06-2017, 04:18 PM   #507
Wide Open
Do I remember correctly that you are doing to try the stock passenger side setup for the clutch?
What year NV4500 did you get?
Wide Open is offline   Reply With Quote
Old 02-06-2017, 04:21 PM   #508
NastyBuzzard
Yes, that is correct. I will be using the stock passenger side setup. I found a couple people who have done it now with no issues.
Its 94 or 95, I cant remember exactly. Has the tall ass first gear.
Old 02-06-2017, 04:32 PM   #509
Wide Open
Cool. I think I'm going to try the passenger side setup too.
Old 02-06-2017, 04:35 PM   #510
NastyBuzzard
I will detail it out here when I get too it, which will hopefully be sooner than later but if you do it first let me know! I just can't justify buying that expensive ass Advance Adapters bell housing. I have also seen people drill and tap the NV4500 to accept SM465 hydraulic bell housing (which I have one of) but I would screw it up, I know it.
Old 02-06-2017, 04:59 PM   #511
Wide Open
Lol I probably would too. I'm planning on anking mine out and not hacking it up. I'm going to try and mount the 205 directly to the NV4500 tail shaft like someone else did on here but I can't remember who it was.
Old 02-06-2017, 05:02 PM   #512
NastyBuzzard
I think I saw that too but I don't remember.. I was really lucky finding that 32 spline 208 that I found.
Old 02-07-2017, 12:40 PM   #513
83GMCK2500
I think it is one of DirtyLarry's builds that you're thinking of. I remember seeing a 205 behind a NV4500 as well. EDIT: this one? http://67-72chevytrucks.com/vboard/s...9&postcount=32
92-94 NV4500s are the ones with the super low first gear. The top cover on the one pictured is 92-94, 95+ have a bolt on shift tower. 1995 NV4500s are a one-year only oddball: http://www.advanceadapters.com/tech-...dentification/
Devin
New Daily, the '96
Old 02-07-2017, 01:26 PM   #514
Wide Open
Yeah I think that's the one. The thread isn't showing correctly on my phone. Pretty sure it was Dirty Larry and later in his thread he ditches the adapters and cuts the NV4500 tail shaft adapter in a couple of places to make it mount up.
Old 02-14-2017, 02:27 PM   #515
NastyBuzzard
Finished digging my drain with what little time I had over the weekend. I also slapped the fuel tank in and drill out some holes to use some larger hardware than 3/8".
Finally some noteworthy progress... What you see here is my model with my brake adapter bracket in it. It is the yellow part. Since I have no mill, I have it out for quote to get made. Hopefully it wont be too pricey. This is to get the rear brakes from a duramax onto my 14bolt so I can have slip on rotors at the rear as well with dual piston calipers.
Old 02-14-2017, 04:46 PM   #516
Wide Open
You probably mentioned it somewhere earlier in the thread but I can't remember what fuel tank you went with. 20ish gallons?
1972 K10
1986 K30 crew cab dually
2002 Z06
2007 Escalade
Old 02-14-2017, 04:50 PM   #517
NastyBuzzard
Its the 31 gal tank. I couldn't fit the 40. I tried but it sat right above the rear diff and was way too close to touching it.
Old 02-15-2017, 01:05 PM   #518
83GMCK2500
Hah, I just saw the pic of the bracket on a Facebook group I'm in.
Devin
New Daily, the '96
Old 02-21-2017, 02:00 PM   #519
Clrussell
Clrussell's Avatar
Just read the entire thread. Good work on it!
I want one of those engine cross members. Like seriously want one
61 apache
Clrussell is offline   Reply With Quote
Old 02-21-2017, 02:39 PM   #520
NastyBuzzard
Thank you! I wish I had more time and $ to have more attention to detail. For instance, I really wish I could have built a new motor and rebuilt the trans/tcase for this build but for now as time and $ allows, its got to go in as is and hope it runs! This truck is being built to tow and made to work so isn't going to be spotless more of a nice daily driver. That's the plan anyways.
As far as the engine xmember goes, it will be available for purchase once my friend and I finish the plasma table and get things going on making our own parts. I have several designs and so does he so we are going on a joint venture, at least on the weekends to start out
Truck related, here is a better look at what the rear 14bolt disc brake conversion brackets are going to look like...
I have one being made for prototyping so hopefully I can get it in my hands soon.
Was tinkering with motor some more and have some stuff running into each other. I also need to find a way to bend that chrome intake piping to go to the 6.5 intake...
More work on the plasma table, we have both been real busy. Still pushing to have it done in May.
Here's my buddy. We were both dirty from cutting/grinding/welding and working on it but at least he is enthusiastic! If you look close we finally got all the slat guides welded in..
I am also working on my own version of front d60 brake conversion brackets. The ones I bought need a lot of refinement in my opinion plus they weigh in as pretty expensive.
Old 02-21-2017, 02:58 PM   #521
Clrussell
Clrussell's Avatar
I'd actually be interested in just paying you for the file, I've got a buddy with a plasma table so he can cut it.
61 apache
Old 02-21-2017, 03:08 PM   #522
NastyBuzzard
You wouldn't really be saving any $, I mean we can just cut the flat out for you if you have your own way to bend the parts. I am willing to just sell cut parts. To sell you the dxf I would have to get some sort of non compete agreement b/c I do intend to sell these.
Old 02-21-2017, 03:27 PM   #523
Clrussell
Clrussell's Avatar
Fully understand the file thing since you'll be selling.. I won't steal your product. We do have a metal break too.
61 apache
Old 02-21-2017, 03:45 PM   #524
Clrussell
Clrussell's Avatar
I'm not in a rush anyway. Just want to get one when I can haha
61 apache
Old 02-21-2017, 04:05 PM   #525
NastyBuzzard
I can have them made by my current vendor but that will inflate cost. If you can give me a little time then yeah, I can have exactly what you want for a good price. With or without the buzzard emblem cut in! Actually that will be removed for our actual "company logo."
