04-22-2019, 02:51 PM | #501 |
Re: What did you do to your truck today.The 3rd chapter
Just finished these. This is the second water pump I painted, because dummy didn't think to fit the first one. The GMB "OE" replacement is not an OE replacement (BBC), doesn't quite clear the factory timing chain cover. I'll be most replacements are the same.
They probably figure you can just bend the cover, but I'd rather eat the labor. A four hour lesson learned, because both were brushed. Should have bought the Delco to begin with. It's a lighter pump too.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
04-22-2019, 06:25 PM | #502 |
Pulled the two saddle tanks. Going to Carlisle so they will be for sale there.
04-22-2019, 08:22 PM | #503 |
All detailed up
Do it, Do it right, Do it right the first time |
04-22-2019, 10:08 PM | #504 |
How did I get this OLD!
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023 Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt. |
04-22-2019, 10:22 PM | #505 |
those are beautiful
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
04-22-2019, 10:25 PM | #506 |
thanks for the reply what brand headers do you have a part # ?
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 Last edited by zicc1835; 04-22-2019 at 10:28 PM. Reason: more |
04-23-2019, 07:54 AM | #507 |
Not roller rockers, just OEM. The valve covers are Billet Specialties. Got them through Summit like most parts cause you get free shipping.
Phil "Money is only a tool to create and achieve what you want most in life" PayPal: rodnrudy@comcast.net |
04-25-2019, 11:54 PM | #508 |
Swapped out a battery box is all. The bolts can be a real (^( without pulling the radiator. The box I wanted is solid. I don't see any pitting, but know better. Hopefully it suits my rebuild.
Pulled the RH skirt off the same truck recently. Fitted a few skirts on it, practice I was hoping to use it for the rebuild as well. Nice fender, but too much rust in front. So I'm in the hunt for a RH fender. That or pair of replacements.
04-26-2019, 02:28 AM | #509 |
http://67-72chevytrucks.com/vboard/a...1&d=1556259847
Cleaned up 4 horn buttons. Disassembled. Polished out scratches starting with 220 grit wet sand worked up to 7000 grit.
04-26-2019, 10:49 AM | #510 |
I keep missing your replies. Hedman 68190, for 68-72 Chevelle I painted them with Rustoleum high heat paint. Don't have the $$$$ for Jet Hot coating...
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
04-26-2019, 04:41 PM | #511 |
Almost finished the interior:
Steve My Build Thread: http://67-72chevytrucks.com/vboard/s...=morning+glory 1971 C10 Inline 6 250 700R4 "Marlene" 1934 Chevrolet Master Sedan 350 700R4 "Iris" 1941 Ford 1/2 Ton 5.0 H.O Roller C-4 "Rose" 2019 Honda Ridgeline |
04-26-2019, 07:55 PM | #512 |
Finished my interior too
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count |
04-26-2019, 09:48 PM | #513 |
Mostly, neglected and drank some beer, but I did finish blasting the air cleaner, shot the first coat of paint on it. Sorry, no pics, it’s at work.
04-26-2019, 11:05 PM | #514 |
Who Changed This?
...and Nice!
Gotta get after my interior and dash. Interior is shot and I want to get more instrumentation than the stock gauge dash has.
04-27-2019, 12:16 AM | #515 |
Mines all back as well.
04-27-2019, 08:43 AM | #516 |
thank you for the reply
04-27-2019, 05:02 PM | #517 |
I got the engine fired and run in yesterday and today I put my Billet Specialties Speedways back on and put her on the ground. I went back to the 5 1/2, 7" static drop I had and I like the look a lot more. Ran to the gas station and filled her up and took her for a spin before the rain showed up. Life is good.
04-27-2019, 07:55 PM | #518 |
Proprietor of Dale's Corner
I like it a lot!! How's it run? I'm guessing good as it looks.....
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
04-27-2019, 11:33 PM | #519 |
Active Member
I tried getting my horn setup fixed. I was missing the pin. Also went to car show and saw this cool carryall.
Posted via Mobile Device |
04-28-2019, 08:38 AM | #520 |
It runs well so far. The ride is "firm" being lowered that much but I like it that way.
04-29-2019, 10:02 AM | #521 |
First car show of the year.
04-29-2019, 10:06 AM | #522 |
Replaced timing chain (stretched).
04-29-2019, 11:17 AM | #523 |
Not ready to put the interior back yet
But making progress on the floors and rockers |
04-29-2019, 03:54 PM | #524 |
'67 Cut out dash repair . A little more work adding A/C vents and this will be done .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 04-29-2019 at 04:00 PM. |
05-03-2019, 01:05 AM | #525 |
A year ago I tried my spray gun for the first time. I sprayed Por-15 engine enamel. Got frustrated early, cleaned up the parts and declared I'd leave any spray gun business to the pros. Bet the paint was too thick. I thinned it, but probably not enough.
The enamel doesn't brush on most smooth surfaces with great success. I brushed the timing chain cover up nicely, but that's where it ended. Today I thought to try spraying again, only this time I met their 5/1 thinning max. In my novice opinion, it could have sprayed a bit heavier. I still didn't break out the gun, used a Preval instead I really should learn to use a spray gun. In hindsight I may sprayed all the Chevy Orange through a gun All precautions spraying this stuff. Fans, open garage, good respirator....It's bad stuff, and lingers a while. On a side, anyone know where that J-hook goes on a 71 BBC, and what it's used for? I removed it 25 or so years ago, can't remember I know it was Chevy Orange from factory, and don't believe it was rubber coated. I can't check right now, but it looks to take a 3/8" bolt, or even a 7/16" bolt tightly. Seems it goes on a head someplace, maybe even a stud, like off a water pump or thermostat housing.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 05-03-2019 at 01:36 AM. |
